Question about Canon Pixma MX922
Canon fax hangs up normal phone calls
Canon fax disconnects line during normal voice calls
old marine
  • 2148 Answers
SOURCE: I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Posted on Oct 16, 2008
rhoncruz
  • 134 Answers
SOURCE: Canon MP530 receive fax issues
Receive Mode Settings Select from the following receive mode options to suit your needs. Once you've decided on which receive mode to use, follow the below instructions to set the receive mode using the operation panel. Receive Mode Setting
  1. Press the <FAX> button to enter Fax mode.
  2. Press <Menu>.
  3. Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
  4. Press the up or down arrow to select the receive mode that best suits your needs, then press <OK>.
Types of receive mode
Select the receive mode according to your needs.
Receive mode
Purpose
FAX/TEL AUTO SW When you want to receive faxes automatically as well as voice calls. FAX ONLY MODE When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only. DRPD When you have subscribed to a DRPD service with your telephone company. MANUAL MODE When you receive mainly voice calls and sometimes faxes, or want to receive faxes manually. ANS.MACHINE MODE When you want to receive voice messages on your answering machine and receive faxes automatically. FAX/TEL auto switch
FAX :
The machine does not ring but will receive the fax automatically. Voice call :
The phone attached to the machine will ring. Pick up the handset to answer the call. Note:
  • Ring start timing and Telephone ring length can be specified in FAX/TEL auto switch in the Receive mode settings.
  • If you want the telephone to ring when it receives a fax, connect a telephone to your machine and enable the Incoming ring settings in RX settings.
  • The phone attached to the machine may not ring depending on the telephone type you are using.
FAX only
FAX * :
The telephone does not ring. The machine will receive the fax automatically. Voice call :
You will not be able to answer the call. * If you want the telephone to ring, connect the telephone to your machine and enable the Incoming ring settings in RX settings menu.
DRPD
FAX :
Your telephone line will ring according to the ring pattern you have chosen and receive the fax automatically. Voice call :
Your telephone line will ring according to the ring pattern you have chosen. Pick up the handset to answer the call. Note: Specify the FAX pattern in the DRPD: Set FAX ring pat. in RX settings menu.
Manual RX
FAX :
The telephone attached to the machine will ring. Pick up the handset and if you hear a beep tone, press the <Color> or <Black> button on the machine to receive the fax. Voice call :
The telephone attached to the machine will ring. Pick up the handset to answer the call. Note: If you are far from your machine, you can use the remote receiving function to receive faxes. Pick up the handset of the telephone connected to the machine and press 25 (the remote receiving ID).
Ans. machine connect
FAX :
First the answering machine connected to your machine will respond to an incoming call, and then the machine will receive faxes automatically. Voice call :
The answering machine connected to your machine will respond to an incoming call. Note:
  • Set the answering machine to answer on the first or second ring.
  • The entire message should be no longer than 15
Posted on Dec 01, 2008
  • 159 Answers
SOURCE: I can't send faxes on my Canon Pixma MP530 on digital phone line
They're telling you your hardward doesn't play nice with their hardware. A few suggestions:
Update your printer, and see if any improvement is found:
http://www.usa.canon.com/consumer/controller?act=ModelInfoAct&fcategoryid=123&modelid=13371#DownloadDetailAct
If that doesn't work, see if your computer has a fax modem that itself can be updated and can support the hardware. Your multifunction printer has a scanner; you can scan in the things you want to fax, then fax from the computer if the computer can fax. This is starting to look like a Dr. Seuss book.
You can also try to learn more about what the problems are and look elsewhere. Your "digital" phone is actually voice over Internet, something VOIP. If you Google for VOIP FAX you'll find some information, like this:
http://www.3cx.com/PBX/FAX-VOIP.html
Posted on Dec 05, 2008
  • 3 Answers
SOURCE: Unable to complete fax transmissions
The Analog line for your fax machine works best with a Trapezoidal Wave Form, but the line coming out of your adapter is Sinusoidal. Call Vonage support, get transfer to tech support and let them know you need a fax specialist, who will then update your account and change the waveform to Trapezoidal. That's how I got my HP Office 7860 Pro to work.
Posted on Jan 17, 2009
old marine
  • 2148 Answers
SOURCE: Canon L120 fax, Hang up the Phone message
Make sure that the phone line coming from the wall jack is inserted in the port with the "L" next to it (I think it's the bottom of the three). If you put it in the port with the picture of the phone next to it (which is for an extension phone or answering machine), the L120 thinks that the receiver is off the hook of the extension phone.
Posted on Jun 11, 2009
Cant receive faxes. constant busy signal when dialing in.
Hi Janet
Try using a standard phone to call your Fax Line
Connect a phone to this Line to test for voice
Disconnect Fax Machine from Phone Line
Reset Fax machine
The Fax machine is supposed to respond to the right tones being sent down the voice line
If it is not responding & all else works then check your Fax settings for "Receiving"
Nov 30, 2015 | Panasonic UF-5500 Fax Machine
Canon mf5770 not receiving faxes
Most fax machines allow you to set the number of times the phone rings before it automatically answers the phone. So if you phone goes to voice mail after 4 rings and the fax machine is set to start the fax after the 5th ring it will never receive the faxes because the call went to voice mail. Good Luck
Dec 05, 2013 | Office Equipment & Supplies
I need to stop a fax that is coming through on a canon laser class 510
Put a phone on the line and hang the call up. Disconnecting the phone line from the fax machine alone may cancel the call.
May 05, 2011 | Canon LaserCLASS 510 Printer
Good day! I have a Canon MX-328. I was expecting to receive a fax so I read the manual and I set my printer to Tel priority mode since we only have one phone line mostly for voice calls. According to...
