Question about EDIsecure ILU Inline Lamination Unit
ERROR 16 NOT PRINTING CORRECTLY - EDIsecure ILU Inline Lamination Unit
Sharp Model MXB401 Error L4-16 what is it and how do i fix it
Hello Joanne,
The error that you are receiving is due to worn gears going to the fuser assembly that need to be replaced!
The repair thread can be read at either link below:
Thread MX B401 L4 16 error
sharp mfp mx b401 error code c4 16
Good Luck!
Rich Lilja
Feb 24, 2015 | Sharp Office Equipment & Supplies
Treadmill error code 16
Precor Error 16, AC Input Voltage Too Low Probable Cause 1. AC input voltage is incorrect.
2. Treadmill operating on undersized AC wiring and/or is drawing high current.
Corrective Action
  1. Verify AC feed into the building's circuit breaker is correct and connected to the proper transformer tap.
  2. The AC wiring must be sized to handle 20 amps of current over the loop length of the AC wiring. Voltage drop across the AC input wiring is a result of the length of the wire run multiplied by the amount of current being demanded by the treadmill. The longer the run and the higher the current the large the wire must be.Verify the unit is connected to an isolated and dedicated 20 amp circuit.
Precor Error 16
Mar 28, 2014 | Precor Exercise & Fitness
Error sc 329
This is for a Ricoh copier. You did not indicate machine.
SC 329: Laser Beam Pitch Adjustment Error
The LD unit home position sensor does not detect an on condition while changing the LD unit position for correcting the LD position or changing the DPI.
Instructions from the Service Manual below...
5.4.3 LASER BEAM PITCH ADJUSTMENT
There are two laser beam pitch adjustment procedures: one for 400 dpi, and one
for 600 dpi. These adjustments use the following SP modes.
· SP2-109-1: Laser Beam Pitch Adjustment - 400 dpi
· SP2-109-2: Laser Beam Pitch Adjustment - 600 dpi
· SP2-109-3: Laser Beam Pitch Initial Setting - 400 dpi
· SP2-109-4: Laser Beam Pitch Initial Setting - 600 dpi
· SP2-902-2, no.12: IPU Test Pattern - Cross Stitch - 400 dpi
· SP2-902-2, no.13: IPU Test Pattern - Cross Stitch - 600 dpi
1. Perform SP2-109-8 (Beam Pitch Data Reset).
2. Input the value for 400 dpi that is printed on the LD unit into SP2-109-1.
Use the value printed after "P" on the new LD unit as shown below.
NOTE: Do not use values printed after a "V".
(These value numbers are on a sticker inside the machine with a UPC code on it. The numbers are just under the UPC barcode. And example number looks like this: "15980300151P: 120, 172", so the example 400 dpi value here is "120".)
3. Press the "Enter" key.
4. Perform SP2-109-3.
5. Print the 400-dpi test pattern onto A3 (11"x17") paper using SP2-902-2 no.12
(cross stitch). (See Service Tables - Test Pattern Printing - Section 4.2.3, pasted below.)
6. Write the value of SP2-109-1 on the test pattern which was input at step 2.
7. Change the value of SP2-109-1 and print another test pattern, repeating steps
2 to 5. Print about 5 patterns with different values for SP2-109-1 (e.g. "48", "96",
"192", "240").
8. Check this test pattern. If the laser beam pitch is not correct, the image looks
like a black vertical stripe pattern.
NOTE: If the laser beam pitch is correct, the vertical stripe is not so noticeable.
If the value is not correct, the vertical stripe pattern is darker.
9. Adjust the laser beam pitch position until the thin lines are of uniform thickness
(no striping effect should appear on the printout), doing steps 2, 3, and 4. (In
step 2, input a value which is estimated to be correct, then do steps 3 and 4,
then if necessary go back to step 2 and try another value.)
10. After adjusting the laser beam pitch for 400 dpi, adjust the laser beam pitch for
600 dpi, using the same procedure as for 400 dpi (use the SP modes for 600
dpi).
4.2.3 TEST PATTERN PRINTING (SP2-902)
NOTE: Do not operate the machine until the test pattern is printed out completely.
Otherwise, an SC may occur.
1. Access the SP mode which contains the test pattern you need.
2. Press exit, then touch the "Copy Mode" key on the operation panel to access
the copy mode display.
3. Select the paper size.
4. Press the "Start" key to print the test pattern.
5. After checking the test pattern, exit copy mode by touching the "SP Mode" key.
Reset the test pattern to 0.
