Question about Car Audio & Video
How to unmute prestige car alarm remote - Car Audio & Video
SOURCE: Free programming instructions for Prestige remote
YOU can call prestige tech support at 1800 225 5074.. or just put the key in the ignition turn the key all the way to the right without starting the car then flip the vallet switch usually located at the bottom of the dash drivers side, flip the switch on and off three times, you will hear a chirp then you should press the first button on the remote for 2 seconds then flip the swith on and off one more time , then press the second button the remote for 2 seconds then flip the switch again on and off one more time then press the 3rd button on the remote for 2 seconds... After which... remove the key from the ignition and your done... Try the remote to see if it works the way it should if not do it all over again..
MSB....
Posted on Oct 22, 2008
reynosaelect
  • 165 Answers
SOURCE: I need the diagram of alarm Prestige model: APS95BT3
go to google and write this> audiovoxtechservices press enter,and in that website request a password to get the instalation manual
Posted on May 11, 2009
SOURCE: programming the APS02BT2 remote
TO PROGRAM ADDITIONAL TRANSMITTERS:
1. Enter the vehicle, and turn the ignition key to the "on" position.
2. Press and release the valet push-button switch three times.
3. The dash LED will flash once, and the siren will "chirp" once, indicating the system is ready to accept programming for channel 1 or the arm/disarm and panic functions.
4. You can assign any of the three transmitter button functions listed below to channel 1.
a. Pressing button #1 on the keychain transmitter.
b. Pressing button #2 on the keychain transmitter.
c. Pressing both buttons simultaneously on the keychain transmitter.
5. Press and hold the selected choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 1 was successful.
6. Press and release the valet push-button switch one time.
7. The dash mounted LED will flash 2 times, and the siren will "chirp" indicating that the system is ready to accept programming for the unlock/panic channel.(If you desire one button to control lock & unlock, move on to step 9)
8. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of unlock channel was successful.
9. Press and release the valet push-button switch one time.
10. The dash mounted LED will flash 3 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel2, or the pulsed ground output for remote trunk release, remote car starter, etc.
11. Press and hold the selected remaining choice a, b, or c above, until the siren emits a long "chirp" to confirm that programming of channel 2 was successful.
12. Press and release the valet push-button switch one time.
13. The dash mounted LED will flash 4 times, and the siren will "chirp" indicating that the system is ready to accept programming for channel 3, or the additional pulsed ground output if available on your model. NOTE: If the program switch is operated again, the circuit will recycle through the program mode. In other words, press 1 time to access the lock function, 2 times to access the unlock function, 3 times to access the start function. When programming is complete, simply turn off the ignition switch to exit the program mode.
ERASING TRANSMITTERS IF THEY HAVE BEEN LOST OR STOLEN: NOTE: Before you begin to erase the lost or stolen transmitter(s), have all transmitters available that you wish to remain programmed. These will be used during the program process to identify transmitters that will continue to be used.
Enter the transmitter program mode:
1. Turn the ignition switch to the “ON” position.
2. Within 10 seconds, press and release the valet/program switch three times. (Siren emits 1 short chirp indicating channel 1 has been entered)
3. Within 10 Seconds, press and hold the ARM or ARM/DISARM but-ton of the first transmitter you wish to remain stored into the control unit until a single chirp is heard from the siren.(Repeat this for each transmitter you wish to remain stored in the control unit).The receiver stores up to four transmitters. To be certain all transmitter slots in the receiver are occupied with transmitters you wish to continue to use, and all others are erased, you will have to fill all four receiver slots. If in step 3 you identified one transmitter, you will have to fill the additional 3 slots. If in step 3 you identified two transmitters, you will have to fill the additional two slots, etc...
4. Press and hold any unused button or combination of buttons until a long chirp is heard from the siren. Release and press the button or button combination again and again until all remaining slots are full. NOTE: The button or combination of buttons entered will also control the armor arm/disarm function until additional transmitters are added. All unwanted transmitters are now deleted.
Posted on Jun 09, 2009
  • 33 Answers
SOURCE: How do I disarm a audiovox prestige car alarm?
