Question about Mtd Garden
I have a 38" deck yard machines(MTD) lawn tractor. When I raise the lever to disengage the blades, the blades still keep turning. Does anyone know how to fix this problem?
  • 1 Big Guy Sep 26, 2014
    Blade engagement is controlled by belt and pulley system. Check for proper belt size and that a pulley tension spring has not broken.
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 140 Answers
If they are slow to stop,thats ok if they don't ever stop thats an issue,the brake shoes that drag on the top of the blade spindles are worn out or not adjusted correctly !
Posted on Sep 21, 2014
  • 57 Answers
SOURCE: Craftsman 42" mower deck won't disengage
Try pulling on the cable coming down to deck. This cable might be your problem. Also check that the spring on the end of this cable is present and functional.
Posted on May 19, 2009
SOURCE: MTD Lawn Tractor: Constantly shredding deck belt...
I have the exact same model MTD tractor with same problem. It began when the bolt that extends through the idler arm assembly broke and subsequently damaged the pulley. Upon examination of the broken bolt, I found that the threaded end that extends below the deck is significantly smaller that the rest of the bolt. I got a larger bolt with the same size threads, bored out the hole through the deck and it made the whole idler assembly much stronger. the deck still has some vibration and some unusual belt harmonics, but it appears to be working. Compared to most other tractors of this size, this deck is very complicated.
Posted on Jun 15, 2009
  • 41 Answers
SOURCE: yard man mtd 20hp 46
go to the online web site for the yardman this will give you the guide on how to replace the belt.
Posted on Jul 12, 2009
  • 148 Answers
SOURCE: Blades won't disengage
When the mower is off and the clutch is disengaged you should not be able to physically turn the blade(s) if you can then you need to adjust the blade brake (look on the mower deck and you should see what appears to be a brake pad). Your owners manual will show you how to adjust. If you need a copy of the owners manual then I would suggest going to www.managemyhome.com and downloading a free copy of the manual for your mower (Need model number which starts is located under the seat).
Posted on Jul 27, 2009
  • 143 Answers
SOURCE: mtd yard bug model - 198707 riding lawn mower blade belt size?
I dont know the belt size but if you go to mtd belts in Jackssmallengines.com you should find it. Stephen.
Posted on Aug 23, 2009
Where is the safety switch to engage the blade
Your lawn tractor will have a lever that raises and lowers the mower deck which houses the two cutting blades. By lowering your mower deck to the desired cutting height, the blades should automatically engage. By raising the deck back to it's highest position, the blades will automatically disengage. Should be simple enough. You can consult your mower manual. If you don't have one, you can easily find it online using the make, model and year of the lawn tractor.
Jul 08, 2014 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Blades keep running in all gears on my mtd 420/38
Assuming you have put the blade drive lever into 'disengage' check the blade drive belt tension. With blade disengaged, belt should have significant slack. You may need to adjust the control cable, adjustment is usually on the mower deck; or you may have some debris on the deck preventing the pully to release belt tension
Jun 26, 2014 | Garden
MTD stops running when trying to engage the blades
unhook clutch at the clutch wire plug see if the blades stop turning then ativate the switch to see if it stops it dosnt bad clutch
Jun 01, 2013 | Yard Machines MTD Gold 20 HP Lawn Tractor ...
My MTD 14hp lawn tractor (38", 6 speed) shuts of
You have a short somewhere . A cut or stripped wire that , at the time of lowering your deck, touches the body. It's like turning off your key. Look around under your deck and you will find what I'm talking about. Fix wire and tie up to prevent future problems. GOOD LUCK.
Jun 16, 2011 | Yard Machines MTD Gold 20 HP Lawn Tractor...
Pulley is hitting mower deck when raised to the stop position all i did was change the blades all brackets are installed in the same holes,what gives?
Hi, re check your hanging bracket positions if it was ok before changing blades as been incorrect will cause the deck to travel to far when disengaging the blades, regards Phil
May 10, 2011 | Mtd 46" Dozer Blade, Fits All & Yard -...
I have a Yard Machine Gold 22 h.p. 8 speed with a 46" deck. Where can I find an online manual that will show me how to remove the deck step by step?
lower deck remove belt from engine disconnect any hangars connecting deck to tractor raise deck lever pull out deck reverse prosess to install
Aug 01, 2010 | Yard Machines MTD Gold 23 HP Garden...
My riding lawnmower blades will not disengage or engage Now my lawn mower will not start
just replaced some pulleys on my craftsman 42 inch cut and now the blades are ingages all the time, but it will start
Jul 17, 2010 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
Blades rotate on tractor when new belt was put on
be sure you have the correct belt for that mower?
Even though your deck is raised to disengage the
belt it may need to go up a small amount more,try pulling back on the deck raise handle to see if that helps,and find a way to keep it at that higher point if that worked or run the new belt for awhile and see if that makes a difference.
Check the belt guards to see if they are close to the belt as possible while engaged,but not hitting the belt
and when disengaged guards should be hitting the belt somewhat to help keep it from turning.
and yes be sure you have good belt brake pads and know they have good tension and hitting in the proper place
May 05, 2010 | Garden
Yard Machine tractor drive deck belt failure
i need a diagram of tensioner springs on yard machine deck 1998 42inch
Aug 11, 2009 | Yard Machines Red Edger
Engine Pulley 660 MTD Yard Machines
make sure the narrow side of the belt goes in the pulley; you may have the wrong belt; make sure all the pulleys for that belt are the same height , if one is higher than the others that may be the problem
Jun 12, 2009 | Mtd 46" Dozer Blade, Fits All & Yard -...
Garden Logo
121 people viewed this question
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
