Question about Acer Aspire 4315 Notebook
My computer is an acer aspire z5610. The keyboard does not have an fn key.any other solution? Thanks chris
sandrew
  • 2961 Answers
SOURCE: Acer Aspire 3000 Series Numerical Keyboard/Function Key Problem
if using XP go to my computer, right click>properties>hardware tab>device manager>look down list for keyboard, click '+' sign and highlight your keyboard and right click and select uninstall. Restart the notebook and the keyboard will be installed automatically along with the drivers and should set it back to default.
Posted on May 21, 2007
SOURCE: Fn key wont turn off
OK, I've found a soliution! :) I've been diging the internet and many people are having the same problem, so it is a common problem however the soliution is very simple (in my case). The thing is that laptops does not has a saparated Num Pad, and numbers can be found on keys under F1-F12 row or/and (active with Fn key) on alphabetic keys uiopjkl;m/ and so on. But if there is a NumLk key on your keyboard, you can lock the Num Pad on alphabetic keys. Then you have to hold Fn key pressed to write letters.  Find the NumLk key and try to turn off the Num Pad :)
On my laptop (Acer extensa 5120) NumLk key is on F11 and active when Fn is depressed.
Hope this wil help :)
Posted on Oct 02, 2008
Subrat20
  • 21 Answers
SOURCE: fn key combo for acer aspire 3680 wlan when wireless switch broke
on pressing  fn+F1 will give you the details of all the combo keys that you can select find out your one
Posted on Jun 21, 2009
rylee_smith
  • 8619 Answers
SOURCE: Acer Aspire 6920 cursor won't move
Hi
Thanks for using FixYa. You’ll need to reset the Laptop as per the procedure given as under---
Remove all the connections to and from the Laptop. Now remove the battery and press and hold the power on button for 2 minutes. Release the power on button. Slip in the battery pack. Plug in the power to the laptop and to the wall. Please do not plug in any other devices and now try the Laptop powering it on to resolve the issue.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Posted on Nov 27, 2009
SOURCE: Acer ASPIRE 5532, touchpad stoped working. I
The 5532 has a button to the left of the power button that turns the touchpad on and off.
Posted on Mar 30, 2010
WHERE IS MY KEYBOARD LIGHT? I use an acer aspire E14 i'm wondering if it has keyboard light..if yes, please how can i activate it..Thanks... FIDELIA
if your acer supports keyboard lighting then the keys are Solution
  • You can enable or disable the keyboard backlight of your Acer Aspire laptop using the following key combination: FN +F9
Mar 05, 2017 | Acer Computers & Internet
How do I disengage the num lock on my acer aspire one?
Hi
i believe that you should press the FN+Nulock key
FN switch bottom left of keyboard Nulock normally top right
many thanks
Mar 16, 2011 | Acer Aspire One Netbook
I lost my question mark -- what do I press to get it back
Press your FN key.
If you look at your Keyboard on a laptop you'll see that certain keys have more than 1 symbol on them.
The FN key brings these secondary symbols to life as live keys and pressing it again will restore original function to the keyboard.
Mar 03, 2011 | Acer Black Acer Aspire Keyboard...
I have a Acer Aspire 5532, my Number Pad on the right doesnt work, and yes ive pressed the number lock button and it still doesnt work. Help Please--Thanks.
Part of the keyboard is not working, the only solution is to have the complete keyboard replaced, they make the key system more of a throw away item. I suggest a computer repair store
Jan 01, 2011 | Acer Aspire AS5520-5537 Notebook
How on earth do u use the mouse and keyboard for Acer Aspire Z5600/Z5610. Hubby cant use touch screen, please help?
There should be a USB receiver inside the battery compartment of your mouse.
Plug it in to the computer and try using the connect button on the keyboard and mouse.
That should do the trick.
Nov 16, 2010 | Acer Aspire Z5600 PC Desktop
New aspire z5610, doesn't see mouse or keyboard. Unpacked new computer,followed set up instructions and trouble shooter but can't get mouse or keyboard to communicate.Any advice would be appreciated before...
This is a common problem. With our new Aspire Z5610 we pressed the reset button under the keyboard but the problem came back from time to time. To be be honest the design of the Aspire keyboard and mouse is rubbish. Went out and bought a new Advent wireless keyboard and mouse in sleek aluminium design - works a treat and no problems so far. Cost £35 from PC World.
Feb 22, 2010 | Acer Computers & Internet
I cant locate fn key on acer aspire one to raise
Fn key is bottom left of keyboard, volume keys (up and down arrows) are bottom right.
Feb 22, 2010 | Acer NSK8458AN Keyboard
Bilingual keyboard
There is a small green Fn button near the start button you will have to use this with shift to use the green keys if you are in multi lingual mode, if you only use the laptop for french you can also change the regional settings for the keyboard to Just French and then they will work just by using shift.
Hope this helps FixYa,
Chris
May 19, 2009 | Acer Aspire One PC Notebook
Fn key is broken
im afraid not, unless you can pull the key (im assuming its just the key) from another keyboard. note that you can change the display settins (in XP) through the desktop settings
Mar 26, 2009 | Acer Aspire 5672WLMi Notebook
Acer Aspire 4315 Notebook Logo
67 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
