Question about Fujitsu Computers & Internet
How master slave DVD jumper - Fujitsu Computers & Internet
Beni S-P
  • 1006 Answers
SOURCE: jumper settings
Here you have MANUAL'S
Posted on Mar 24, 2008
Psionics
  • 236 Answers
SOURCE: how to tell which jumper is master and which is slave
Master is 7-8 (the 2 furthest from the power connector)
Slave is no jumpers selected
Here is a manual for your model for reference:
http://www.seagate.com/support/disc/iguides/ata/cuda7200ig.pdf
Posted on Mar 28, 2008
SOURCE: need a jumper diagram
quantum 30gig
Posted on Jun 26, 2008
SOURCE: I have a quantum fireball 20.4 gig drive where do the jumpers
There is normally a sticker on the drive, which indictates the settings.
Posted on Jan 04, 2009
  • 3 Answers
SOURCE: Master slave jumper settings on 250gb Maxline Plus II SATA
There are no master/slave settings on SATA drives because each drive has its own cable. The drive order is determined by what SATA port they are plugged into, or by the BIOS configuration.
Posted on Sep 04, 2009
How do I set the jumpers to make it a slave?
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
note the plastic jumper is ' located at the rear of the hard drive next to the IDE/SATA lead/s
Sep 10, 2011 | Hitachi Computers & Internet
Cant get burner to reconised on pc
Since this is an IDE drive, please check the Master/Slave/Cable Select jumpers, if you've connected the drive in the same cable of your hard drive, you should check its jumper settings, if hard drive is set as Master, the DVD writer it should be as Slave, if the hard disk jumper is set to Cable Select (CS), the DVD should be in the same way too. After this check if DVD drive is identified correctly in BIOS, it's a good idea to set drive detection as Auto, if this all is OK, check its driver in Windows, it must be appear as a DVD-RW drive.
Mar 03, 2011 | LG GH22NP21 DVD-Writer - Internal...
Computer will not detect dvd burner
Is the drive powering up . Is the light on the front of the drive always on.If always on the cable would be put in upside down change either on motherboard's side or on the drive. Is your drive a SATA or IDE. If IDE and the drive is sharing a cable with another drive or HDD then you will have to set the master/slave jumper found behind the drive. Look behind the drive and you will see a jumper with more connectors.
Generally there are three options C/s,Master,Slave. Removing the jumper completely also makes the drive a slave. Make sure the other drive is slave or master and appropriately change on this drive. IF HDD ( Hard disk) is master make this one slave or vice versa. Now windows should be able to find the drive.
Jan 15, 2011 | Mad Dog Multimedia (MC-12XDVDRW-SE)...
HP a1250Ncomputer wont boot up.
OK, ONE DVD MUST be set as MASTER and ONE as SLAVE. The master MUST be on the "End" of the cable, the SLAVE, on the other. First try with ONE drive, and if you get it working, swap them out too at first, then after establishing that it works OK with just One, the MASTER, then introduce the SLAVE. Do Not forget to RE-JUMPER between swap outs.
May 20, 2010 | HP Pavilion a1250n (EG194AA) PC Desktop
I would like to make this a slave so that my 500 GB PATA HardDrive will be the master as that has my operating system and the Plextor PX-716A drive will be the slave?
You need to configure the jumper at the back of the drive as shown in the following picture
Configure the CD/DVD drive as slave, configure the hard drive as Master.
Mar 13, 2010 | Plextor PX-716A (PX716ASW) DVD±RW...
Need IDE jumber settings.
There is a little jumper block on the rear of a DVD. by IDE connector. on the case above there will be a Table marked . Master: Slave: CS. Now, you must set the jumper as to your drive's position. IE: Master or Slave, Master is on the plug at the END of the ribbon, the Slave is on the "Other" one. Accordingly the Master has the Master Jumper ON, the Slave the Slave Jumper ON. CS is Cable Select. It isn't all that used.
Feb 11, 2010 | Plextor 52x32x52 PX-230A Internal CD-RW...
PC will not see Maxtor 80GB DiamondMax Plus 9 as seconary slave.
Two thing,
First, never use a Maxtor HDD as a slave to a CDROM/DVD, doesn't work and tends to cause stability issues. So try swapping the jumper on the CD/DVD to slave and setting the Maxtor to Master, this should get it working.
Second, if it is showing up as 33GB, you have the Jumpers set to limit capacity(designed to avoid troubles on older systems. If this is the case, you likely have a single jumper in the center row of pins between the power and data cables. If it only works as master at the moment, then you likely have the neter row(limit size pins) and the one closest to the data cable(Master Pin) both plugged in.
Change your DVD/CD to slave, remove the limiting jumper and ensure the Master jumper is installed on the Maxtor, then be sure the end connector on the ATA(likely marked master) is plugged into the Maxtor and the middle connector(Slave) is plugged into the DVD/CD, this should have you all fixed up.
Hope this helps FixYa,
Chris
May 19, 2009 | Maxtor DiamondMax Plus 9 80 GB Hard Drive
Jumpers
You can only have TWO (2) Devices in IDE - Master and Slave.
For example
Cable 1 (ide channel 1)
Master - HDD
Slave - Tape Drive
Cable 2(ide channel 2)
Master - CD/DVD drive
Slave - HDD
Do you have a diffrent type of cable?
Oct 08, 2008 | HP DDS-4 20/40GB (c5683-00255) DAT Tape...
How to install second internal hard drive
Yes, you can use, Please see label attached to the harddrive for a jumper setting to become primary harddrive.
in the DVD rom there's also a label on it. but the most common setting is slave is in the center.
C S M -
c-cable select
s-Slave
M- Master
the jumper is set to center to become a slave.
the hard drive is should be a master
connecting to the other end of the IDE cable.
HDD-should be a master
DVD rom-Should be a slave
Hope this help.
Feb 19, 2008 | Acer Aspireā„¢ T180 PC Desktop
Dvd drive
Typically the master/slave setting is done with jumpers on the back of the drive. Look at the connection at the back and look for markings for Master and Slave. If you have the manual, that will tell you too.
Feb 19, 2008 | Computers & Internet
Computers & Internet Logo
57 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
