Question about KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher
Kudi01flss6 control panel lights up will not start
Kudi01flss6air guy says its control panel. Could it be a fuse?
Total loss of power. No lights no anything
Check circuit breaker in main fuse box , If they are all ok check the fuse in the wall plug. If taht is also ok you may have to check for internal fuses in the rear of the tv. It may be a power control/regulator card issue .... see below if you are brave enough to attempt a repair on this. The link leads to a video of a guy performing a resolder / reflowing of solder on a control card. He can do this because he is confident there are no damaaged capacitors, just dry/ dad soldered jounts.
Jun 18, 2015 | Televison & Video
1348 will not power up, just one click
The replacement control panel could be ng.
Dec 23, 2013 | Kenmore Dishwashers
Hey guys, I might be a girl but I can do some work on my lil 1993 restored 525i Instrument cluster lights just went out along with a parking light and can't figure out which fuse or relay to replace. I...
Front power distribution box is located in the left-hand rear corner of the engine compartment.
Fuse # 1 instrument cluster check control. Check fuses #4 ,5 &20. There is also a panel under the rear seat . Good luck.
Dec 21, 2010 | 1993 BMW 5 Series
Guy that tested battery said we have a short in electrical system, how much will this cost to repair...rough estimate .. car won't start like once every 3 or 4 weeks...auto zone was where they checked...
it depends where you take the car for repairs.but this might be an easy fix..go to autozone or walmart(cheaper) and buy a test light and check your fuses one by one the light will turn on when you find the one still pulling current..check fuse panel to see what that fuse goes to and rewire or replace....hope this helps?
Oct 06, 2009 | 2004 Mazda 3
Dashboard lights not illuminating.
CHECK DASH LIGHTS FUSE.THE GUY WHO PUT RADIO IN PROBABLY FORGOT TO HOOK UP YOUR RADIO ANTENNA LEAD.GETTING NO RECEPTION WILL CAUSE STATIC.
Sep 16, 2009 | 2002 Honda Passport
Wife attempted to start her Suz Intruder 800, heard a ''fisht'' sound from under the seat. Now we/ve got no power, lights etc. Thinking it's the ''Relay Starting Motor'' P/N 31800-21E20. Any thoughts?
I'm a Honda guy but try looking around under the seat or under the side panels for a main fuse. If the main fuse is fried (usually around a 30 amp fuse) nothing will happen with the bike unless the fuse is replaced.
Aug 19, 2009 | 2000 Suzuki VS 800 Intruder
I need to run the filter pump without power to the heater
dont worry about the heater it will not come on so turn the pump on before it turn green call a pool guy
Aug 17, 2009 | Jandy Aqualink - Rs24 One Touch Pool / Spa...
Climate control stopped operating overnight during below freezing
Well last night I went under the hood, opened the fuse panel and removed the "Memory"/Audio fuse, in my car it was yellow and only pulled up, not out, it was a "20". I left it out for a few min, pushed the fuse back in and everything is fine now, just have to reset my clock.
Hope this helps all!
Jan 03, 2009 | 2005 Kia Sorento
KUDS25SHWH1 Kitchenaid Dishwasher Control Panel Only CANCEL light on
I bought a control board for $127.00 figuring that was the problem but it wasn't. I called an appliance guy who came out and said its the touchpad that needs to be replaced. I ordered the touchpad ($325) since I already have to much invested in this dishwasher. I paid $1200 for it 8 years ago and its really a great dishwasher. My appliance confirmed that if it was the fuse-ling that you would not have any lights on.
Feb 19, 2008 | Dishwashers
KitchenAid 24 in. KUDI01FLSS Stainless Steel Built-in Dishwasher Logo
29 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
