Question about Electrolux EIDW6105GW 24 in. Built-in Dishwasher
Standing water after rinse and dry
What could be causing this on a new unit?
    President:
  • 2,712 Answers
If the water doesn't drain from your dishwasher, check these:
Drain line/air gap Aclog in the drain line or air gap (if there is one) is the usual reasonthat a dishwasher won't drain. Often the problem is at the point wherethe drain line attaches to the garbage disposer or household drainline. If you remove this line, you can clear any debris from the hoseor hose connection. Be sure to reattach the hose before starting thedishwasher again.
Pump Yourdishwasher pump ejects the water. The pump is usually mounted directlyto the motor, then attached to the bottom of the dishwasher. You canreach the pump from inside the dishwasher, but first you need to removethe lower rack, the spray arm, and the spray arm support.
Lookfor an impeller--a round plastic fan blade-type of device that spinsaround. This is the wash impeller, which forces the water through thespray arm. Beneath the wash impeller is the drain impeller, which issimilar in size and shape to the wash impeller. The drain impellerpushes the water toward the drain port. These components make up thepump. If any of the pump components are defective, you need to replacethem.
Drain valve and/or solenoid Manydishwashers use a drain valve with an electric solenoid. Whenelectricity flows to the solenoid, the valve opens and diverts thewater to the drain. Sometimes the solenoid, or the diverting lever,sticks and prevents the dishwasher from draining or filling properly.Try to free up the solenoid to lubricate the lever. Otherwise, you mayhave to replace the solenoid or pump assembly. With these systems, themotor always rotates in one direction. When it's energized, the drainvalve diverts the water.
Other dishwashers simply reverse thedirection of the motor to drain the dishwasher. These units don't havea drain valve. Instead, there's a drain hose connected directly to thepump housing.
Belt One brand of dishwasher uses a belt to drive the pump. If this belt is broken or has fallen off, replace it.
Motor Ifthe motor isn't turning or working, the unit won't drain. First checkto be sure you have power to the dishwasher. If not, see the section"It doesn't work at all." If the motor hums but doesn't turn, it mayneed to be replaced.
Some dishwashers are susceptible togetting stuck if you don't run them regularly. If you haven't run thedishwasher for more than a week, you may need to manually spin themotor to free it up. If the motor is defective, you need to replace it.Dishwasher motors can't be serviced.
Timer Partof what the timer does is control the motor and drain valve. If thetimer doesn't work properly, the water may not drain and you need toreplace the timer. This problem is uncommon.
Best bet is to contact the shop you bought the unit from if its brand new.
Posted on Jun 23, 2009
My charging unit exploded while charging what can cause that?
Something clearly shorted out inside the charger. To be one the safe side buy a new unit.
Aug 21, 2017 | The Audio Players & Recorders
Changed battery and changed all detectors and they still cherp
Try installing all new batteries. Latest installs have the individual units also hard wired to each other so that when one goes off the others are triggered. When a battery is weak in unit it often causes the main unit to chirp along with some of the others in sympathy. If still no improvement and all batteries are brand new, then either get new units or disconnect the hard wiring between all units.
They will still work but without the nasty global feature.
Dec 22, 2016 | Home
I have a Brother HL 4070 CDW. I have replace the Magenta cartridge but it seems to be spilling ink. When I print in color, the images are not good.
Make sure that the toner cartridges are installed properly.Make sure that the drum unit is installed properly.Make sure that the belt unit is installed properly. Perform the calibration. Adjust the colour by using the custom setting in the driver and by using the control panel. Colours the printer can print and colours you see on a monitor are different. The printer may not be able to reproduce the colours on your monitor. Make sure that you use paper that meets the printer's specifications. Put in a new drum unit.Put in a new belt unit. Check the printer's environment. Conditions such as high humidity and high temperatures may cause this print quality problem.Identify the colour causing the problem and put in a new toner cartridge. If the problem continues, put in a new drum unit. Also visit >>
Image Defect Troubleshooting
Sep 06, 2011 | Brother HL-4070CDW Printer
When using both the FAX and COPY functions of the Canon Laserclass 710 the printed page shows a 2nd "ghosted" image of the primary image about half way down the page. We've tried a few adjustments but the...
