Question about Reddy Heater-170,000 BTU Kerosene Deluxe
REPAIRS TO RT 25 BONAIRE GAS HEATER
My rt 25 bonaIRE GAS HEATER TURNS OFF AFTER ABOUT TEN MINUTES HEATING I THEN HAVE TO WAIT FOR ABOUT TWENTY MINUTES BEFORE IT WILL LIGHT UP AGAIN THEN IT WILL CUT OFF AGAIN ABOUT TEN MINUTES LATER
Honeywell HZ315C ceramic heater turns on and heats well. After a minute or so it clicks off. Unfortunately it does not turn back on. Power light remains on. If I unplug the heater,wait twenty minutes,...
Yes it could be the thermostat and you should be able to bypass it.If you do this you will want to monitor it closely as you're thinking for safe operation. Thank you
Mar 28, 2011 | Honeywell HZ315 QuickHeat Ceramic Compact...
Security light stays on and vehicle won't start
Try keeping the key in position for at least ten to twenty minutes, the security light may be blinking .
Leave it as such for twenty minutes and then turn off the key and then again turn the key on and try to start , it must reset the security system.
Nov 27, 2010 | 2001 Ford Expedition
The pressure switch light is illuminated and that is the only light that is on. The pool heater was shut off in the spring and worked well then. We put in a brand new filter just before leaving for home,...
Check to be sure that your gas valves are on at the house or tanks and outside and inside the heater. Then be sure to bleed the gas line. If it has sat for a while the gas could have disapated from the line. To do this just shut the gas off outside the heater and open the line by loosening the flex line or the union at the heater. Open the gas untill you smell gas, then shut the gas down again and tighten the fittings up again. Then give it about ten or twenty min. for the gas to clear, open the valves again and see if this helps. Good luck.
Aug 31, 2010 | Pentair Minimax NT Heater
I have a Rheem 41v50n (about 10 years old)and the pilot light went out and will not re-light. Gas comes out when I hold the botton down, but it goes out again when I let go. Any simple fixes, or should I...
The thermocouple just needs to be replaced. Can be bought for around ten bucks at many hardware store or heating supply house. Simple installation. Takes about ten minutes to install. They come in different lentghs, see how long yours is before you buy, so you get the right one.
Nov 12, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
I have a similar problem
I just went into the Bonaire website and downloaded their FAQ on gas ducted heating from their support link. Their instructions are pretty easy to understand.
Sep 08, 2009 | Heating & Cooling
Will light and run for about ten minutes then shut down
the home heating fuel will gel thus the heater will shut down
Jan 16, 2009 | Reddy Heater-170,000 BTU Kerosene Deluxe
Goodman gmp050-03 heater
Either yourself or a Heating specialist will have to replace the gas valve.. Once installed you will plug unit back in which will reset power board and should work fine
Dec 23, 2008 | Goodman GDS80904BNA Open Flame Heater
Reddy Heater-170,000 BTU Kerosene Deluxe Logo
95 people viewed this question
Top Reddy Heating & Cooling Experts
Mack Baxter
paulcarew
Richard Marsh
Richard Marsh
Level 1 Expert
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
