Question about BaByliss 74466BU
How to remove trimmer head from troybuilt tb80ec trimmer
Troy-bilt TB80EC won't start
Check for fuel and fire and start eliminating systems.
Aug 30, 2014 | Garden
Troybuilt tb80ec wont start
If you didn't over winter the engine properly it could be several things. Start with replacing the fuel filter. If it still won't start... time to put in a carburator kit. Next time make sure you run your weed eater dry and spray some wd-40 or the like into the spark plug hole.
Jun 02, 2014 | Troy-Bilt 27cc 2-Cycle Straight-Shaft Gas...
Troy-built tb80ec will only run in half choke position
Reality. Place unit in trash. Every post about this model has same gripe. After short usage it: 1) only runs on half choke. 2) won't start after getting hot 3) has inaccessible fuel adjustment other than idle.
The unit is crap.
Feb 08, 2012 | Troy Garden
I have a Troy Built weed trimmer Model TB80EC. Is there a repair/operators manual available depicting how to change the string on the spool? Thanks.
There indeed is an owners manual for your trimmer. It will include other information as well. You can find a copy of it here. You will need to give your model number and serial number to get it.
http://manuals.mtdproducts.com/mtd/Public.do?BrandCode=10001&langId=-1
May 01, 2011 | Garden
The head on my troybuilt weedeater TB70SS stopped spinning at higher RPMs. It will spin at real low RPMs. Help please?
if it is cable driven, if the shaft is curved it a cable , the cable is broken.
if it is a straight shaft with a gear box the gears are probably stripped
Nov 02, 2009 | Troy Bilt Tb70ss Gas Trimmer
What oil do I put in my 4-stroke Troybuilt weed trimmer?
According to troybuilt, here's their info.
For Briggs & Stratton engines use an SAE30 oil above 40 degrees F (4 C) and below this temperature use 5W-30.
For Tecumseh engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30.
For Kohler L-Head engines use an SAE30 oil above 32 degrees F (0 C) and below this temperature use 5W-30. For Kohler Overhead Valve engines use a 10W-30 above 0 degree F (-18 C), and below this temperature use a 5W-30.
For Honda engines,10W-30 is recommended for general use, and above 55 degrees F (10 C) you can use an SAE 30.
For MTD Brand engines, SAE 10W-30 is recommended for general, all-temperature use.
K
May 25, 2009 | Troy Bilt Tb425cs 26cc 4 - Cycle Curved -...
BaByliss 74466BU Logo
Top BaByliss Health & Beauty Experts
NOEL
NOEL
ray gallant
Tom Chichester
Are you a BaByliss Health and Beauty Expert? Answer questions, earn points and help others