Generally, when you have a ghosting problem, the issue is with the fusing unit. If you have a new fusing unit (or if you can get one) install the new unit and the problem should go away.
If you don't have access to a new fuser, you can try replacing the drum/imaging unit. Sometimes a ghosting problem can be caused by a bad cleaning unit (inside the imaging unit), but usually it's the fuser causing the problem.
Aug 31, 2010 | Canon LaserCLASS Fax 710 Printer
When printing backgroud is grey
Causes
Print density setting.
soluitons
The print density may be set too high. Try adjusting the print
density. For details refer to the printer's operation guide.
Causes
Defective drum surface potential.
soluitons
If a drum unit which is known to work normally is available for
check, replace the current drum unit in the printer with the normal one. If the symptom disappears, replace the drum unit with a new one
Causes
Defective main charger unit.
soluitons
Replace the main charger unit
Causes
Defective developing roller (developer
unit).
soluitons
If a developer unit which is known to work normally is available for check, replace the current developer unit in the printer with the normal one. If the symptom disappears, replace the developern unit with a new one
check ifyou want service maual you can send mail to anantakumarjena0@gmail.com
Oct 30, 2009 | Kyocera FS-2000D Laser Printer
How to change bulbs in my 2005 beetle vw
The headlight unit is held in place by a lever located behind each unit in the engine compartment. Some earlier units also had a locking clip. Moving the lever down releases the complete unit that can then be withdrawn out the front of the fender. Note: Road grit and general accumulations of dirt may make this less than smooth. After removing the whole unit the headlamp bulb is accessible by removing the cover at the rear of the unit and removing the bulb. Replace with new halogen bulb - do not touch the glass with bare hands as the oils on your fingers will cause hot spots and cause the bulb to fail. Replacement is the opposite of removal although you may want to clean out the fender opening before replacing the light unit. Lock in place using the locking lever.
Oct 22, 2009 | 2005 Volkswagen New Beetle
WEATHERKING 10AJA4801 BAD COMPRESSOR
You have 10 seer 4 ton unit. A compressor install in my company (4 ton) is about 1400 dollars. Remember when you change compressor you only get a 1 year warranty. A new unit can have as much as 10 year compressor warranty. Amana has a 10 year parts and labor with their unit. The new unit will be 13 seer and you may have to install a TXV inside. You might think about changing the whole system with the new 410A system. Either way a new condensing unit is needed. I have not had anyone just change a compressor in an older unit. Just not cost effective. Get several estimates before you make up your mind. Rus
Jul 04, 2009 | Heating & Cooling
Coil blew up on outside unit, is it better to fix or replace whole unit?
Depends on where the coil is leaking. Also the age of the unit. If it is just a small leak a serviceman can repair it. You have to look at how much it will cost to repair, And the cost of new unit.. The new unit will be a 13 seer and may not match the inside coil. . Also some Companies are selling 10 year parts and labor warranties with new units. Look at the leak on your coil to see what caused the leak. Most of the time it a rubbed line or drier leaking. If you have to cut away fins. Buy another condensing unit. When you cut away the fins you loose heat conductivity. Higher head pressure could cause damage to unit. Rusty
Jun 03, 2009 | Weather King 10AJA6001AH Air Conditioner
Leaks water
The water may be condensation dripping in an area where the catch components are not able to catch it. The largest line that exits the cold coil and ends at the compressor should be insulated without any tubing showing all the way back to the compressor, deficits in the insulation (even small ones) could cause condensation to form and drip.
Mar 09, 2017 | Goldstar DH5010B Dehumidifier
Electrolux EIDW6105GW 24 in. Built-in Dishwasher Logo
358 people viewed this question
Top Electrolux Dishwashers Experts
Mike
Starnley Johnwells
Starnley Johnwells
Are you an Electrolux Dishwasher Expert? Answer questions, earn points and help others
