Question about Qca Spas Majestic Series Aruba Xl Hot Tub
By pass FL1 code - Qca Spas Majestic Series Aruba Xl Hot Tub
    Top Expert:
  • Qca Spas Master
  • 5,045 Answers
Recirculation pump or pressure switch
Posted on Sep 15, 2017
I installed a new heat sensor in a jandy pool heater. It is still flashing an FL1 code.
Sounds like you have an LJ Laars heater. The heater is old and it is very likely that the board is having trouble reading the sensor. All the boards are very expensive, might not be worth saving the heater. You may end up replacing more than one board. The sensor should be tested before changing the power control board, R0366800.
Mar 14, 2017 | Jandy Pool & Spa
How do I clear an air in a j345 jacuzzi
make sure all the unions to the pumps are tight
Sep 15, 2014 | Pool & Spa
Jacuzzi j355 hot tub FL1 code flashing on control panel
sounds like the recirculation pump isnt working FL1 means no Flow pump 1
Aug 24, 2014 | Jacuzzi Pool & Spa
Failure Code FL1, what problem is associated with this code?
temp sensor malfunction. faulty sensor or water temp is too cold or too hot
Aug 23, 2013 | Jandy Pool & Spa
Code flashes fl1 and heater does not go on
asdasdasdasdasdasdasdasdasdasdasdasd
Aug 02, 2013 | Home
FL1 fault code
Definition of FL1 = Water flow problem, inhibited or pressure switch malfunction. Check for proper spa water level and ensure pump is primed. Check for clogged filter.
Its likely to be your pressure switch (screws into heater tube, usually two wires) If this is blocked or has failed the heater will not turn on.
Jul 18, 2012 | Dream Maker Spas Pool & Spa
Code FL1
hi, this generally means a flow error and shows when the heater is looking to heat but there isn't enough pressure running through the heater tube. in this case the thermal overload sounds like it has tripped in the pump.
Jun 06, 2009 | Qca Spas Majestic Series Aruba Xl Hot Tub
Jacuzzi hottub flashes f1 code. Tried hose in heating element and new filter.
The F1 code on my Jacuzzi is just the setting for the filteration mode. If you press the + and the - sign at the same time than release. Then press the warmer + or cooler - to select filter mode F0 thru F6. If you are getting a FL1 code means the flow switch is malfunctioning.
May 05, 2009 | Jacuzzi Home
Qca Spas Majestic Series Aruba Xl Hot Tub Logo
Top Qca Spas Pool & Spa Experts
Ian Kime
Ian Kime
byrdhaus188
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Qca Spas Pool and Spa Expert? Answer questions, earn points and help others
