Question about Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven
How to fix frigidaire wall oven beeping error message f11
  • Official Brand Answer
  • 2,267 Answers
Good Morning Friend,
I understand that your Frigidaire wall oven is beeping and showing an F11 error code. Typically an F11 error code states that there is a shorted key, or a button has been detected as pressed for a long time. I suggest hard resetting your appliance, by cutting the power at your homes circuit breaker for 3-5 minutes. While you are resetting your oven, make sure to wipe down the control panel. The panel is very sensitive and could be detecting something that has splashed or spilled onto it, even dust. When you bring power back to your appliance you will need to start by setting the clock. Turn your oven on any cycle at any temperature. If you are still receiving an F11 error code, I suggest contacting your local authorized technician for further assistance. Hope this is helpful.
-Best Regards-
WP
Posted on May 16, 2014
  • 338 Answers
SOURCE: Error F3 on display ovens beeps
the temperature probr is located inside your oven in one of the upper corners. it should be a round stick looking piece. some are removed from the front others are removed from the back.
Posted on Nov 26, 2008
  • 130 Answers
SOURCE: Frigidaire Wall Oven
It is telling you that your oven has an issue. Check your owners manual for the fault code definitions. If you have a model number I may be able to find it for you.
Posted on Jan 26, 2009
  • 107 Answers
SOURCE: Frigidaire gas wall oven clock unit sometimes says F1 and beeps.
F-1 is USUALLY a touch pad error, it thiniks something is stuck. The sensor error code is F-3.
Posted on Mar 17, 2009
  • 56 Answers
SOURCE: i have a frigidaire model cfeb786jgb3 error
f1 is a watchdog on the control board
replace control
Posted on Jun 30, 2009
fixyourboard
  • 310 Answers
SOURCE: frigidaire oven f9 code
Here's the info from the service manual:
"Fault Code: F9
Likely Failure Condition/Cause:
1. Door motor failure / jammed. Latch
motor switch failure.
2. Control software failure, or component
failure (relay stuck).
3. Wiring Problem.
Suggested Corrective Action:
1. Press CLEAR key.
2. If CLEAR key does not eliminate problem, turn off power for
30 seconds, then turn on power.
3. Check wiring of Lock Motor, and Lock Switch A and Door
Switch circuits.
4. Unplug P4, apply power (L1) directly to the Lock Motor, if the
motor does not rotate, replace Lock Motor Assembly. Plug
P4.
5. Check Lock Switch A for proper operation (do they open and
close, check with ohmmeter). The Lock Motor may be
powered as in above step to open and close Lock Switch. If
the Lock Switch is defective, replace Motor Lock Assembly.
6. If all above steps fail to correct situation, replace control."
- www.fixyourboard.com
Posted on Jul 25, 2009
Dr error message
Hello Herb Reinhart - If the range previously displayed DR and now showing F11, it typically indicates that the unit has detected a shorted keypad. Since you have already try resetting the unit by unplugging it and issue persists, I would recommend contacting a professional to proceed further. Most likely the EOC on the range will need replacing.
Apr 09, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I get a F11 code with beeping noise and the oven controls won't work? what can i do?
Hi Ken Kazemi - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if it proves to be ineffective contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Feb 03, 2013 | Frigidaire 30" Self-Cleaning Freestanding...
I have a double frigidaire oven and i am using the self cleaning and i am getting an err f11 and it just keeps beeping, it will not let me cancel
Unfortunately, an F11 error indicates a short at the keypad. Try unplugging the oven and waiting a minute before restoring the power. If that resets the error, great.
Otherwise, you need to replace parts. Please add a comment with the model number for specific information. Most likely, you need to replace the electronic control unit (clock). However, this error can be a sign of a damaged wiring harness or the secondary control panel in the oven.
If the oven door is locked, you may be able to temporarily unlock it by accessing the switch controlled by the door lock motor. You will need to unplug the oven and pull it out. Then take off the back panel to reach the switch.
I hope this helps. Again please add a comment with the oven model for more assistance.
Dec 10, 2012 | Frigidaire Ovens
Frigidaire oven won't work. top range works fine, but digital clock and digital display stopped working which works oven, so oven also will not work f11 code
Hello steve o - Typically error code F11 indicates a shorted keypad. Try resetting the range by unplugging it or flipping the household circuit breaker off. This usually will clear most false error codes. Wait approximately ten minutes and if the error code does not clear contact a professional to move forward accurately. Most likely the EOC on the range will need replacing.
Nov 12, 2012 | Frigidaire 30" Self-Cleaning Freestanding...
F8 error and bottom door locked
Here is Frigidaire's suggestion to your problem:
Oven Control Beeps
and Displays an "F"
Error Code
Electronic control has detected a fault condition. Push CANCEL pad to clear the display
and stop the display from beeping. Reprogram the oven. If a fault reoccurs, record the fault
number, push the CANCEL pad and contact an authorized servicer.
Jul 26, 2011 | Frigidaire 30 in. Electric Gallery Series...
Mar 17, 2009 | Frigidaire 24" Built-In Single Gas Wall...
Nov 26, 2008 | Frigidaire 24" Built-in Single Electric...
F 11 ERROR KEEP BEEPING
F11 - usually associated problems with the key pad. Shorted or otherwise malfunctioning. If power is disconnected from the unit for about 30 - 45 seconds and then reapplied and the problem still exists changing the EOC is recommended
Sep 03, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Frigidaire 30 in. Electric Gallery Series Self-Cleaning Double Wall Oven Logo
464 people viewed this question
Top Frigidaire Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
ashburton
Are you a Frigidaire Oven Expert? Answer questions, earn points and help others
