Question about Honda Garden
I have a Honda HRR216VKAA selfpropelled mower and have had to replace the left rear wheel gear 3 times do to wear from the gear slipping. This is most notable on the side of a hill where the left whe
I've also replaced the rear wheels so all of the gears have been new but the mower will "clatter" on the left rear wheel as the gear seems to wear down from this and it just gets worse! Any suggestions would be appreciated.
2 Suggested Answers
ryanplex
  • 57 Answers
SOURCE: Replaced both rear wheels +gears
Sounds like when you replaced the wheels you did something wrong and now they are unleveled.
Posted on Aug 24, 2011
Poulan pro lawn mower will start with pull. Will NOT start with KEY
Take key switch out and look for damaged or broken parts or replace switch.They will come with new key.
Jun 11, 2016 | Poulan Pro 22inch 625 Series Briggs ...
Selfpropelled portion stopped working, replaced broken belt,have correct p/n for new belt,belt is slack ,self propelled not working
There should be 3 pulleys one on the motor on top of the blade, one on the axle for the wheels and one that goes to your cable to engage that pully and tighten the belt, take the cover off that hides the axle and pull your handle for the self propell and see if its tighting, some mowers have a little adjuster to tighten the cable on the self propell handle or even on the cable itself, did you make sure to run the belt between the guides over the blade, let me know what you find so we can further help
May 15, 2016 | Troy-Bilt 12AVB29Q711 TB260 21-Inch 160cc...
Hit a stump with lawnmower, now wont start
You may have sheared the flywheel key. This throws the timing off. If the shaft isn't bent replace the key.
Jun 22, 2014 | Poulan Pro 22inch 625 Series Briggs ...
Self propelled JS63 Deere Lawn Mower Transmission is driving axle but rear wheels act like they are slipping. It seems like gears on end of axle are not engaging the drive gear on the inside hub of...
some times you can add a thin shim to the out side of the wheel mounting center to push the wheel gentally a little more to the drive gear for more positive engagement to the wheels inside gearing, also check your gear drive mounting pins/ keys for wear if thier warn it will engage the end of the drive shaft iradically appearing as slipping type movment at the wheel hope this Helps Steve
Aug 01, 2010 | Garden
I have replaced the transmission assy. on my toro selfpropelled; the problem I have is I can only get one side to work at a time. With no wheels installed, both of the gears on the front drive spin in the...
Many TORO mowers have a drive pinion that can be used on either side, however, internally, they ratchet one direction, drive the other direction. You may want to rotate (reverse) the installation of one gear and try it.
Nov 08, 2009 | Toro Lawn Mower With Toro Power Tools
Self propelled lawnmower seems to be out of alignment
depending on the model the wheels sometimes have a ring gear assembly inside each wheel the parts/diagram for your mower can be found at: searspartsdirect.com
Aug 21, 2009 | Garden
What is causing slipping of rear right wheel on
most likely the gears that are inside the wheel hubs.
Jul 09, 2009 | Garden
Rear wheel drive on mower does not engage
Its possible that the cable slipped does the pulley turn on top of trans.if so does the shaft turn if so then your gears on wheels need cleaned or replaced.
May 09, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
26 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
