Question about RTO Ho Herpa Freightliner Truck Tractor
What does the code eec16 on a freightliner mean
I have a 2013 freightliner. . Cummings eng.. code eng 0... what would this mean?
You would need to contact a Freightliner dealer on this.
May 24, 2017 | Cars & Trucks
What would cause a code 4354 on a 2016 Freightliner Cascadia?
the code means something but only if the engine make , type and transmission make and type is known
Freightliners run 3 different engine and up to 4 different transmissions and the code will be specific to that combination
take it to a freightliner service center and have it fixed
Oct 01, 2016 | Cars & Trucks
What does the #25 code on 1998 freightliner truck mean
I'm not a diesel person. I looked up generic codes for Detroit diesel. Code 25 says, "no codes".
Mar 05, 2015 | Cars & Trucks
I have a Freightliner 2006 A default code is showing up That code is 25 Can you help me figure it out
code 25 says its a clutch slip. it might very well mean that your clutch is slipping or starting to show signs of slippage. have it replaced by a certified mechanic.
Jun 04, 2014 | Cars & Trucks
Freightliner code 128 s254 07
on 2006 freightliner century with 12.7 detroit 60 Error code
eng contreller no resp. 128s254 07.
Apr 26, 2012 | RTO Ho Herpa Freightliner Truck Tractor
What does the code eec 61 on a freightliner mean
A check engine light and fault 61 code is an electrical failure to the injector or a bad solenoid on the injector, but you will most likely find your problem at the terminal crimp.
Nov 11, 2011 | RTO Ho Herpa Freightliner Truck Tractor
Active faults 1 at startup screen
if you press and hold the mode button it should beep then you will get the component location. ecu 128 for example is in the engine- mid 136 is the abs. once you see that, press the mode button again and you will get the code. sid 123 for example- press mode button again and you will get the failure code. FL 02, could indicate when it is reading a high or low reading, short or open... etc. once you have the three parts of this code then you should be able to contact your local dealer to find out what the code means. Truck diagnostics are not always easy... active codes really just give technicians a place to start... hope this helps
Dec 16, 2009 | RTO Ho Herpa Freightliner Truck Tractor
RTO Ho Herpa Freightliner Truck Tractor Logo
22 people viewed this question
Top RTO Toys Experts
Timllfixit
The Scrivener
Pete Bruk
Are you a RTO Toy Expert? Answer questions, earn points and help others
