Question about HP Officejet 7500A e-All-in-One - multifunction fax / copier / printer / scanner color
Refer to printer documentation 0x61011bec
Why cant i set up my printer to print?
rockfixya
  • 679 Answers
SOURCE: Ink system has failed
IssueAn 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel. The printer cannot copy, receive faxes, or print.
Solution
Press the On button to turn the printer off.
Unplug the power cord from the back of the printer.
Remove all the ink cartridges.
Wait two minutes.
Plug the power cord into the back of the printer.
Press the On button to turn the printer on.
Install the ink cartridges when prompted.
If the error code does not display, the issue is resolved.
If the 0xc18xxxxx or 0xc19xxxxx ink system error code displays on the front panel, service the printer.
Posted on Feb 03, 2009
cene765
  • 787 Answers
SOURCE: I have an Hp c5180 and I am unable to print.
Look here: http://www.out-of-warranty.com/ink-system-failure-error-0xc18a-hp
Posted on Oct 08, 2009
SOURCE: Won't print
Ink system has failed. Unable to print. Refer to printer documentation. Error:Oxc18a0101
Posted on Oct 16, 2009
SOURCE: error message 0xc18a0001 Ink system has failed.
Easy fix. I found elsewhere on this site that the solution is to RESET the printer via the following instructions from HP...
1) Unplug Printer
2) Simultaneously press and hold the HELP & OK buttons
3) Re-plug in printer, while still holding the two buttons.
That's it ! You are reset. It will take a little time for the printer to re-configure, but you'll be printing in 5 or so minutes.
Posted on Oct 29, 2009
SOURCE: Print Cartridges Refer to documentation (No function works)
I was getting this same VERY unhelpful error and the only thing that solved it for me was to buy another genuine HP black cartridge (350XL). As soon as I put it in, it cleared the error and sprang to life. As a matter of interest, before this happened, the HP Toolbox utility was also saying that the old cartridge was nearly empty. So why on earth doesn't the printer tell you the same thing??? Come on HP - get your firmware sorted. Disappointed.
Posted on Nov 26, 2009
Hey im trying to help my sister out with some documents, only it was originally 4 pages which ive manged to get down to 2 double sided documents (ie 2 pages back to front) and now i cant seem to be able to...
Open the saved document then click file print. Then when the print page comes up on your screen set the printer to print to as Microsoft Document Writer. Which is a virtual printer. Then click print, save the file on your computer either my Documents or on the Desktop. Click print.
It will then print your document to a file.
This file can then be attached to an e-mail.
Let me know how it goes!
Take care!
damnor01
Jun 08, 2011 | Canon PIXMA MX310 All-In-One Printer
Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel
Hi iam gaurav patil Control panel displays: "!Print Cartridge. Refer to printer documentation" What does this mean as device does not resposnd to any command whether through computer or on the control panel 2 day i refil my cartridge then also i cant print my docs pls solve my problem
Aug 31, 2010 | HP Photosmart C5280 Printer
When printing duplex the even pages print portrait and the odd pages print landscape...
This could be a setting on the printer, in the driver on your computer, or the document you are printing.
First, try printing a different document and see if the problem persists.
Reset the printer to factory default settings, also referred to as a cold reset. HP has instructions on their website here: HP LaserJet 2300 Printer Series Resetting the Printer Cold Reset
You can also go into the printer driver on your computer and reset settings there, or uninstall and reinstall the printer.
Sep 08, 2009 | HP LaserJet P3005 Printer
Can't access fax held in memory
justyourt916 --
I found this at:
http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
Here are the instructions for retrieving the fax's from the memory:
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Sep 08, 2009 | Canon PIXMA MX310 All-In-One Printer
Won't print
Mar 29, 2009 | HP Office Equipment & Supplies
Memory full
Memory Reference Print faxes received from memory when ink is low or paper has run out or paper has jammed. It may be necessary to press <Stop/Reset> to clear the error then attempt to print the fax from memory.
  1. Press <FAX>, then press <Menu>. [FAX SETTINGS] will appear at the top row.
  2. Use leftright.gifto select [MEMORY REFERENCE].
  3. Press <OK>.
  4. Use leftright.gifto select [PRINT DOCUMENT] or [DELETE DOCUMENT].
    If you select [PRINT DOCUMENT]:
    1. Press <OK>.
    2. Use leftright.gifto select the transaction number (TX/RX NO.) of the document you want to print, or enter the number using the numeric buttons. If you are unsure of the transaction number, print the MEMORY LIST
      Press <OK>.
    3. Use[ left.gif] to select <YES> to print the first page only, or use [ right.gif] to select <NO> to print all pages of the document. (Received faxes begin at 5001. Faxes waiting to be transmitted start at 0001.)
    4. Press <OK>.
    5. To print another document, return to step 4b, or to finish printing, go to step 5.
      If you select [DELETE DOCUMENT]:
    6. Press <OK>.
    7. Use to select the transaction number (TX/RX NO.) of the document you want to delete, or enter the number using the numeric buttons.
    8. Press <OK>.
    9. Use [left.gif ] to select <YES>to delete document, or use [right.gif ] to select <NO> not to delete the document.
    10. Press <OK>. To delete another document, return to step 4g, or to finish deleting, go to step 5.
  1. Press <Stop/Reset>.
Jan 21, 2008 | Canon PIXMA MP530 All-In-One InkJet...
How set Printer to Autoselect Tray
This will most likely be the in the menu on the printer. Refer to the users manual and how to access those setting.
Jan 26, 2007 | HP LaserJet 4250n Printer
HP Officejet 7500A e-All-in-One - multifunction  fax / copier / printer / scanner   color Logo
mukhtar21 shaikh
mukhtar21 shaikh
