Question about Kenmore Elite HE3 Steam 8674 Dryer
Dryer only working when I hold button down. Beeping noise
The
  • 11,896 Answers
There is three possibilities that I can think of that could be wrong:
Short in switch
Failure on washer's brain or circuit board.
It should give you an error code. If you don't have one, it may just be a faulty start switch.
Posted on Jun 23, 2009
How do I stop my washing machine door alarm beeping?
do this and fix it. God bless you
However read the instr. manual section troubleshooting /
if doesnot have download from www.fitness.manualsonline.com
The processes below will get most controls unlocked.
Duet Washer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Whirlpool Duet Dryer - Press and hold the END OF CYCLE SIGNAL button for 15 seconds.
Kenmore Elite Washer - Press and hold the DRAIN/SPIN button for 15 seconds.
Some Models- Press and hold the control lock button for 15 seconds.
If none of these work try unplugging for 5 minutes
Sep 28, 2012 | Hotpoint WMA74 Front Load Washer
My gas dryer is a whirlpool LGR4634eq0. Timer starts but when I press the power button i hear a load noise( like a stuck hinge) and the dryer wont start. Help
The power button is usually called a "start" button. For as long as you hold it down, it provides power to the motor. When the motor gets up to speed, centrifugal force holds the switch closed for you. This is why a quick (short) opening of the door will not stop the dryer and a quick press of the start button will not start the dryer.
This, however, does not explain the noise...
The motor turns a belt which wraps (sort of) around a pulley which is on a spring (and also around the drum). The spring should hold tension on the belt, but the belt should not be so resistive (drum refuse to turn) to cause the tensioner to strike anything.
Can you turn the drum by hand?
The drum rides on two wheels. They should roll smoothly.
:o).
Jun 04, 2011 | Maytag Neptune MDG5500AW Gas Dryer
Cycle Signal keeps beeping loud-soft every 15 seconds while dryin
Hi Celine, I just experienced the same exact problem. I came here looking for a solution. I got mine to stop by holding down the cycle signal button for 3 seconds, releasing it for three seconds, and repeating until both lights (loud and soft) went off. Hope it helps.
peter
Apr 21, 2010 | Kenmore Elite Oasis 6808 Electric Dryer
Amana Dryer will not work,will not stay on,makes funny noises
during the process of moving your dryer, it sounds like the drum became dislodged. With the dryer off, open the door and try to move the drum by hand, if it sounds like something is 'dragging' them the drum is off its bearings. IF it is, the quickest way to get help to take it apart is go online to youtub, type in your dryers name and model number and ask how to replace drum
Apr 27, 2017 | Maytag MDE2706 Electric Dryer
Dryer has a beeping noise
sounds like your touch panel or main control
Dec 01, 2008 | Kenmore 63942 Dryer
My dryer keeps beeping after 30seconds of turning it on. I have pressed the 'LOCK' key to unlock & even then it still does the beeping thing! Could this be the motherboard packing up?
I had the same problem. My wife was about to take an axe to the darn thing. The frustrating thing was that it was beeping 3 times and the status lights were flashing. The manual only described 4 beeps (Dryer ran too long) or 6 beeps (Push button does not function). It finally dawned on me that it was beeping two sets of three beeps (i.e 6 beeps). The corrective action was to press buttons lightly and release. I pressed on every button first lightly then heavily with no success. I pounded on the instrument panel; still no luck. Finally I pressed the Options button and the Select button simultaneously for a second and heard a click. After that, no more beeping. According to the manual this activates a "LOCK' feature if you hold them down long enough. But in my case, the lock light flashed but didn't engage and after the beeping stopped, I left well enough alone.
Hope this helps.
Jun 22, 2008 | Dryers
Kenmore Elite HE3
replace the power control board
Jan 21, 2008 | Kenmore 82822 Electric Dryer
Beeping dryer
You should open the service panel and to find out where does the "beeping" unit located and to remove one of the wires connected to it (the unplugged wire should be insulated). Good luck!
Aug 20, 2007 | Miele Novotronic T230C Electric Dryer
Kenmore Elite HE3 Steam 8674 Dryer Logo
116 people viewed this question
Top Kenmore Dryers Experts
Sal De
Tim Whalen
Marvin
Marvin
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
