Question about Pentair Minimax NT Heater
Mini max my power light comes on but my pressure sw does not light up
  • Pentair Master
  • 1,631 Answers
Try cleaning the filter, or check the water flow. It's sensing not enough water flow through your system.
Posted on Apr 05, 2015
3 Suggested Answers
  • 10865 Answers
SOURCE: My pool heater will not start. The power light is off and the pressure sw is lit.
You must turn on the pump and let water circulate through the pool and the heater before you turn on the heater otherwise you will ruin the heater
Posted on Apr 16, 2009
john224
  • 1378 Answers
SOURCE: Only the pressure sw light
The indicator light means your pressure switch is not closing therefore the heater will not fire. It can be as simple as cleaning your filter to clear the error and get the heater running again. If the filter cleaning still doesn't solve the issue then the switch itself has likely failed and needs to be replaced. Jump the lead wires coming to it to verify the switch is bad. If the wires jumped together gets the heater going, replace the switch.
John
Posted on Sep 08, 2011
The overhead light between the driver and passenger won't come on where do I find power for this light
Your instrument cluster light dimmer switch if turned to max, will click on the roof light..Some cars also have overhead light disable sw near light control panel. Also door sw around door where it closes
May 15, 2017 | Cars & Trucks
2011 mini cooper countryman, starts, runs, drives but has low power.(50 mph ) max Due for service in 1200 miles.
The only way to correctly diagnose what is going on is to have a diagnostic scan done, sounds like the pcm has gone into 'limp home' mode which restricts power to prevent damage to the powertrain
Feb 15, 2015 | 2011 Mini Cooper Countryman
Turn off service light
What exactly is the heater doing. You turn on the filter pump, flip the switch on the heater, does it turn on? Does the board light up?
Jul 18, 2014 | Mini Max 100 Above Ground Heater
Pentair Mini max my power light comes on but my pressure sw does not light up
if pressure switch does not light that means no pressure either water flow or a bad pressure switch you can jump the wires on the pressure switch but be very carefull if it does start make sure it does not bang or make noises
May 14, 2014 | Pentair Minimax NT Heater
Why does my pressure light not come on on my mini max pool heater
Sensing not enough water flow, most common problem, dirty filter.
Keurig b31 mini. Power light on, brew light not on
Water reservoir may not be seated properly or filled above the Max line. Did you do a purge and establish filling the hot water reservoir?
Feb 08, 2013 | Keurig B30 Mini Coffee Maker
Only the pressure sw light is on. No other lights come on. Cycled on off switch and circuit breakers, yet still only pressure sw light comes on
John
Sep 08, 2011 | Pentair Minimax NT Heater
E03 error code
Error Codes
f01 light 4, motor triac
f02 light 3 motor, jammed/ tacho
f03 lights 3&4 Ntc fault
f04 light 2. pressure sw stuck on empty
f05 lights 2&4, pressure sw stuck on full
f06 lights 2&3, N/A?
f07 lights 2&3&4 heater relay
f08 light 1. heater relay
f09 lights 1&4 eprom/setup error
f10 lights 1&3, pressure switch not sensing
f11 lights 1&3&4, pump/draining error
f12 lights 1&2, communication error
f13 lights 1&2&4, dryer ntc/ fan motor
f14 lights 1&2&3, dryer heater
f15 lights 1&2&3&4, dryer heater relay
f16 N/A
f17 light 4, door lock
f18 light 3 comms error (3 phase motor) power board
Aug 09, 2010 | Siemens WTXD8300 Electric Dryer
I have a Mini Max 100 pool heater. The pilot
check pressure switch for proper adjustment and make sure filter is clean so system pressure is normal
Jun 07, 2009 | Pentair MiniMax 100 Aboveground 100,000...
Apr 16, 2009 | Pentair Minimax NT Heater
Pentair Minimax NT Heater Logo
136 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
