Question about Frigidaire FEF364DQ Electric Kitchen Range
Front left dual element on a Frigidaire ceramic top stove GLEF379DBB: inner element has stopped heating. How do I replace the element?
  • 64 Answers
Open the door and look under the top remove the screws and the top will lift
Posted on Jun 23, 2009
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Dual element burner on glasstop range...inner element stays on
It is the burner control (behind the knob). The triac in the control has failed. $50 item, 10 minute change. Just make note which wire goes to which terminal.
I doubt that it is the control board, as the board has little to do with the stove top, but rather controls the display and the oven temperature/feedback monitoring.
Hope this helps.
Jan 14, 2009 | Frigidaire FEF366DC Electric Kitchen Range
The inner right front element will not heat up on our Kenmore Elite ceramic stove top. The middle and outer elements on the right front work fine. Why is this happening?
inner element burned out. Either burner needs replacing or control switch is bad. Take out burner and see if coil has a break in it. IF not, then switch is bad. I cannot see your repyl due to some tech issue w/ the site, so it may be a day or so before I can reply again. Please leave feedback for me if appropriate. Thanks
Nov 28, 2008 | Kenmore Kitchen Ranges
Frigidaire ceramic top self cleaning stove
Have you thought about reading the manual, it states that the heat goes off and on to maintain the proper heat while cooking, You should turn the burner off a few minutes before done because even on off the burner is still cooking while it is cooling down to go off. And you do not need to have as high of heat to cook that's what so great about this ceramic tops you save time and energy.
Jun 26, 2008 | Kitchen Ranges
How to change element
First unhook power then remove 2 screws under front of top. You may have 2 more on hinges in back. Remove element support from side you replacing. Remove two screws from elment. Transfer wire for wire to new element. Reinstall element screws in same number holes you took them out of.
May 09, 2008 | Frigidaire FES367 Electric Kitchen Range
Frigidaire oven heating elements **** the bed
open the bottom drawer and get the model number off the serial plate on the left hand side i think its a slide in with the controls on front
Mar 30, 2008 | Kitchen Ranges
Stove problem - outer cirlcle of an expandable element not working
You will need to call a professional these are very complicated and not easy to service, there are no fuses either. It will most likely be the element itself that has failed and they are not cheap. It also could be the switch too however it will take a person very familiar with schematics to properly diagnose it. Or you could just replace the element and switch yourself and that would most likely solve it.
Dec 26, 2007 | Cooktops
Open Questions:
Frigidaire FEF364DQ Electric Kitchen Range Logo
779 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Justin Duby
Justin Duby
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
