Question about Philips HTS-6500/37 System
HOW TO INSTALL SUBWOOFER #PWR2006-37 PHILIPS
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Hi I have a Philips HTS3450 system but lost the Subwoofer, Is there a way that I can connect the Subwoofer connection to my Panasonic Home theator system to get the sound? Thanks in advance
I'm not sure what you mean by "connecting the Subwoofer connection to my Panasonic Home Theater System"
If you want to watch something on the Philips and send the audio to your Panasonic Home Theater you can buy a VGA to AV Adapter Cable. Just connect it to the back of the Philips HTS3450, get an AV cable (red,white,yellow) and run it to the Panasonic.
I recommend buying it here: http://www.buy.com/retail/product.asp?sku=212966742
Aug 11, 2010 | Philips HTS3450 System
I need pinout assignments for a Philips 5.1 Home Theater Speaker system (PWR2006-37)? It has a DB-15 style input connector that hooks to the output of a Philips dvd / amp / control unit. this was...
Pin assignment is as follows (not sure of levels required- preamplification / attenuation may be necessary:
1: Control 0/5V.
2: Unused
3: Unused
4. Center speaker in
5. Ground
6. Ground
7. Subwoofer in
8. Ground
9. Unused
10. Ground
11. Left Front speaker in
12. Right Front speaker in
13. Ground
14. Right surround (rear) in
15. Left surround (rear) in
Jul 10, 2010 | Philips DVP642 DVD Player
I have a philips surround system model # HTS3450/37 and my subwoofer is out and i cant hear anything through my system. How do i check what is out on my subwoofer?
Hi
Thanks
in advance
Jan 01, 2010 | Philips HTS3450 System
Info on the SW9800 Subwoofer
I would like to buy your subwoofer for my broken system. Please contact me ASAP
adam.roseneck@gmail.com
Dec 23, 2008 | Philips Cineos HTS9800W System
Philips receiver hts3450 was stolen but I have all my speakers and subwoofer.
Without doubt the Philips had an amp built in for the subwoofer. So that when it is connected to the TV the sound signal from the TV is just too weak to power it.
My advice would be if you can't get a another receiver is to look up the specifications of the it. You should then be able to find a suitable amp that will power the subwoofer for the TV from those specifications.
Jun 01, 2017 | Philips HTS3450 System
Subwoofer light
The subwoofer light stays red regardless of the state it is in despite it being labled a standby light. (It's more of a power on light) It seems that philips missed the point of what a standby light is.
I would have expected the light to have changed colour to indicate that the unit was operational and perhaps syncing with the receiver box.
May 17, 2008 | Philips Cineos HTS9800W System
Philips HTS-6500/37 System Logo
62 people viewed this question
Top Philips Audio Players & Recorders Experts
Gyula Lacz
 Grubhead
Grubhead
Are you a Philips Audio Player and Recorder Expert? Answer questions, earn points and help others
