Question about Keurig Platinum B70 Coffee Maker
Where is the drain cap on the keurig
How do I get water out of the inner tank of my B60 Keurig?
Turn off and unplug the Keurig brewer. Remove the water reservoir from the machine, empty it into the sink and place aside.
Move the machine to the side of the sink with the back hanging over the sink. Locate the drain cap on the back of the machine, and remove the drain cap.
Empty the water into the sink. Do not tilt the machine more than 90 degrees while emptying to make sure all water drains. Replace the drain cap. Place the machine back on your counter or in storage if you do not plan to use it.
Oct 08, 2014 | Keurig B60 Coffee Maker
Does not fill cup full and take long time to drain into cup
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Sep 20, 2011 | Keurig Platinum B70 Coffee Maker
My Coffee maker is not brewing, and the screen says de-scale. I don't know what to do, I remove the water container, turned it off and back on. I will appreciate your help, thanks Andrea
Step 1: Plug Brewer in and turn power "ON".
Step 2: Pour approximately 64 oz of the vinegar into the Brewer until 4 beeps signal the tank is full.
Step 3: Wait about 6 - 8 minutes for the vinegar to heat up and the green "READY" light to go on.
Step 4: Place a ceramic mug in the Drip Tray and run a brew cycle. DO NOT USE A K-CUP...just press the Brew button.
Step 5: Repeat the brew process 4 or 5 times pouring the contents of the mug back into the Brewer after each cycle.
Step 6: Now let the Brewer stand for 4 hours while still on.
Step 7: Place a ceramic mug on the Drip Tray and run 4 brew cycles, pouring the contents of the mug into the sink after each cycle.
Step 8: Turn the brewer off, let the remaining vinegar cool, and drain the brewer as instructed above.
CAUTION: Vinegar may still be hot. Remember to replace the Drain Cap.
c. RINSE
Step 1: Fill the brewer with hot tap water.
Step 2: Power up brewer.
Step 3: Wait about 6-8 minutes for the water to heat up and the Green "Ready" Light to go on.
Step 4: Place a ceramic mug on the Drip Tray and run a brew cycle.
Step 5: Repeat brew process 4 times for a total of 5 cycles.
Step 6: Drain the brewer as instructed above.
CAUTION: Water may be hot. Remember to replace the Drain Cap.
Step 7: You may need to rinse again to eliminate any residual taste.
http://www.keurig.com/Customer-Service/Brewer-Registration-And-Support/~/media/Files/Keurig%20Brewer%20Manuals/De-scaling_instructions_04_30_2004.ashx
Jun 06, 2011 | Keurig Platinum B70 Coffee Maker
Hi, I descaled the machine and it just wont stop draining. Occasionally it will shut of by itself while draining. thanx
Here is a tip that I wrote that will give you some things to try that will help you get your Keurig coffee brewer working again.
Keurig Coffee Brewer not making a full cup of Coffee
heatman101
May 14, 2011 | Keurig B30 Mini Coffee Maker
It won't drain the water through
heatman101
Apr 30, 2011 | Keurig B60 Coffee Maker
How do I access the inner water reservoir to drain?
3434 Sorry to read about your issue.
their is no inner chamber to drain
you can contact Keurig at 1-866-901-2739 or Keurig.com
You do have a 1 year warranty, and if you are out of warranty. They will give a discount on a new unit.
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Keurig B60 Coffee Maker
Draining the keurig
It can not be drained, ever!
Dec 26, 2008 | Keurig B100 Coffee Maker
Can I hook up a water supply to a Keurig B100 brewer?
The B100 is a pour over unit and the drain is just that.. a drain directly connected to the tank... In order to have plumb feature the machine would need a fill solenoid attached to a float.switch through a circut board of sorts...Hope this helps
Robb
Nov 25, 2008 | Keurig B100 Coffee Maker
Keurig Platinum B70 Coffee Maker Logo
19 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
