My Hampton Bay 12,000 btu A/C when used for the first time this year has a loud noise/vibration when the compressor is on. Quiet when fan only. Is compressor going bad or might something be loose? This unit is wall mounted.HBT120A
  • 10,515 Answers
This means that it's a time to change "COMPRESSOR".
Hope i helped you.
Thanks for using "Fixya".
Posted on Jun 23, 2009
Hampton Bay Window A/C HBQ051A: What is BTU? And, no, obviously it's not posted on the unit, nor do I have any documentation.
First, I'm not a Hampton Bay Tech.
I found this on you tube 6,000 BTU?
*** Following for information only ***
https://www.youtube.com/watch?v=KnNFQGBySlI
https://www.youtube.com/watch?v=7TNy7HpF9zg
https://www.youtube.com/watch?v=XT8BJGvbnZg
* Normally I would suggest checking your warranty but this is a discontinued A/C unit. May not be worth repairing as there are newer units more power and less electrical usage.
Aloha, ukeboy57
Jun 18, 2018 | Hampton Bay Heating & Cooling
We bought a Hampton Bay fan model ALTURA 56 inchs. Since a year we have a noise came from the motor. Wath is the best way to fix this situation.Thank you!! Guy
If you are using a dimmer switch get rid of it and get a FAN control. Also, you can check the capacitor to see if it's going bad. Hampton Bay is just a low-end store brand for Home depot. You get what you pay for.
Mar 30, 2015 | Hampton Bay Dryers
52 inch ceiling fan hampton bay--Humming..... Tightened blades,adjusted fan blades, changed to a new wall switch, blade to ceiling height O.K.... still humms, what can I do??? thank you
Sounds like you have covered all the bases already, but there is the small possibility that it is the housing vibrating. You can remove it and buffer the adjoining parts with electrical tape on the inside (so as to be hidden). Otherwise, you have a fan that hums (many just do). May need to exchange for a known quiet model like a Hunter or Panasonic.
Farmerbear at FixYa.com
Oct 01, 2010 | Hampton Bay 24002 Ceiling Fan
2 of my hampton bay ceiling fans stopped turning-one that was installed 6 years ago and one that was installed 2 months ago. I can hear the motor vibrating when it is turned on. Do I need to replace the...
mcdevito75 here, On the fan you hear, carefully turn the blades by hand just a little and see if they start up on there own. These motors are sealed units and maybe the oil is a little thick from non-use. If the baldes don:t start up, Then I would replace the fans.
Jul 26, 2010 | Hampton Bay 24002 Ceiling Fan
Wobbly ceiling fan
Make sure the blades are not loose.
Jun 11, 2017 | Hampton Bay HL52QV-P-3LC14 Brass Landmark...
There is a humming noise coming from fan no matter what speed it is on. I have run the fan for hours and still humming
The key to a quiet fan is to isolate the motor vibration from all other parts. This occurs, in the majority of fans, in three places: between the motor and the blade brackets, between the blade brackets and the blades, and between the downrod/motor flange and the mounting bracket. Some fans also have vibration-isolating material between the mounting bracket and the ceiling. If your fan makes a noticable humming noise, inspect it for the above mentioned types of vibration-isolating material. With the exception of the rubber flywheel, if your fan is lacking any of the above, they are easy to add and should solve the majority of humming problems. You can always add additional material as rubber washers and spacers are readily available.
Jun 09, 2010 | Hampton Bay 52 In.Carriage House II in...
Hampton Bay fan bearing noise
its not the bearings sounds like you need to level the mount and that scraping it the fan blade mounting plate hitting the side of the 'case' that surrounds the motor assembly ive never heard of bearings in the motor going or needing lubrication other than what factory placed in them...remember Hampton Bay is the Yugo of electric appliances too
Aug 03, 2009 | Hampton Bay 24002 Ceiling Fan
Loud bang, sounds like the motors going to drop out when the compresser kicks on,17 years old, relpace/repair
The actual internal motor in the compressor dome is mounted on springs. Over time these get weak and hence the loud bang noise when the motor hits the sidewall of the compressor housing. It is not too serious and will probably work for ages. Just anoying. Leave it until it really packs up.
May 04, 2009 | Heating & Cooling
Hampton bay fan makes squeeking noise
If the fan is fairly new, remove it and return it to Home Depot. It is almost certainly something that has fallen down into the motor and is rubbing loudly enough to make a squeak as the fan runs faster.
The fan itself has sealed lubrication and you don't have to lubricate it.
Apr 07, 2009 | Hampton Bay 24750 Huntington III Ceiling...
Heating & Cooling Logo
176 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Mack Baxter
Marvin
Marvin
