Question about Capresso Jura-13185 Impressa F7 Espresso Machine, Silver Metallic
Jura f7 drip tray
Hard to close
Water is dripping slowly from one spout. How do I access and remove the spout assembly on a Jura Impressa F7?
Open the whole machine and you'll find the spout. Tighten up the nut there, the washer is like a tap thats dripping
Dec 10, 2014 | Jura Capresso Impressa F7 Espresso Machine
Drawer will not go back in for Jura Capresso impressa
For Jura F7 Series, "Tray Missing, can't put it back in". With a small flashlight, look in to the cavity which the tray and grounds container reside in. Along the right side above a slot to the end, you'll see a white micro switch. with a "Tooth Pick" simply press the switch inward (to the right) and hold till the machine cycles the Levcer / Flap up and out of the way.! Put your tray and grounds container back in and begin brewing!! -dh
Mar 17, 2012 | Jura Capresso Impressa E8 Espresso/Coffee...
Message says tray missing, even with tray in place. Have found the micro switch inside and pushing this down "fools" the machine into thinking the drip tray is back in place, but then when the...
Clearly, the drip tray is not aligned right, or there is a manufacturing flaw. Simple answer would be to examine the part of the tray that you believe is supposed to engage the switch when it is in place, and try to figure out why it is not doing this.
Personally, if you are like me and don't mind voiding a warranty, I'd suggest removing the switch so the machine always thinks the tray is in place.
May 07, 2011 | Jura Capresso Impressa F7 Espresso Machine
I have a Jura impressa C5, and drip tray will not go back in with the grounds basket installed. Seems as thought the mechanism is jammed out of place. I have cleaned out the tray and vacuum cleaned the...
I have a Jura Impressa 27. The tray, for some odd reason, was not going back in. I simply tried it without the top part - that receives the grounds - and was finally able to get it in. I pulled it back out and found some grounds that had been dumped. It seems something was stuck that wouldn't allow it back in with the top part. Then after I was able to put both pieces back in without a problem.
Mar 26, 2011 | Jura Capresso IMPRESSA F60
Jura impressa f7 decalcifying pressed rinse but does not show empty button as the manual says
First you have to turn the machine off and then press and hold rinse buttom until you read empty tray and then follow the rest of the instructions. Good luck
Dec 31, 2010 | Jura Capresso Impressa F7 Espresso Machine
Tray missing
On the right side inside you can see a small slot. Try using a screwdiver or something to click this small microswitch, if the message disappears, then you need to check your tray and see if something is broken. You can also try to move a little on the tray when it`s in the machine. However if clicking on the microswitch doesn`t help, you need to have this switch replaced in a servicecenter
May 27, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
Jura Impressa F50 - tray - fault 8
Hi, if you havn't already solved this one, it has been caused by pulling the drip tray/ dump box out while the brew unit was still active. Switch off the machine and insert the drip tray without the dump box. Turn the machine back on and the brew unit should re align itself.
Feb 15, 2010 | Jura Capresso Impressa F9 Espresso Machine
When turned on it will prompt "Open Tap" "Close Tab"
There are two possible causes. One is easy the other is hard. So try the easy one first. Remove the grinds tray completely, and place you hand in the cavity that it normally takes up. moving you hand slowly in, feel towards the top. you will find a little flap, past that flap there is the tamper and coffee filter at a slight angle. This may be blocked, so clean with a cloth.
If that does not solve the problem (and 90% of the time it does) then you may have a small spec of dust that is stuck in the water system, this needs to be flushed and cleaned. The best place to do that is with a Jura approved center. Unless you are technically minded. Your local Jura chaps sound like they need a k!$k up their behind
Sep 10, 2009 | Jura Capresso Impressa F7 Espresso Machine
Capresso Jura-13185 Impressa F7 Espresso Machine, Silver Metallic Logo
13 people viewed this question
Top Capresso Coffee Makers & Espresso Machines Experts
De Brewerz
De Brewerz
Level 1 Expert
Lawrence Oravetz
M.B. Nataraj
M.B. Nataraj
Are you a Capresso Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
