Question about Mitsubishi HD1000U DLP Projector
Mitsubushi DLP Projector Problem
The unit displays correctly until i turn it upside down, then the unit loses power immediately..red power indicator and blinking green status indicator. Why?
I am having the same problem with mine.
Posted on Apr 10, 2010
Image is upside down how do i turn image right side up
Go into the menu then the display option. It's probably set for "ceiling mount"
Nov 13, 2014 | Mitsubishi HC3800 1080p Home Theater DLP...
PG-MP60X - Power light is red, lamp light is red, projector not working. How I can fixed that ? thank you
Reset the lamp timer.
1,Connect the power cord.
2,While simultaneously holding down "menu","enter" and "down" on the projector, press "standby/On" on the projector and keep all four buttons pressed down until the lamp indicator starts blinking green.
"LAMP 0000H" is displayed, indicating that the lamp timer is reset.
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 04, 2014 | Sharp PG-M60X Multimedia Projector
Infocus in15 temp and lamp indicator flashing
In attempts to get your IN15 projector working, please try the steps below.
Disconnect AC power from the projector and wait for 10 seconds for supply to properly discharge.
While holding down the Menu, Select and Input buttons simultaneously, plug in the main AC power until
the LEDS stop flashing (approximately 7 seconds)
Jul 15, 2012 | InFocus IN15 DLP Projector
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Toshiba projector switching itself off
Hi 123d
Have you tried resetting the lamp timer ?
If you have and it didn't solve the problem , take out the lamp and check for any discolouration or markings on the lamp.
If you do find anything out of order then the lamp would need replacement.
May 21, 2008 | Toshiba TDP-S9 DLP PROJECTOR *2% DISCOUNT...
Problem with a Gateway 210 DLP projector
The color wheel may not be turning. Remove the lamp and see if it will turn manually.
Aug 08, 2007 | Gateway Projector 210 Multimedia Projector
Open Questions:
Issue with the HDMI Input Hello. I have a Mitsubishi HD1000 DLP Projector that has an issue with the HDMI port. It has been working like a charm and I was very happy with the device, but suddenly, one day I tried to watch a movie in the normal conditions in my salon and the HDMI port didn't received any signal (I have been using it in this setup almost more than 2 years). All the rest of the functions (menus, and others ports like VGA) worked ok. Yesterday I tested another HDMI High Grade wealthy cable without success. But the strangest thing was when I tried another computer and partially it worked with 2 different HDMI cables but green color is not displayed anyway, then the picture looks like magenta. I tried a color pattern and in fact, green is shown like black. If I put again the computer that I usually used for movies, it doesn't display anything except "No Signal". Also I have opened the device and tested continuity from one extreme of the HDMI Cable to the pins soldered to the mainboard of the projector and it looks like all the 19 pins have continuity -but maybe one of them has some losses-. Resuming: - With the computer I usually used, suddenly it stopped to receive any signal with 2 different cables - With another computer, both cables shows the same behavior: the image is displayed with the exception of green (of course, sending a RGB pixel) - Could be the cables, but is too estrange that both have the same issue Anybody could help me? I am a little desperated with this issue :-( Thank you very much :-)
Feb 28, 2017 | Mitsubishi HD1000U DLP Projector
See all Mitsubishi HD1000U DLP Projector Questions
Mitsubishi HD1000U DLP Projector Logo
241 people viewed this question
Top Mitsubishi Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Mitsubishi Office Equipment and Supply Expert? Answer questions, earn points and help others
