Question about Doro Lands Phones
What is block function? - Doro Lands Phones
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
Tip
How to Block a Phone Number With AT&T
<a><img src="block-phone-number-at_t-200X200.jpg" /></a> Call blocking is an easy way to deflect unwanted calls. <span></span> jQuery(document).ready(function(){ jQuery('.intro .thumbnail a:first').attr('href','http://i.ehow.com/images/a04/th/aq/block-phone-number-at_t-800X800.jpg'); }); <p>If you're an AT&T customer and you're tired of receiving calls from companies that try to sell you things you don't want or from people who simply pester you over the phone, the solution is simple. AT&T has a call-blocking service that you can activate in a few simple steps so you won't have to ignore the phone or hang up on people.<br /> jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); <span>Difficulty:</span> Easy <span>Instructions</span> <ol> <li> Dial "*60" and listen to the voice instructions.<br /> </li> <li> Press "3" to turn your call-blocking service on.<br /> </li> <li> Press the "#" button.<br /> </li> <li> Dial the telephone number that you want to block.<br /> </li> <li> Press the "#" button again to block the number<br /></li></ol>
on Jan 12, 2011 | AT&T Blackberry Curve 8300 Smartphone
What's your problem?how can I block the facebook chat function but not block all of the facebook web site?
blacklist this url: http://facebook.com/ajax/chat/
users will see how many friends are online, but if they go to send anyone a message, it will never go through, and chat history does not show up. I am sure you can block more extensively, but for a quick and dirty fix, this does the trick.
Feb 11, 2012 | Zyxel Zywall Usg 1000 Unified Security...
My canon C3170i shows error E000001-0010
Product : imageRUNNER 5070 / 5570 / 6570 Title : Fuser noise and intermittent E001 code Error
The upper fuser roller section makes a noise and intermittently error code E001 occurs Workaround : In this case, the UFR Shutter inside the upper fuser roller was installed reversed (180 degrees out of postion). Installing the UFR Shutter in the proper orientation corrected the problem. Note: the UFR shutter installed in the reversed position will cause a noise and block the Main Thermistor when the shutter should block the Sub Thermistor. In turn, the shutter will block the Sub Thermistor when the shutter should block the Main thermistor. This will cause improper temperature for the Upper Fuser roller and cause the error code. suggested to go in service mode and reset the error, and see if it will solve the problem. If the problem presist, a code will appear and that will be the one we should work on. So we did clear the error, and the machine is functioning.
Entering service mode: press Additional Function > press 2 & 8 at the same time > press Additional Function again Clearing the Error: press Copier > press Functions > press clear > press Err > press Ok. Restarting the Machine:Power off then On.
Oct 12, 2011 | Canon Office Equipment & Supplies
I have been receiving inappropriate messages from an unknown number. i want to block this number but i dont have this function( block function) in my nokia set (3110).
Other than changing the handset for one that does have this function the only other thing would be to have your number changed by your network. Another option is notifying the police of this and seeing what they can do.
Apr 21, 2011 | Nokia 3110 Cellular Phone
FUNCTIONAL BLOCK DIAGRAM OF INTEL8085 MICROPROCESSOR
hi u can view ur functional block diagram by visiting the site www.8085projects.info or simply visit www.Google.com and in the Google search engine type functional block diagram of INTEL8085 microprocessor and click on search u will observe a list of sites and u can find ur corresponding details in that list of sites to view any detail simply click on cached was this helpful pls rate me for my solution
with warm regards -bonefirediv
Apr 11, 2011 | Office Equipment & Supplies
How do i block a number
THIS FUNCTION IS NOT MOBILE FUNCTION. IT IS COMPANY FUNCTION. CALL UR COSTMUR CARE (TOLL FREE) AND ASK HIM FOR BLOCK THECONTAC
Mar 01, 2008 | Sony Ericsson K800i Cellular Phone
Lands Phones Logo
11 people viewed this question
Top Doro Lands Phones Experts
castletech
castletech
Greg Cann
Greg Cann
Are you a Doro Lands Phone Expert? Answer questions, earn points and help others
