Question about VXI Corporation Blueparrott B250-XT Bluetooth Headset
Flashing red won't connect to phone
Blue parrott B-250 XT continuous red flashing won't connect to phone
4 Suggested Answers
ponnykazi
  • 69 Answers
SOURCE: I purchased my blue
U should charge it for short time
Posted on Jan 29, 2011
SOURCE: my blue parrot b 250 xt keeps loosing bluetooth
Clear your headset out of your phone then repair it to your phone. You do thieving by clearing it from your phone then turn your phone off for about 30 sec then turn it back on and then clear your hradset by holding down both the volume up &down bottoms on the headset for 5-6 seconds you will heat a double beep. Them you are ready to repair it.
Posted on Oct 31, 2011
SOURCE: parrot bluetooth b250 xt alternating red and green flashing lights
While device is on hold both volume buttons for 6 seconds till you hear 2 tones. Then plug in factory supplied charger for 10 seconds. Unplug a d re-pair to your device
Posted on Nov 27, 2012
My iPhone 4 will pair with a blue parrott b250 xt but the Bluetooth link won't stay connected. It drops then reconnects drops then reconnects. How can I fix this problem?
You could try closing everything non vital on the iPhone to make its job easier or mabye it a power issue with the headset. A) even rechargeable batteries have a lifespan, B) you got a bad one so try keeping the power connected to the headset while you pair it. 10_25_2013_12_17_40_pm.png
Sep 08, 2013 | Cell Phones
How do sync with my new phone?
1. You must start with the headset in the OFF position. Put the headset in pairing mode by Pressing and holding the Multi-Function Button until the lights are flashing alternating Red and Blue, you will then release the Multi-Function Button. Please note the headset will continue flashing Red and Blue until the paring cycle times out (approximately 2 minutes) or completes the paring with the cell phone. If you only press and release the Multi-Function Button the headset will not go into the paring mode.
2. Once the headset is in paring mode, go to the Bluetooth menu / connections of your cell phone. Select add new / search for / find new device (different phones have different but similar names for the options). The cell phone should find a device called VXi B250-XT. Move the cursor over the VXi B250-XT and press (OK, select, enter, or whatever your phone uses for a prompt). If the cell phone asks for a passkey code you will put in 0000 (four zero's). The headset will then pair and connect to the cell phone and be blinking Blue once every second. Your phone may ask you if you want to connect to the B250-XT and/or add it to your trusted device list, press (OK, select, enter, or whatever your phone uses for a prompt).
Aug 01, 2011 | VXI Corporation Blueparrott B250-XT...
What is the pairing security code for xx3 plantronics
The following are detail instructions on how to Pair (sync) a Plantronics Bluetooth Headset to your Bluetooth Cell Phone:
1 - You need to go into the device you wish to pair it and turn the Bluetooth feature first.
2 - Then you need to place the headset in pairing mode so your phone will find it.
Find your model headset in the instructions below. Once the headset is in "Pairing" mode you will then need to follow the instructions in your cell phone or Bluetooth device's user guide on how to go it to your phone and search for the headset & pair it to a Bluetooth headset.
The passkey is 0000 (4 Zeros) except models M1000 and M1500 (see below for their number )
For the Plantronics M3000/M3500 (discontinued):
Pressing and holding down the volume up key and the talk button at the same time. Hold them in together until the indicator light on the headset starts flashing red then green.
For the Plantronics 510 Voyager:
Pressing and holding down the call control button and holding down the volume up at the same time until the indicator light on the headset starts flashing red then blue.
Plantronics Explorer 320,330,340 & 350
Begin with the headset turned off. Press and hold down the silver call control button in for 6-10 seconds. The light will flash blue first. Continue to hold the button down then release the button when the indicator light starts flashing red then blue.
