What are NVM values for Belt edge learn mode setup of xerox dc1632 printer?
  • 62 Answers
SOURCE: xerox dc 12 mailbox finisher
its plug and play...you dont need to change anything
Posted on Nov 19, 2008
  • 62 Answers
SOURCE: mailbox ,finisher xerox dc12
i take you have a mailbox finisher. If so the finisher is plug and play with the dc12
Posted on Feb 20, 2009
SOURCE: my printer is xerox 1250,
Sorry to tell you this, but adjusting or performing maintenance on this machine is very, very dofficult unless you have the technical documentation and in some cases the specialized tools.
If you have a maintenance contract you should call the service department associated with that contract.
Any time the colors are light, be sure to check the amount of toner for that color and make sure there is plenty in the hopper. Also there is often an adjustment that you, ther operator, can make to increase or decrease the color saturation.
. If you are using a manufacturer of the toner other than Xerox, you might get some help with the agent that sold you the toner.
Otherwuse, it takes a trained technician with tools and documentation to keep the Xerox machine running properly.
Posted on Dec 15, 2010
upbeatjunk
  • 231 Answers
SOURCE: How activate printer xerox docucolor
I would try this:
Power off the copier/printer.
Power it back on
While it is warming up, press and hold the start button for 5 seconds.
This should activate the automatic start feature.
I hope this helps! If this did help you, please give a thumbs up!
Thank you for choosing FixYa!
Posted on Jul 06, 2011
SOURCE: xerox 4112 fault code 092-311
NVM VALU FOR 092-311
Posted on Oct 01, 2012
Dear All can any one tell me solution for this Error please XEROX 7228 Workcenter code 004-346 waiting for your kind replays
04.346, 04-562 Transfer Belt Home
The IBT Home Sensor does not detect the Belt Home signal.
If this fault is declared 3 times in succession, print mode will be disabled. In order to
clear this condition, reset NVM location IOT/Finisher 1221 to 0 in dC131.
Sep 15, 2015 | Xerox Office Equipment & Supplies
I have copier xerox 5021 error is 092-910 what does it mean
That error is an ATC failure. It can be caused by a bad drum or MCU Board. You can first try clear the value of NVM [752-059] (ATC Fail) or NVM [752-060] (ATC Fail Continuous Count) to '0'. Enter Diagnostics, Press and hold the [0] key on the Control Panel for 4 seconds or longer and then press
the [Start] button while keeping your finger on the [0] key.
Password is 6789. And go to NVM Initialize.
Sep 06, 2015 | Xerox Office Equipment & Supplies
004-361 error code in xerox 7345
Hi
Xerox Werk Centre 7428 Tray 2 NVM Read / Write Chain-Linc & Current Value
Feb 03, 2013 | Xerox WorkCentre 7328 Multifunction laser...
I have Color Registration problem in Xerox m24.I hv checked all 4 Drums.They are free .IBT assembly is free.On PWS Regicon setup, it gives NG.There is Color Regidtration issue.Kindly suggest solution
Welcome to fixya
Hello
I have a solution for this
Press Ok, Accept or replay so we may get started
Your pre-solution is coming up shortly
PLEASE REPLY OR LEAVE COMMENT TO CONFIRM YOU RECEIVED THIS EMAIL
My name is Bruce
Jan 17, 2011 | Xerox WorkCentre M-24 Color Copier
As soon as machine is turned ON error code 124-315 appears. pls help!
Here is a note from a Xerox Tech:
Everything points to NVM coruption so try with reseating the NVM pwb. And then maybe NVM init.
Hope these helps.
Nov 23, 2010 | Xerox DocuColor 12 Printer
Docucolor 242 code 042-326. What do we need to
arrwup.gifBSD On BSD 9.20 - Transfer Belt Position Monitoring arrwup.gifDescription Belt Home Position too long
arrwup.gifInitial Action NOTE:
If this fault is declared 3 times in succession, the print mode will be disabled. In order to clear this condition, reset NVM location 741-105 to 0.
  • Check the opening/closing of the Front Cover.
  • Turn the power OFF then ON.
arrwup.gifProcedure Check that the Transfer Belt is in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Center if required (see REP 9.3).
Perform ADJ 9.13 Belt Edge Learn Cycle.
The Belt Edge Learn Cycle ends abnormally. Yes No Unanswered
End
Check the reflective mark at the rear of the Transfer belt.
The reflective mark positioned correctly and reflects properly. Yes No Unanswered
Clean the reflective mark and reposition it properly, if the problem continues, replace the IBT belt ( PL 7.3).
Enter dC330 [042-200 Transfer Belt Home Sensor]. Rotate the belt manually for 1 turn.
The display changes. Yes No Unanswered
Go to OF 99-1 and troubleshoot the Transfer Belt Home Sensor ( PL 7.5).
Check the operation of the actuator of the Transfer Belt Edge Sensor Assembly.
The actuator moves smoothly. Yes No Unanswered
Replace the Transfer Belt Edge Sensor Assembly ( PL 7.4).
Select [042-016 IBT Steering Motor (CW) High Current] and [042-017 Steering Motor (CCW) High Current].
The IBT Steering Motor operate. Yes No Unanswered
Go to OF 99-9 and troubleshoot the IBT Steering Motor ( PL 7.4).
Check the installation position of the IBT Belt Module (the four legs of the IBT Belt Module are placed on the board springs of the Transfer Drawer and the fixing screws (M4: x2) of the IBT Drawer are tightened).
The IBT Belt Module is installed in the proper position. Yes No Unanswered
Adjust the installation position of the IBT Belt Module.
Set dC131 [741-105 Angle Data Initial Value (A0)] to 0.Install the IBT Belt in the center (where the IBT Belt Edge and the IBT Belt Frame are approx. the same distance from the front and rear). Perform ADJ 9.13 Belt Edge Learn cycle.
End
Replace the Transfer Belt Home Sensor ( PL 7.5). If the problem continues, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem persists, replace the Transfer Belt Edge Sensor ( PL 7.4). If the problem is persistent, replace the IBT Belt Module ( PL 7.1).
Sep 08, 2009 | Xerox Office Equipment & Supplies
Xerox printer has a Power off and turn on message
U must put some values nvm values. If U didn't. U must say what kind of rip u have and I can send
Jan 26, 2009 | Xerox DocuColor 12 Printer
nvm 774056 if it is fuji the value -48
nvm 774056 if it is xerox the value -16
the problem is same
nvm 774057 it is 0 put 1
Jul 02, 2008 | Xerox DocuColor 12 Printer
jasbo
jasbo
