Question about Sharp AR-407 Copier
Hello, how do i replace the developer in my sharp ar407 copier? please help me!
  • 41 Answers
Http://www.eserviceinfo.com/download.php?fileid=41998
Hi ,i uploaded the service manual at the above link in 3 sections.Download all 3 sections before unzipping it and it comes in pdf format.The dev section is on page 4-6 if i am right.good luck and let me know.
Posted on Jun 24, 2009
What is ar407 toner weaste problum in machine and salve
The waste toner bottle is full. You can empty it into a trash bag but beware it is very messy. The waste toner door is on the rear right hand side of the machine. Remove the white bottle and carefully empty it out, then put the bottle back into the machine.
Jun 13, 2014 | Sharp AR407 Waste Toner Bottle Genuine
What does developer replacement required means?
the developer is magnet powder, which is mixed with toner in developer unit and it helps the toner transfer on to the drum surface.
If the developer looses his properties, the copy will have dark back side, or spots or similar problems.
On preventive maintenance, the developer, drum and drum cleaning blade are mandatory parts.
Hope that helps!
May 15, 2011 | Sharp AR-M205 Copier
What is Code: F2-37
http://www.copytechnet.com/forums/sharp/15117-sharp-ar407-code-f2.html
Apr 23, 2010 | Sharp AR-507 Copier
I have changed a developer and so i want to run a sim of developer in the copier sharp ar-5316
Hello sir; This model machine not require developer to replace, it come with toner cartridge therefor no such simulation code.
Jun 11, 2009 | Sharp Office Equipment & Supplies
How to put developer(black) into copier how to enter thes functions please... i must enter in expert mode before entering codes...
Hello sir; This model copier, the developer come with toner cartridge, you don't have developer replacement problem.
May 26, 2009 | Sharp AR-5316 Advanced Digital Imager...
Sharp AR-275 Copier
Hello sir; there have no reset key for maintenence, whenevere PM light on you need to do PM service (such as replace drum developer, drum blade etc.)
May 19, 2009 | Sharp AR-275 Copier
Needs maintenance
Maintenance doesn't necessarily mean developer replacement, if its working well, ignore developer and continue if it requires, pullout the developer unit and remove the toner hopper. Then empty the used developer and put new one. To empty, turn the dev unit upside down while rotating the magnet roller clockwise the return it in normal position and pour the new developer while turning the magnet roller clockwise until evenly distributed. Put back the toner hopper and screw back and install inside the copier then set it with 'P, Interrupt, C, Interrupt keys enter 25 press Start 2 then Execute key and allow to run till it stops then press Interrupt twice and Press 24 Start 3 Execute . Finally Switch OFF and ON.
May 07, 2009 | Sharp AR-407 Copier
Sharp AR-M165, maintenance led and developer replacement leds on
It's the drum thats causing the lines to happen. Youre going to have to get that replaced before you can reset the counters.
If you get light copies, then the developer should be replaced.
Sep 01, 2008 | Sharp AR-5316 Advanced Digital Imager...
F2-02 error on Sharp AR-M237
on this code you may have to clean out the developing unit and start with fresh developer. Make sure the developer unit is not leaking from one of the bearings. You may need a tech for this one...
May 23, 2008 | Sharp AR-M237 Copier
Sharp AR-407 Copier Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
