Question about Philips 50PF9630A 50 in. Plasma Television
The bottem half of the screen is black. Any ideas?
The bottom half of the screen is black. Any ideas?
Found 2 blown fuses.
Posted on Jun 25, 2009
Any advice on what board I should replace if the left half of the screen is no good, just showing white and black vertical bars? Right half is fine. Is the panel kaput?
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Sep 29, 2015 | Panasonic TH-37PH9UK 37" Plasma Display -...
LG 50PK250 shows only 1/2 top screen while the bottom 1/2 screen is black which board do I need to replace??
Line, faults & possible causes to both Plasma & LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Aug 08, 2015 | LG 50PK250 50 HDTVReady Plasma TV
Bottom half of screen is black
The display strip is not properly seated in the connector base. That is a hardware problem so dont think of a software error.
Oct 07, 2014 | Samsung Un46eh6000 46-inch 1080p 120hz Led...
How do i fix the bottom half of my laptop screen which is all black
It is unfortunate that the bottom half of the laptop screen is black. You may try performing an LCD BIST using the below link:
http://dell.to/1irqbYp
Also try connecting an external known good monitor and check if that helps.
Thanks and Regards.
Kiran Kumar.
#iworkfordell.
Jul 06, 2014 | Dell InspironTM 1501 Notebook
My plasma screen goes black on bottom 1/2 of the screen
In most cases the lower Y-Buffer board causes this issue. Unless you know how to work on a TV it is suggested that you have a technician look at the TV and repair it for you.
Nov 05, 2009 | Philips Magnavox 42MF521D/37 Television
Funny half screen problem
Maybe you got dried capacitors near the vertical IC or the IC himself are damaged you need to be atech for make the rapair because is dangerousli make it
Jun 02, 2009 | Sanyo DS31520 31" TV
Screen turned black
your monitor got a hardware problem:
1) the LVDS controler board out of work, only change or repair it could be fixed.
2) if you can see some show like smaller signal detect windows in the centre of screen a very short time (bright flashing one time), this is inverter board damaged or worn lamps, thay all need repair or replace
hope give you some idea. please take a rating let me know how much helped you thanks!
May 20, 2009 | Dell E176FP 17" LCD Monitor
Black Square in bottom half middle of screen
It sounds like your panel is going out and time for a new TV
Nov 30, 2017 | NEC PlasmaSync 50MP1 50 in. Television
RCA PHD50300 no picture on top half of screen
Replace the scan drive board also called X-sustain board. This is the board on the upper left side in the back of the set with a huge heat sink on it. you can find them online for about 175.00. The p/n is pkg50c2g1. Be carefull with the 4 ribbon connectors that go to the display.
Apr 03, 2008 | RCA Scenium PHD50300 50 in. Plasma...
Open Questions:
Philips 50PF9630A 50 in. Plasma Television Logo
192 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