Hello.
You have explained your question with very good detail
Press the colour button, then hang up. Most faxes are capable of transmitting colour faxes, and you should press the colour because even if the sender sends a B&W Fax, it will Automatically receive it in B&W. If they send a colour fax and you hit the B&W Button, it will only receive in B&W.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community
Regards GM
Apr 25, 2011 | Canon PIXMA MX300 All-in-One Printer
I have a canon mx410 all in one inkjet printer.i need assistance with setting up the fax to a phone line. Thank you Zainy
  • Call your phone company to sign up for service. Ask for an additional line with a "distinctive ring." The additional line is for your fax machine---whenever you hear the distinctive ring you'll know that a fax is coming through. Get voice mail service on the regular phone line as well.
    Purchase a two-jack phone splitter (sometimes called a wall jack adapter) that allows two cords to plug into the same phone line. Plug it into the phone jack in your wall.
  • Run a phone cord from both machines into the wall adapter. Test the system by calling both your regular phone number (assure it rings and the voice mail picks up) and your fax number to see if the fax machine picks up (you'll hear a set of strange beeping tones).
  • Apr 13, 2011 | Canon Pixma MX410 All-In-One Printer
    How can I get the telephone on my Brother Fax T96 to work?
    Step by step information at the link below.
    Brother Fax T96
    The F/T Mode is used to allow the fax machine and the telephones to share the same telephone line. When a call comes in, the fax machine and all extension telephones on that line will ring according to the number of rings you have set for the Ring Delay.
    When the Ring Delay is completed, the fax machine will answer the call and determine if it is a fax call or a telephone (voice) call.
    The fax machine can determine this by the signal it is receiving on the telephone line. If someone is sending a fax automatically , the sending fax machine will transmit a fax tone (a series of beeps every 3 seconds).
    If your fax machine hears these tones, it will receive the fax.
    If the fax machine does not hear any fax tones, it assumes it is a telephone (voice) call and will begin ringing the F/T ring tones (double ring) for the length of time you selected for the F/T Ring Time. These tones will only ring on the fax machine's handset (extension or external phones will not ring). At the end of the F/T ring time the fax machine will go into the receive mode in order to receive a manual fax.
    (If the call was a voice call and was not answered, the caller will hear the fax receive tones also).
    • If you answer the call before the fax machine(during the ring delay period) and determine it is a fax, you can transfer the fax to the fax machine for receiving.
    • If you answer the call on an "extension" phone and hear a beep every 3 seconds (automatic fax) or silence (manual fax), press *51 or *91 for New Zealand (remote activation code) on the telephone keypad, wait to hear the fax machine turn on (chirping sounds) and then hang up.
    • If you answer on the handset of the fax machine and hear a beep every 3 seconds or silence, press the Fax Start or Start/Copy key on the control panel of the fax machine and then hang up the handset.
    • If you answer a call on an "extension" phone during the F/T Ring Time, you will hear the F/T ring tones.
      To release the call from the fax machine, press #51 or #91 for New Zealand (remote deactivation code) on the telephone keypad and you can speak to the calling party.
    • If you pick up the handset of the fax machine during the F/T ring time, you may talk to the calling party immediately.
    Mar 28, 2011 | Office Equipment & Supplies
    What do I buy to use 2line phone and separate fax?
    You can buy a 2 line phone, but to use the fax/dsl line for voice, you will also need a line sharing device.
    "The stick" is a good brand....
    All it does is recognize if an incoming call is a fax or a voice call. If fax it would go to a fax port on the stick. If voice, it comes out the voice port which you can call on.
    The same rules apply to this line....if something is using it, the next call will get busy......But now you could have the phone company "Hunt" your line 1 to line 2 (fax/dsl) if line 1 is busy.......hence...2 incoming lines....
    Apr 14, 2009 | RCA 25201RE1 Corded Phone
    Canon image class MF4150 distinctive ring
    How to Set the Receive Mode (MF4140/MF4150)
    1. Press [Additional Functions]. 2. Use [Left cursor] or [Right cursor] to select [FAX SETTINGS], then press [OK]. 3. Use [Left cursor] or [Right cursor] to select [RX SETTINGS], then press [OK]. 4. Use [Left cursor] or [Right cursor] to select [RX MODE], then press [OK]. 5. Use [Left cursor] or [Right cursor] to select the receive mode, then press [OK]. [FaxOnly]: Answers all calls as faxes and disconnects voice calls. [AnsMode]: Receives faxes automatically and records voice messages. [NET SWITCH]: Distinguishes between fax and voice calls. [FaxTel]: Switches between fax and voice calls automatically. [MANUAL]: Does not answer any calls. You have to manually receive faxes. NOTE: a. For [FaxTel] or [MANUAL], make sure the optional handset or an external telephone is connected to the machine. b. For [AnsMode], make sure an answering machine is connected to the machine. c. The [NET SWITCH] mode is available for certain countries only and requires subscription to a network switch service. 6. Press [Stop/Reset] to return to the standby mode.
    Aug 12, 2008 | Canon imageCLASS MF4150 All-In-One Laser...
    Auto-answer issue: fax beeps on line when voicecall received
    Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
    Mar 27, 2008 | Office Equipment & Supplies
    Disconnection of computor to wirless modem when fax / phone hand held is activated
    try to change the option for enabling the auto line transfer to handphone on pickup
    (if the disconnection occurs during ur data transfer/FAX/voice call, this is usual..dont worry)
    bye
    Was my tip helpful?
    Feb 11, 2008 | Panasonic KX-FPG175 Plain Paper Thermal...
    Canon Pixma MX922 Logo
    107 people viewed this question
    old marine
    old marine