Plantronics 655, 665
Plantronics Discovery 640, 645, 640e
Plantronics Pulsar 590/590e & 590A & a Bluetooth device:
Begin with the headset turned off. Press and hold the call control button then power the headset on and when the indicator light flashes red and blue, release the call control button. Once the headset is paired successfully the headset will flash blue.
pulsaradapter.jpgFor the Plantronics Pulsar 590 & 590A & the Universal Adapter: Begin with the headset turned off. Press and hold the call control button. Power the headset on and when the indicator light flashes red and blue, release the call control button. Turn the Universal Adapter on. Press and hold the adapter pairing/connect button for 7-10 seconds. When adapter starts flashing red and blue release the buttons. The headset and adapter will flash blue when paired successfully.
pulsar_260_128.jpgPlantronics Pulsar 260
For the Plantronics Pulsar 260, Begin with pendant powered on.
Press and hold both the mute/play/pause button and the power on/off/pairing button simultaneously. When the
indicator light flashes red and blue, release buttons. While pendant is flashing red and blue, use the phone menu to search for Bluetooth devices and select "260 Plantronics." When prompted for passkey,
enter 0000.
For the Plantronics M2500 (discontinued):
Start with the headset powered on. Press and hold down the call control button while also rotating the multi function dial upward (away from the light) until the indicator light on the headset starts flashing red then green. When prompted for passkey, enter 0000.
For the Plantronics M1000 (discontinued):
Hit and hold the volume/mute switch in until the indication light starts blinking.
For the Plantronics M1500 & A500 adapter (discontinued): Turn the headset on and the adapter off. On the headset push in and hold the mute/volume dial until the indicator light begins to flash. On the adapter press and hold the blue power button for 10 seconds. The light on the adapter will flash once after 3 seconds- continue to hold the power button for another-7 seconds until the light flashes red. If the pairing is successful, the headset will sound a tone and both the headset and adapter lights will turn off.
For both the Plantronics M1000/M1500 (discontinued): If you remove the battery cover from the headset and then remove the battery itself. On the Green PC board itself there will be a letter followed by 4 numbers. These 4 numbers are your personal PIN code.
You can also use the Plantronics Bluetooth Pairing Guide
Feb 05, 2011 | Cell Phones
How do you put blue parrott B250--XP in discovery mode.
From the power off position, switch the unit on by holding the function button for 3 seconds. Keep holding the function button until the indicator light on the function button flashes red and blue in an alternating pattern. The unit should now be in discovery mode and ready to pair with another device..
Aug 03, 2010 | VXI Corporation Blueparrott B250-XT...
Cant hear on my blue parrot headset. it was working fine then just stopped. its showing that my phone and headset is connected.
try this: have both on but not in use,plug the charger in for 10 secs only then unplug, watch lites go from red to blue then flashing just blue at a rate of 1x per second. that resets it. worked for me.i called the company
May 17, 2010 | VXI Corporation Blueparrott B250-XT...
Lost the instructions to my blueparrot b250xt, how do i pair it to my cell phone
Good day... You may find the users guide on the following web site.
www.blueparrott.com/pdfs/202711B_B250XTUserGuide.pdf or visit the VXi web site at www.vxicorp.com, go to the support tab (new window), support tab - Manuals, Find the B250 XT and download.
Hope this helps.
Mar 21, 2010 | VXI Corporation Blueparrott B250-XT...
Blue parrott will connect with my Palm Centro, but there is no sound in the earpiece. Please help.
Mar 14, 2010 | VXI Corporation Blueparrott B250-XT...
How do I pair my blueparrot B 250 xt with my verizon LG phone?
my hb250xt is paired to phone and the light is flashing blue. when I make a call it does not go thru the head set and the light go off until I end the call and then it comes back on. cannot talk thru headset
Nov 29, 2009 | VXI Corporation Blueparrott B250-XT...
VXI Corporation Blueparrott B250-XT Bluetooth Headset Logo
56 people viewed this question
Top VXI Corporation Radio Communications Experts
eradiostore
eradiostore
Are you a VXI Corporation Radio Communication Expert? Answer questions, earn points and help others
