Question about Samsung 5.1 Channel Blu Ray Home Theater System - HT-H5500W/ZA
How unlock ht-h5500w ? - Samsung 5.1 Channel Blu Ray Home Theater System - HT-H5500W/ZA
How to unlock a Samsung 5.1CH Blu-ray Home Entertainment System HT-H5500W to play diferente DVD area codes
1. Turn off then on again, without a disk in the drive and wait for the graphical menu to appear.
2. Open the tray and close it again (still empty).
3. "No disk" will display on the TV at upper left.
4. The timing here is very critical. When "no disk" disappears, (don't jump the gun, wait for it to definitely disappear) hit REPEAT 76884 quickly. I found that pressing every half second or so just did not work; it had to be fast.
5. If this works, "4" will display top left. Press and hold the 9 key briefly. If OK, "9" will display instead of "4". If not, back to 2. There is no need to repeat 1.
6. Turn off then on again.
If this doesn't work (very likely), vary the critical timing in 4, the brief time between "no disk" disappearing and hitting the keys and the keying speed. Be persistent, it may take many goes. Be fired up by knowing that success is one in the eye for Samsung who are completely unhelpful and say it cannot be done.
The above was taken from this forum:
http://forums.whirlpool.net.au/forum-replies.cfm?t=2111916#r6
This was
Dec 28, 2015 | Samsung Audio Players & Recorders
Each time when turn off and turn on the player, it lost all the user settings (preset FM channels, speaker DB level settings etc).
All the settings are stored in a special microchip that requires a feed of power (often a few volts only) when the mains power is off. Normally this is done by what is called a Memory Retention Capacitor. This stores a voltage that feeds the chip. Unfortunately these have a tendency to sometimes fail. Leaving no power. It can be easily replaced once you found it. They look a bit like an electrolytic capacitor, but a funny looking one. They are generally low value in capacitance and very low voltage.
I'm including an image of one. If you find one that looks like it replace it and the memory stations will only have to be done once more and they will be saved.
It's unlikely they will have used a battery like those found in computers for this.
Nov 15, 2015 | Samsung HT-H5500W Home Theater System
Unlock region for aiwa ht-dv1
HI
press and hold the child lock button until it beeps...
Thank you
Dec 22, 2008 | Aiwa HT-DV1 System
I want unlock my samsung HT-TZ212 to multi region
Aug 09, 2008 | Samsung DVD-V90K Multisystem DVD/VCR
Samsung ht tz315 unlock code
i JUST tried the unlock to multi region for my samsung ht-tz315 and it didn't work does anyone have a crack for this please. thks
the code was
Turn On player with remote
Press Enter on the remote
Press 8, 4, 2, 6 and 9 on the remote
The player will power Off
Switch On power from remote
does not work
Aug 01, 2008 | Televison & Video
Region Unlock Code
Go to http;//www.dvdcity.com/codefree/instructions.html maybe there you find an answer.good luck
Jul 04, 2008 | Samsung HT-DS140 System
Samsung HT x20 region code
For Samsung HT-X20 the region code unlock listed workd perfectly. Just hit 8,4,2,6,9 then ENTER (do this twice) and it will play your DVD which it did not before.
Abe
May 11, 2008 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung 5.1 Channel Blu Ray Home Theater System - HT-H5500W/ZA Logo
155 people viewed this question
Top Samsung Audio Players & Recorders Experts
Electro Med Services...
Electric Dime
Electric Dime
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
