Question about Vehicle Parts & Accessories
What does chrysler 300 esp bas mean - Vehicle Parts & Accessories
  • 660 Answers
EPS = electronic stability program.
BAS = Brake Assist System.
You should let a dealer have a look at it, but I know this is a common problem with Chryslers.
Posted on Sep 25, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
Esp bas light on what is that
our Electronic Stability Program (ESP) Indicator Light / Brake Assist System (BAS) Warning Light is a common issue with Chrysler's. The first thing to check is the electrical system. Remove the battery posts and clean them well. Next is to check the ground connection at the bulkhead, under the hood and the positive connections at the fuse box and boost pin. If all that checks out OK, check under the main fuse box for loose / corroded plugs and wires. These are the known, common problems. The fluctuation in power would cause the PCM to momentarily go into limp mode causing bucking on decell. Also have the OBD trouble codes read, including the ABS system.
To reset the ESP/BAS light, with the engine running, in park turn the wheel right to left, lock to lock twice.
Nov 11, 2014 | New 2006-2010 Chrylser 300 Chrome Grille...
ESP BAS light is on came on once I changed the spark plugs & it would not shift out of park
check your owner's manual. I saw that condition mentioned in mine. I just do nit remember the answer. Sorry.
Oct 24, 2014 | 2005 Chrysler 300
Chrysler 300 esp bas light along with abs light
You'll need someone to check the body computer for trouble codes to know what to do next. You may find an auto parts store with the right code reader to access the body computer, but most readers only access the engine computer.
Once you have the codes a mechanic can check those codes to find the problem.
Jul 14, 2014 | 2008 Chrysler 300
BAS/ESP indicator lights remain illuminated
Maybe a wheel sensor issue.
Charge battery fully - an under performing battery can create gremlins.
Jan 05, 2014 | 2005 Chrysler 300
BAS/ESP lights remained illuminated imediately after changing the battery
Yes, until you reinstall all your codes, this is the reason mobile battery men have a small battery they connect when they change batteries, to prevent this
2007 Chrysler 300 Touring ESP light on
un hook your battery to reset the computer , if it persits you may have to change the esp sensor keep in mind once you disconnect the battery it will clear your error codes and it can not be read later.
Mar 19, 2013 | 2007 Chrysler 300 Touring
What is the esp bas
esp stands for electronic stability program
Feb 26, 2011 | 2005 Chrysler 300
Esp/bas light came on - power features went out
sounds like your alternator is going out or have a short
Nov 03, 2009 | 2005 Chrysler 300
Vehicle Parts & Accessories Logo
47 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
