Question about Zanussi F1045W Front Load Washer
Belt broken on my wdt1085 washing machine.
How to fit new belt
  • 31 Answers
Also if its hard to get the belt on put it round the mortor and tie rap it to the spider wheel then turn till the belt is on.DONT FORGET TO CUT THE TIE RAP OFF<zip tie>
Posted on Jul 03, 2009
  • 57 Answers
Take off back plate to washer, wrap belt round motor and spider (6 legged wheel above the motor) and turn the spider thats it
Posted on Jun 23, 2009
Hoover 2305l washing machine grinds and locks up
First remove the belt and spin the motor it may be motor bearings if this checks ok then the gears in your transmission are meshing which means you will have to fit a new transmission.
Aug 03, 2012 | GE Washing Machines
I have a Hotpoint Ultima WT761 Washing machine. The belt has not broken but is damaged and the edge is stripping off. It has come off the drum and motor spindle. Clearly its time to get a new one which I...
not absolutely sure of your exact model, but most washer belts on put on by putting them on the motor the stretching to the tub pulley and holding it there while you move the pulley which then stretches the belt to fit for you.
May 05, 2017 | Washing Machines
How do i fit a new belt in the washing machine
Hello,unplug appliance, remove lid and back plate, place belt on motor and carefully on drum pulley, turn pulley to pull belt onto its, its quite tight to do but is possible, watch out for trapping your fingers.
Thanks
May 21, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Fitting new belt
Remove top cover and lower rear panel of washer
With some help, tilt washer forward, and fit belt round motor pulley first,slowly ease belt onto drum pulley and feed slowly round, turning pulley at same time, it will be very tight, so watch your fingers, you can align the belt after it is fitted. Please rate my solution.
Thanks.
Aug 19, 2009 | Washing Machines
How to fit a door seal on zanussi washer dryer WDT 1085
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Feb 10, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Removing/replacing main drum bearing on a zanussi WDT1085
Yes you do need to remove the drum, it entails stripping the washer down, and it is normal practice to replace the complete drum half with the bearings pre-fitted..
It is not a job to undertake, unless you feel competent to do do it, as it entails al ot of work and time..
Good luck if you decide to proceed.
Plz rate my suggestions.
.Thanks.
Jan 03, 2009 | Zanussi WJS1265W Front Load Washer/Dryer
Washer stuck
i am assuming that water comes in at the start of cycle and machine does not then progress. Points to a timer fault unfortunately. These timers are expensive and quite hard to fit. don't recommend repair in view of age of appliance.
honestly can't see how related to sock problem
Jun 26, 2008 | Washing Machines
FITTING NEW BELT ON ZANUSSI WASHUNG MACHINE F1045W
It is'nt any adjustment on those machines. They were fitted with eleastic belts. Is the belt not tight enough, you need a new belt.
Jan 23, 2008 | Zanussi F1045W Front Load Washer
Zanussi F1045W Front Load Washer Logo
221 people viewed this question
Top Zanussi Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
