Question about Golden Technologies Companion II Travel Scooter
GTCompanion 2 Three wheel Gc340
Scooter won't run. Key switch is loose. Everything else turns on.
Green ready light on Pride Sonic three wheel scooter wont turn on. What turns it on?
Hi if it is similar to pride x the circuit will shut down if key is left on for 20 minutes u will still have lights. Remove key for a short time then replace it & turn on ..goood luck
Jan 21, 2016 | Pride Sonic 3 Wheel Portable Scooter
How do I fix Jordan scooter that wont start
Hi, Anje and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty jiffy stand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and downloads that you will need please visit the websites below. Good luck and have nice a day.Scooter Troubleshooting Scooter won start All about Scooters Scooter won start
http://www.sym-center.ru/files/jet-all.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Jan 15, 2016 | Jordan Motorcycles
What does the 7 beep code mean on my Pride Victory 10 scooter mean when I turn the key on ?
This is a speed pot or throttle control problem (wig-wag) have you had some speed issues with the scooter before this happened, if so the wig-wag needs replacing. Make sure it is in the centre position at rest and switch the scooter on again.
Jul 11, 2014 | Pride Mobility Products Pride Victory 10 -...
What is the main cause of un passing electric to start
Hi, Bijualexander and the usual suspects are:
5. Security alarm needs a reset.
6. Starter control circuit, relay, or solenoid faulty.
7. Faulty starter button.
8. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue, please visit the websites below. Good luck and have nice a day.
50CC Scooter Wont start
How To Fix Scooter Starting Issues Part 1 Quick Guide
The Ultimate GY6 Starter Ignition Troubleshooting Tutorial
50cc scooter wont start need help
Scooter won start
Apr 26, 2014 | Bajaj Motorcycles
Starter not turning with charged battery atlantis derby 100
Hi, Anonymous and the usual suspects are:
For more information about your issue and valuable free downloads that you will need please visit the websites below. Good luck and have nice a day.
Scooter won start up any ideas Tilted Forum Project Discussion Community
Scooter won turn over
http://www.49ccscoot.com/manuals/Derbi_Scooter_Manual.pdf
https://www.oemmotorparts.com/oem2.asp?M=derbi
http://www.derbi.com/fr/images/stories/modelos/37/manual.pdf
Dec 01, 2013 | 2006 Derbi Atlantis City 100
My engines cannot turn on to power,
Hi, Dennis and the usual suspects are:
Startup Troubleshooting Starting Your Scooter 1 7
Scooter won start DOWNLOAD BAJAJ CT 100 SERVICE MANUAL
http://www.marutibajaj.com/pdf/ct100.pdf
Bajaj Auto Ct 100 2015 User Manual
Nov 23, 2013 | Bajaj CT 100 Motorcycles
No ignition
Hi, Futeballmom and the usual suspects are:
Fix Chinese 49cc Scooter that won start
CPI motorcycle manuals
CPI Scooter Parts Racing Planet USA
CPI Oliver 50 2004
Jul 24, 2012 | 2005 Cpi Oliver 50
Baja sc50-2 scooter
Hi, Benny and the usual suspects are:
Scooter won start
Baja Panterra 50 90cc PDF Service Manual Downloads on 4Strokes com Forums
http://www.bajamotorsports.com/system/documents/63_OWNERS_MANUAL_-_SC50_-_Sun_City_50cc_Scooter_Owners_Manual_VIN_prefix_LAWA_.pdf
Feb 13, 2012 | Bajaj Caliber 115 Motorcycles
Golden Technologies Companion II Travel Scooter Logo
Top Golden Technologies Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Golden Technologies Health and Beauty Expert? Answer questions, earn points and help others
