Question about Frigidaire Refrigerators
I am replacing the water filter holder and would like to know how to disconnerct the water lines
  • Official Brand Answer
  • 2,267 Answers
Good Afternoon Friend,
I understand that you are trying to replace the water filter holder, or housing, on your Frigidaire refrigerator, and are wondering how to disconnect the water lines. Typically, this is not a do it yourself repair. There are no manuals that will guide you in replacing the water filter housing. I suggest contacting your local authorized technician for further assistance. They have had the necessary training to replace the housing with ease. Should you have any other questions, please feel free to reconnect. Hope this is helpful.
-Best Regards-
WP
Posted on May 16, 2014
I had the message sud on my washer I clean the filter at the bottom of the washer and replaced it and Now I have water pouring out everywhere
Seems like you have not got the filter plug in correctly, or it's not in tightly enough. Turn off the water, put a shallow tray underneath the filter housing, slowly unscrew the filter holder and drain out as much water as you can. Then fully remove the filter holder and check for damage or foreign matter in the screw threads. Clean it fully, dry and replace it. Turn on the water VERY SLOWLY and check for leeks.
May 16, 2015 | Washing Machines
It is an Aprilair Humidifier 220 with thermostat control. The unit is attached to the furnace and for 3 days, we have had water on the floor! We just moved in 2 months ago and are not familiar with a...
Check the drain on the humidifier (at the bottom there is a drain which should be attached to some type of hose that drains into your sump or other wastewater orifice)...
check the filter (remove the lid and the filter is that corrugated metal type thing (it may be clogged causing overflow - you can replace it for about 7bucks at home depot)
also check that the water line (should be attached to the black plastic frame is attached and the water is going into the top part of the black filter holder)
check that the filter is sandwiched properly within the black plastic holder
lastly check the actual holes in the black plastic filter holder to make sure they are not clogged
remember to bring the old filter to confirm size for the replacement
Jan 28, 2011 | Heating & Cooling
Water won't flow, water line clear and has water running thru it....
Then you have to replace the water filter of the refrigerator. It is having some blockage that is why water is not flowing in it.
Filters situated in the interior liner of the refrigerator compartment of samsung-built side-by-side refrigerators are relatively simple to replace. Follow these steps:
  1. Remove the old filter by grasping it and slowly making a one quarter turn to the left.
  2. Pull down gently on the filter to remove it from the mounting bracket assembly. Be careful to not tip the filter, as water may spill out of it.
  3. Discard used filter.
  4. Remove the new filter from its packaging. Apply the appropriate month sticker to the filter to remind yourself to change it again in six months' time.
  5. Fill the filter with water from the tap, and then line the arrow on the filter up with the arrow on the cartridge holder inside your refrigerator.
  6. The filter automatically pulls itself into position as you turn the filter to the right and lock it in place. Be careful to not over tighten the filter into position.
  7. Run water through your dispenser for about three minutes to clear the system. Keep in mind that a newly installed water filter could initially cause water to spurt from the dispenser.
Water by Culligan filter cartridges need to have a water filter adapter installed. This is a one time installment, and once you have this adapter installed, it stays in the refrigerator for all future filter replacements. If your refrigerator already has this adapter in place, do not remove it to replace the filter.
Smart Water filter cartridges do not require the use of the water filter adapter. If for some reason your refrigerator has an adapter in place already, you will have to remove it before installing a Smart Water filter cartridge. The adapter is removed in the same manner as the filter itself: with a gentle quarter turn to the left.
Note: Replacing this type of filter is a quick process - there is no need to unplug your refrigerator when replacing it. Also, this filter should be replaced every six months.
Hope this was helpful to you. Thank you for using fixya.
Jan 27, 2011 | Samsung 26.1 Cu. Ft. Side-by-Side...
I can not turn the cartridge cap counterclockwise to loosen it so that I can replace filter.
Try turning the water off to the refrig then pushing the water dispenser to relieve water line pressure . Then try turning the cap counter-clockwise . Sometimes it takes me both hands at a customers home , to remove the cap due to the rubber seals on the end of the filter , have stuck to the plastic holder .
Aug 05, 2010 | KitchenAid Superba Architect KSCS25INSS...
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
Need someone to explain in detail how to change the water filter ....i have a replacement just don't know how to do it
At the bottom on the kickplate ( by the picture on this thread , you didn't give a model number ) twist the slot under freezer door , to the left and slide out filter . The filter slides off the holder . Slide new filter on and reinstall into the hole , twisting the holder clockwise so it seats .
Sep 05, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
CAN NOT REMOVE WATER FILTER FROM PLASTIC HOLDER
it will also state to turn of the water supply and release any pressure
Jul 02, 2017 | Maytag MSD2651 HE Side by Side...
Water leak at filter
I had this with a Kitchenaid Superba and wanted to get rid of the filter holder assembly entirely as I have an undersink unit which serves the fridge. I removed the plastic line (nut) at the back of the fridge (which led to the filter holder at the front) where the flexible copper tubing inserted (this was a 3/8' compression fitting-plastic) and also the returning line (1/4" copper compression nut on a plastic line) at the manifold (again in the back of the fridge) where it gets split between the water line and the ice line. I then just connected the 1/4" flexible copper directly to the manifold (1/4" nut, compression sleeve, male-male connector) using a pre-made 1/4" flexible compression line. Sounds complicated but after seeing how the water routes it was fairly quick work.
Dec 02, 2008 | Whirlpool GS6NBEXR Side by Side...
Descaling
Remove the filter holder (portafilter).
The manual says to unscrew the nozzle from the filter holder coupling and wash with hot water.
Mix a liquid decalcifier with water in tank at a 1:1 ratio. DO NOT USE VINEGAR! It says to fill the water reservoir.
Run the cleaniing solution through the machine - pressing the coffee button, 1 cup at a time. During each interval let the decalcifier act for 10 or 15 minutes by turning off the machine by the main switch.
Carefully wash the tank and fill with fresh water and empty 2/3 of this by pressing the coffee button.
Now let the machine warm up and empty the rest of the reservoir by rotating the hot water/steam knob.
Screw the nozzle in the filter holder coupling again.
Jan 06, 2008 | Saeco Magic De Luxe Espresso Machine
Refrigerators Logo
48 people viewed this question
Top Frigidaire Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Sal DeAngelo
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
