Question about Desa International White Wireless Plug In Door Chime
Wiring formesa speciality products 390-6150XX-RX1A
SL-6150-RX
How do I find a Technics SL-BD22 grounding wire?
A grounding wire is just a piece of wire connected to an earth point on the deck, connecting to an earth point say on a radiator pipe. There's nothing special about this wire any old piece will do. You only need it if you get a hum noise when the turntable is connected to the amp.
Jul 18, 2014 | Technics Audio Players & Recorders
I need a new push button for an sl6195 rx
Heath-Zenith (I beleive they bought DESA) makes a battery remote push button bell that says its compatible with all Heath Zenith chimes. I bought one at Home Depot and it worked for my SL-6195-RX. (an on line doorbell seller and the Home Depot assoc all said it wouldn't work.)
UPC is 16963961975.
Item also shows a code "11G43" on a sticker on the back of the package.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/steven_7f54ab9063554f66
Nov 04, 2011 | Desa International White Wireless Plug In...
How many quarts of oil for an lexus 2002 rx 300 consume
the 1MZFE engines sump capacity is designated in the back of the owners manual.
(4.5 US quarts)
Feb 19, 2011 | 2000 Lexus RX 300
Why does chimes sound when no one as pressed bell
water can get into the button on door inside is a spring that pushes a part of the switch away from the other and when someone presses it they join together and bell sounds but if the rain gets inside it can make an electrical connection between the two points open it up and see if there is any trace of water the just put a bit of pva glue over the top join on the switch it will water proof it and will also be easy to remove or it could be a low battery or if mains anything can set them off mobile phones tv any thing that sends a rf signal its best to have as small a gap as possible between the two units
May 20, 2010 | Desa International White Wireless Plug In...
JUMPER SETTINGS FOR SL-6151-RX-A
I just solved a similar problem with mine. I found a PDF of the instructions for changing the frequency and the tone: http://heath-zenith.hcents.com/data/manuals/598-1034-02.pdf
May 14, 2010 | Desa International White Wireless Plug In...
I'm looking for push button for a trine/desa model #SL-6166-RX
I believe this is also the Zenith door chime. I bought mine at home depot, and they have the push buttons.
Mar 01, 2009 | NRS Huge Playhouse W/ Kitchen, Skylight,...
Desa International White Wireless Plug In Door Chime Logo
76 people viewed this question
Top Desa International Home Security Experts
Eric Kalman
Eric Kalman
Level 1 Expert
Mike
jasbo
jasbo
Are you a Desa International Home Security Expert? Answer questions, earn points and help others
