Question about Sportcraft Tx350 Treadmill Motor Speed Controller Board Fh-3511c Circuit Control
Need to order a control board
Sportcraft tx350 mortor control board
I am not sure they carry these boards but most certainly worth a call is Allied Electronics. If they don't have one I know they will steer you the right direction.
May 14, 2014 | Sportcraft Tx350 Treadmill Motor Speed...
Motor Control Board
go to www. fitnessrepairsparts.com and get it.
God bless you
Jun 11, 2013 | Sportcraft Tx5.0 Tx 5.0 Rc Treadmill Motor...
I have a sportcraft tx 2.5 and was cleaning it and some water got into the housing where the motor and circuit board is located. Now all I get is the number 7 on the display and it won't run.
Dear Sir:
1) Please unplug the machine
2) Put with air gum machine, and pass in all board and circuit for heating.NOT OVERHEATING.
3) Wait for 24 hours. if you have some infrared lamps, will be better.NOT OVER EXPOSED.
4) Turn ON the machine, and proof, if the problem remain, the board is faulty. and replace.
5) However try to RUN the software calibration for better diagnose, troubleshooting, and fix it. see the block diagram attached.
God bless you
Jun 09, 2012 | Sportcraft Tx2.5 Tx 2.5 Treadmill Motor...
My sport craft arcade hoops with electronic score board is not turning on
I have problem with Sportcraft basketball arcade hoops control box. When I press on buttons on, play, up and down, some it responds, but most of the time it is not responding. Where do I get the control box list, diagram, and where to buy toggle switch?
Thanks,
May 27, 2012 | Sportcraft Arcade Hoops With Electronic...
I have a TX350 sportcraft treadmill, works great, but shocks our hands everytime we use it and we lost the user manual when we moved a few years ago. ?
I am not a fitness expert but I did want to pass along a few resources in case they may be useful. Here is a parts list for the TX350, and here you can search for treadmill repair companies in case you need to have someone in your area take a look at it. Hopefully you can find a solution without needing to spend money on repairs, though.
Mar 14, 2011 | Sport & Outdoor - Others
Have a sportcraft tx350 treadmill and it won't stay on one speed. It speeds up.
I have a TX350 sportcraft treadmill and I keep getting shocked when I use it. How can I stop it ? I no longer have the user manual for it either. Can I get one ?
Feb 25, 2010 | Exercise & Fitness
Sportcraft Turbo Hockey table will not power up
The customer service is somewhat oblivious to their inventory and products they sell. But, if your table is not pushing the puck, call and order a new fan (easy swap out). Also, you may use a small pin and poke each air-hole as dust accumulates and clogs system (do not use a wax or polish, only damp soft cloth)
The control box is the interface to power scoreboard.(kids pushed the transformer cord in too hard and separated the circuitry panel inside CB). I am in process of replacing mine, model number 34090, part number 34090HG08, $5.00+ SH
There are comparable control box modules for similar turbo hockey games, Atomizer, which uses a similar control box that you can swap circuitry out to your old box. (Very simple, even a cave man can do it..hah). The key is the ability to put control box back together once you disassemble inerts. (The "flip" mechanism is so shoddy it never goes back together right)
Good luck with Sportcraft and their disposable $500-600.00 air hockey tables which have a lifespan of parts of less than 5 yrs!
Nov 17, 2008 | Fat Cat 7' Air Hockey Table
Sportcraft Tx350 Treadmill Motor Speed Controller Board Fh-3511c Circuit Control Logo
18 people viewed this question
Top Sportcraft Exercise & Fitness Experts
John
Are you a Sportcraft Exercise and Fitnes Expert? Answer questions, earn points and help others
