Question about Boating
Im looking for instructions for my daiwa 1000x baitcasting reel. im not sure how to set different functions for casting. looking for original manual
  • 2976 Answers
SOURCE: Penn Spin Reel will not lock after casting
On the front of the spool there is a device to turn to set the drag. Torn it tighter and tighten it until slightly below the breaking point of your fishing line. It isn't a critical adjustment, it just keeps your line from breaking while trying to land a fish.
Posted on Feb 20, 2009
SOURCE: Quantum Tour Edition 1170PT baitcasting fishing reel
Tighten the drag star to expose the black ratch ring. Press the ratchet ring down towards the star drag as you turn the handle backwards to unscrew it from the crank shaft.
Posted on Apr 16, 2009
  • 16 Answers
SOURCE: I am looking for a user manual for Daiwa Seaborg 500 R or FE
You can download it here:
www.nickzahra.com.br/manuais/SB500Fe.pdf
Posted on Jun 01, 2009
nuworldman
  • 11 Answers
SOURCE: I just recently purchased a shakespear sigma
Baitcast reels are very frustrating to some people. There should be a dial on the side which controls a magnet that keeps it from backlashing make small adjustment and cast also use your thumb to aid in controlling the spool.Then practice practice practice.
Posted on Sep 06, 2009
tbirdfan1
  • 3051 Answers
SOURCE: Is there a manual of
Hello there again i just wanted to know if you are done with the chat session we were having if so could you please give this session a rating for me so i can continue to help otherslike yourself
Best regards Mike
Posted on Dec 07, 2009
Testimonial: "This was a difficult subject and there apparently is not too much information available. I appreciate the effort. Mmorris"
Were freespool clutches incorporated into all of the antique baitcasting reels?
Although the earliest two extant U.S. patents for reels described freespool clutches in the mid-1850s, and many more refined clutches were invented before 1900, the vast majority of baitcasting reels were not equipped with such clutches until after World War II. Reels with clutches were available long before that, but in most casting reels, the spool remained connected to the handle through the gear train during the cast. By 1900, inventors had come up with many different ways of breaking that connection by separating the gears, by separating the gears from the spool, etc. But most reels weren't made with what were often fairly complicated devices.
The first automatic clutches were invented in the early 1890s. These freed the spool as soon as the angler stopped cranking the reel.
May 30, 2018 | Incorporated Fishing
Abu garcia silver max reel manual
those are your magnetic cast control. it is a magnetic braking system. i suggest setting it at "5" and dont adjust unless you are casting into the wind, if that is the case turn it up to towards maximum and keep your casts low to the water and use heavy baits. its a great tool to help eliminate backlash.
Apr 05, 2013 | Abu Garcia Pro Max Baitcast Reel
Howtoseyupaspincastingreel
use 10# test line or heavier. use 3\8 oz lure or heavier. set magnetic control to "5". tighten small silver knob under the reel handle down until the spool will not turn when you push the thumb bar. loosen the same silver knob while you have the thumb bar pushed and adjust the knob tension so that the spool stops turning when the bait hits the ground. this is basic tuning for any baitcasting reel.
Jul 08, 2012 | Abu Garcia Pro Max Baitcast Reel
Cant cast the pinnacle platinum plus lp 100 fishing reel more than 15 feet because the line tangles. Any suggestions?
Sounds like your drag is too loose. Best way to get used to setting a baitcaster, in my opinion, is to put a 1/2 ounce weight on the end of the line and engage the spool. The line should drop to the ground freely, but not full speed - if too fast, the spool will continue to spin and you'll get that dreaded birdsnest. If it doesn't reach the ground, you need to loosen it more. Once you have it set, keep that weight on and go practice, using the thumbing process Parorae noted in the previous answer.
They take some getting used to for sure!
Aug 04, 2010 | Pinnacle Solene SLP10 Baitcast Reel
Boating Logo
303 people viewed this question
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
