Question about Garden
We require a manual for a Dondi Rotary hoe
Bearings and seals
2 Suggested Answers
backwoodsctr
  • 169 Answers
SOURCE: I require a manual for my Honda F90 Rotary Hoe.
honda has operator manuals online on their website. you can print off sections or the entire manual.
Posted on Nov 19, 2009
Type of grease for Dremel rotary tool bearings
From what I was told, the bearings are Oil Impregnated and do not require a lube
Mar 13, 2015 | Rotary Tools & Hardware - Others
HOW DO I grease bearings on a Suzuki LT-A450X four wheeler
I will assume you are talking about the wheel bearings. Removal procedure is detailed and you need a service manual to guide you. When you get the bearings out provided they are in good condition they are of a sealed type however very little grease is usually what you find in them. They will have rubber seals that can be CAREFULLY pried out . A small flat blade pocket screwdriver works well for this. Do not damage the lip of the seal. Removal of only one side is required. Pack and reinstall.
Dec 14, 2014 | Suzuki Motorcycles
Bearings are loud when drum is spinning
well if its a front loader or a top-loader washer sometimes the parts are covered under warranty parts only.....check 2nd threw fifth year warranty in owners manual can be almost the cost of a new one if parts aren't under warrantty .... and most top-loaders require a spanner wrench a specialty tool to perform repair.... usualy seal bearing average $60.00 to 120.00 dollars each and around $ 130.00 in labor sometimes more for top loaders and ... frontloaders it usually requires seal rear tub with bearing and spider drum support bearing usually$60.00 rear tub with seal $160.00 an upto $225.00 and spider support $80.00 an up to $160.00 thats just parts we havent even got to labor ..... labor about 2 hours....depends on local rates...
Jan 31, 2011 | Washing Machines
Leaking front sprocket seal
There is nothing else to do but remove the side casing and replace the seal. Hopefully the bearing will not be damaged. Check for play and if you can feel any play, front to back, replace the bearing before the main shaft is shafted!
You may require a manual from emanuals.com for method descriptions.
Dec 29, 2010 | 2008 KTM 450 SX-F
I have lost my mannual for my Rotary Hammer Drill .Hoe can I get a replacement?
Go to Boschtools.com and search under manuals, put in your model. They have them all online
Dec 28, 2010 | Bosch 11265EVS 158 Spline Combination...
Looking for a manual on a masport rota hoe 5 hp briggs and straton. machine is approximately 25 to 30 years old
Your best bet at possibly getting a manual are in the 2nd link below for the rotary hoe.
Phone numbers AU and NZ
http://www.masport.co.nz/CONTACTUS/CustomerServices/tabid/679/Default.aspx
Contact Masaport directly here: (form)
http://www.masport.co.nz/SUPPORT/ImageRequestForm/tabid/664/Default.aspx
You can use the Distributor locator here:
http://www.masport.com/DISTRIBUTORS/DistributorLocator/tabid/182/Default.aspx
There is one site that is a pay site that has ONE resident Masport person. I can not list it here but has outdoorsking in the address. FixYa TOS thing.... (web search!)
As far as any engine manuals. The engine type model and series are stamped into the air shroud not far from the spark plug wire. http://www.briggsandstratton.com Type in your engine model type series and you can download you parts and engine manual.
Thanks for Choosing FixYa.
Kelly
Sep 20, 2010 | Garden
I require a manual for my Honda F90 Rotary Hoe. Where would I find one?
Oct 20, 2009 | Garden
Wheel bearings
dont worry about grease them or that kind of maintenance they are sealed
Sep 24, 2009 | 2003 Kia Rio
How do you change a rear main oil seal in a 2000 toyota celica gt
First of all, be certain that the leak is in fact from that seal. many leaks travel to that area.
To change the seal is fairly involved, you need to pull the trans and flywheel. There are some specialzed tools involved. Do you have manual or automatic? Manual requires clutch plate alignment on re assembly, by the way , if manual, be sure to change the release bearing and pilot bearing at minimum. Commonly it would make sense to change the clutch during this process....you're already all the way in there..
Sep 07, 2009 | 2000 Toyota Celica
Garden Logo
52 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