Locate the valet/override switch (button), (if you can't locate it, try tracing the wires under the dash from the main unit, usually a black and gray or black and red set of wires). Turn key to "RUN" position then press the button, the alarm's LED should light up solid at this time indicating valet mode as been set.
Posted on Jun 20, 2009
logosc75
  • 625 Answers
SOURCE: I bought my car used
Locate a black push button switch under the dash or near the drivers side kick panel (older model), or the alarm has a push button LED light(newer model) or the Valet switch is in the antenna(newest model). Turn the ignition on, press and release the switch one time. This should disarm the alarm.
For programming: turn ignition on, press and release the valet switch three times: you will hear one chirp from the alarm, press the lock button on the remote. Press and release the valet one time, you will hear two chirps from the alarm, press the unlock button on the remote. Repeat as necessary. Turn igniton off to exit programming. Test remote for proper functioning.
Posted on Jul 17, 2011
Prestige car alarm remote not working
mostly self serve fixing them . id ask at a tint an alarm place
there is function to pair them again . have the remote tested if its putting out signal . point at a camera an watch . take it to autozone . listen to it on a radio close to it. you have 2 is the other working.
Jan 05, 2015 | Audiovox PRESTIGE APS920FACTORY...
My alarm was working fine then one day i just unlocked the car drove then when i tried locking the car with the remote and it didnt work the light that flashes when alarm is on didnt start flashing it...
Sounds like the unit may have seized (common occurence with this unit). Disconnect the positive battery terminal, wait ten seconds, reconnect. If you have a security radio be sure to have the code handy.
May 22, 2011 | Brand New Prestige Aps787n Remote Startcar...
I need to re-program the remotes to my alarm. It is a prestige aps255a. Just to lock and unlock all the doors. To arm and unarm is already programmed.
Huh? Pressing the lock button arms the alarm AND locks the doors. Pressing the unlock button disarms the alarm AND unlocks the doors. If this is not happening either there is an issue with the wiring from the alarm to the car or, with the vehicle's door locks.
Apr 20, 2011 | Audiovox APS255A Car 2 Prestige Platinum...
I have a honda pilot with the prestige car starter and the panic alarm keeps going off when I open the door. I can not get it to stop so it has to go through its 2 minute cycle. any ideas on how to get...
That is your factory alarm. I will assume that this Prestige unit is a remote starter with keyless entry...and you are using the Prestige unit to unlock the doors. Apparently, the unlock wire is connected but, the factory disarm is not. You can turn off your factory alarm by unlocking the vehicle with the key.
Jan 25, 2011 | Prestige Remote Start
I have a new prestige car remote installed recently and i have a problem how to shut off the alarm coz the installer did not or forgot to give me the manual. When i start the car remotely i press the...
You did not mention the year/make/model of your vehicle but, the issue appears to be the factory alarm. The installer failed to make the connection. If you intend to make the connection yourself I would need information pertaining to the vehicle. The (-) pulse before start wire for Prestige remote starters is black with a blue stripe. It is in a 4 pin connector at the module. This wire can be used to disarm the factory alarm before the remote start sequence.
Jan 23, 2011 | Prestige Remote Start
How to deactivate a prestige car alarm
remove the fuse in the main harness going in to the alarm unit under the dash, if you have a starter kill feature you may need to bypass this. you will need to make up a jumper wire and place it in pin 30 and 87 on the relay
Feb 07, 2010 | Audiovox Prestige Code Alarm Remote Alarm...
I need to see if a add on remote start will work with my prestige
The APS9076 is a OEM add-on remote start module only and not an alarm. Are you trying to add or find a remote to an existing Prestige alarm or installing one?
Aug 02, 2009 | Audiovox AS9076 Car Upgrade Remote Start...
I don't know how to use my keyless remote start
DO YOU THE MODEL OF THE ALARM,PROBABLY NOT,EMAIL ME I THINK I CAN HELP YOU,I NEED TO KNOW HOW THE REMOTE TRANSMITER LOOKS LIKE.HERES MY EMAIL: reynosalectronics@live.com.mx
Mar 14, 2009 | Prestige Remote Start
MSB....
Oct 13, 2008 | Gmc Dodge Ford Reverse Back-up Sensor...
Car Audio & Video Logo
115 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
