Question about Canon Pixma MX922
Canon fax hangs up on phone calls
Hangs up phone calls
3 Suggested Answers
old marine
  • 1992 Answers
SOURCE: I can send faxes, but not receive them on Canon Pixma mx310
Do you have the phone you are answering with connected through the fax machine? If you have the machine set in 'tel priority' mode, the machine will not begin receiving a fax until you press 'FAX' and the 'color' or 'black' button. Alternatively, if you have your phone connected to the 'telephone' jack on the machine (next to the 'L' jack), you can press '2' and '5' on the telephone keypad to turn the machine on in fax receive mode.
Posted on Oct 16, 2008
old marine
  • 1992 Answers
SOURCE: Canon L120 fax, Hang up the Phone message
Make sure that the phone line coming from the wall jack is inserted in the port with the "L" next to it (I think it's the bottom of the three). If you put it in the port with the picture of the phone next to it (which is for an extension phone or answering machine), the L120 thinks that the receiver is off the hook of the extension phone.
Posted on Jun 11, 2009
I need to stop a fax that is coming through on a canon laser class 510
Put a phone on the line and hang the call up. Disconnecting the phone line from the fax machine alone may cancel the call.
May 05, 2011 | Canon LaserCLASS 510 Printer
Good day! I have a Canon MX-328. I was expecting to receive a fax so I read the manual and I set my printer to Tel priority mode since we only have one phone line mostly for voice calls. According to...
Hello.
You have explained your question with very good detail
Press the colour button, then hang up. Most faxes are capable of transmitting colour faxes, and you should press the colour because even if the sender sends a B&W Fax, it will Automatically receive it in B&W. If they send a colour fax and you hit the B&W Button, it will only receive in B&W.
I hope this helps, if so please rate this answer below Thank You for supporting the FixYa Community
Regards GM
Apr 25, 2011 | Canon PIXMA MX300 All-in-One Printer
Jun 11, 2009 | Canon L120 Fax Laser Printer
Display ''line in use''
This is a fairly easy repair IF you have electronics knowledge. There is a small relay on the input of the phone line within the fax machine. It is a common problem to have the relay "hang". If you can locate a suitable replacement relay, I am confident that this will cure the problem.
Apr 06, 2009 | Office Equipment & Supplies
Faxing
Normal 0 Sending Fax Using Calling Card:
Load document in the ADF
Press [FAX]
Adjust settings for your documents as necessary
Press [Hook] Alternatively, you can lift the handset if one is connected to the machine.
Dial your calling card information responding to all calling card prompts on the fax key pad. After dialing the recipient’s number using the numeric keys or speed dialing, wait for the high-pitched fax signal.
When you hear a highpitched signal, press [Black} for black & white sending.. Hang up the handset if you used it.
Oct 18, 2008 | Canon PIXMA MP780 All-In-One InkJet...
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
Canon Fax JX200 - fax interupts phone calls
Canon Support suggest changing the Remote RX code or turning off remote RX.
Goto fax settings -> RX settings-> remote RX
Nov 22, 2007 | Canon FAX-JX200
Incoming telephone calls
Refer to your manual. It may be under RX(recieve settings). Go disable FAX/Tel SW and make sure it is fax mode only
Jan 11, 2007 | Canon FAX-B820 Plain Paper Bubblejet
Canon Pixma MX922 Logo
22 people viewed this question
old marine
old marine