6. Exit the SP mode.
Test Pattern Table (SP2-902-2: Test Pattern Printing - IPU)
No. Test Pattern
0 None
1 Grayscale 1
2 Grayscale 2
3 Grayscale 3
4 Grayscale 4
5 Grayscale 5
6 Vertical Lines (256-greyscale) 13 Cross Stitch (600 dpi)
7 Vertical Lines (1-dot)
8 Vertical Lines (2-dot)
9 Hatch Pattern
10 Cross Pattern
11 Slant Pattern
12 Cross Stitch (400 dpi)
Test Pattern Table (SP2-902-3: Test Pattern Printing - Printing)
No. Test Pattern
0 None
1 Vertical Line (1-dot)
2 Horizontal Line (1-dot)
3 Vertical Line (2 dot)
4 Horizontal Line (2-dot)
5 Grid Pattern (Single-dot)
6 Grid Pattern (Double-dot)
7 Alternating Dot Pattern
8 Full Dot Pattern
9 Black Band
10 Trimming Area
11 Argyle Pattern
12 16 Grayscales (Horizontal)
13 16 Grayscales (Vertical)
14 16 Grayscales (Vert./Hor.)
15 16 Grayscales (Vert./Hor Overlay)
16 Not used
17 Horizontal Line (1-dot)
18 Grid Pattern (Single-dot)
19 Grid Pattern (Double-dot)
20 Alternating Dot Pattern
21 Blank Page
These adjusments listed in the manual require removal of a service panel and mechanical adjustment of the laser mounts, so it should be done by a qualified technician.
However, these test procedures can indicate whether or not this is the problem with your printer.
Sep 05, 2012 | Office Equipment & Supplies
How do I deal with the Check Cartridge U052 message
Solution 1:
  • Remove and replace the cartridges.
Solution 2:
  • Insert new cartridges
Solution 3:
  • Reseat the print head to correct print issues or clear an error.
Solution 4:
  • The print head is broken and it must be changed by a new one.
Source:
http://fix-your-printer.blogspot.com/2010/11/error-u052-on-canon-printers.html
Sep 16, 2011 | Canon PIXMA MP530 All-In-One InkJet...
Error 16 turn printer off
Hi -
The error codes 16 means that you need to check the print head thermistor circuit during power-on. Printer initialization determined that the print head itself is not installed. Some cause of this is again the print head is not installed, the print head built-in thermistor element has failed, carrier cable is disconnected or is already damage, print head temperature detection circuit has failed.
Having said this, it is better to have the printer check by a qualified technician or your local service provider
Hope this helps,
Good Luck!
Feb 28, 2011 | Epson DFX-9000 Matrix Printer
Opened my printer espson dfx 9000 and im getting an error 16 how do i overcome this?
OPENED MY PRINTER EPSON DFX-9000 AM GETTING AN ERROR 16 HOW DO I OVERCOME THIS
Jul 23, 2010 | Epson DFX-9000 Matrix Printer
Making a booklet out of a multi-page PageMaker file
many questions, the answer should be yes and all is in the driver settings but it all depends on if you have the correct driver installed and configured correctly for your copier and if your finisher is a booklet finisher. if you have every thing laid out in page maker correctly and the driver is setup correctly then it should do just fine.
Apr 14, 2010 | Canon imageRUNNER C3170U Color Copier
Not so much a problem but got message printed out while trying to print a document. Unsupported Personality: UNKNOWN. Does this mean something I should be concerned with ??
An error page will print with the words "Unsupported Personality: PCL " in the upper left hand corner. The printers are host-based and do not support PCL printing; therefore, installing an alternate PCL5e or PCL6 printer driver will frequently generate this error condition. NOTE: This error condition occurs by design when an attempt to print with a PCL5e or PCL6 printer driver occurs and is NOT a bug within the product software. SOLUTION: Install the correct HP LaserJet Host-Based Printer Driver or the HP LaserJet printing system software for the product. These drivers are available for download from the HP web site. Click here to go to the HP web site drivers and downloads page. NOTE: There are several programs (such as accounting, invoicing, court documentation applications) that are 16 bit (DOS) programs with a 32 bit (Windows) overlay. Due to the nature of these applications and the associated Windows overlay, the errors may continue with the correct printer drivers. These applications do not typically support a host-based output device, and as such would not be supported in these environments.
Feb 24, 2010 | HP LaserJet M1522n MultiFunction Printer
Error u2
Press #, Interrupt, C, Interrupt. Enter 16 print.
Dec 02, 2009 | Sharp AR-5320 Black and White Copier
HP Color LaserJet 2550N. Slow printing takes 16
http://www.hp.com/#Support
Follow the link and get the correct driver and get installed
Jun 30, 2009 | HP LaserJet 2550n Printer
EDIsecure ILU Inline Lamination Unit Logo
81 people viewed this question
Top EDIsecure Office Equipment & Supplies Experts
jasbo
jasbo
Are you an EDIsecure Office Equipment and Supply Expert? Answer questions, earn points and help others
