Question about Acer ScanPremio 1220ST Flatbed Scanner
How to get windows to see the scanner every time.
Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
Buy and install the 'Viewscan" scanner driver utility.
Then: Found that for windows to reliably see the scanner start windows, go to device manager, turn the scanner on and as it goes through its setup, right mouse click and select "scan for new devices" Windows 7 will now see the scanner right away.
Posted on Aug 11, 2014
SOURCE: driver for windows XP
pleas I woant the driver Scan Prisa 640P
Posted on Feb 11, 2009
SOURCE: ACER 620 P SCANNER
I Want Mercury Scanner 620P windows xp Driver
Posted on Mar 26, 2009
fdlixboy
  • 79 Answers
SOURCE: windows found driver software for your device but
hallo!! if your installer from the cd try to use other cdroom or dvd rom and install again... if you have other cd installer try to use it.. if your installer from your plus drive delete it and replace a new coppy make sure the installer no viruses. thank you!!!
Posted on Jul 04, 2009
technical114
  • 1851 Answers
SOURCE: Asus ScanPrisa 640UT seems to
Could you be please more clear? I can't understand if you ask for Asus ScanPrisa 640UT or Acer ScanPrisa 640UT. Maybe it's not your fault but FiXya's categories.
Waiting clarification, don't hesitate to post.
Thanks and regards
Stelios
direct fixya link: http://www.fixya.com/users/technical114
Posted on Aug 27, 2010
SOURCE: Asus ScanPrisa 640UT seems to installed correctly
For that uninstall all usb drivers from device manager then it automatic install all usb drivers .Also uninstall scanner driver from win7 then reinstall make sure driver is compatible with win7. Also make sure usb cable is fine. Then reinstalling drivers check scanner is communicate with computer or not. Let me know if you need further assistance. Thanks for using FixYa.
Posted on Aug 29, 2010
Slow start up
go to my computer choose drive c then properties go to tools and check the drive then restart..
Nov 28, 2013 | Computers & Internet
Ram upgrade pcv rs402
Perform these simple tips given below to make your start up fast & reliable:-
- Disable Firewall.
- Uninstall unnecessary programs and files.
- Run disk cleanup through system tools.
- Turn ON Windows updates and update device drivers.
- Limit start-up items and manage background running services (must use reliable program RegInOut to manage it properly.)
Nov 12, 2013 | Sony VAIO PCV-RX370DS PC Desktop
Getting Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter with an LSI20329IE Ultra 320 using a VHDCI 68 PIN TO CENTRONICS 50 PIN (CN50) CABLE
Acer ScanPrimo ST 1220ST to work with Windows 7 and a PCI host adapter works just fine I use it every day. The key is to use a third party scanner software called Vue Scan 9.0.57 and using the following start-up procedure so Windows 7 can find the scanner on the SCSI controller. First open windows device manager, then turn on scanner, immediately right mouse click in device manager and select scan for new devices. Windows 7 will immediately find the scanner. It seems that windows will only see the scanner through the SCSI interface during the scanners startup sequence. It has been a while but I believe this works with Mira Scan V4.03 as well.
Sep 22, 2011 | Acer ScanPremio 1220ST Flatbed Scanner
Scan note working (Hp Laserjet M5035 MFP)
Lets check whether windows detects your scanner
Right click My Computer > Manage > Device Manager
Under Device Manager check Imaging Devices
If there Double click Imaging Devices and check the device under that. If you find your scanner there .Then the scanner is installed properly
Now Lets try a test scan
If Windows Xp do this .
Click start > Run > Type wiaacmgr.exe press enter key
Now take a test scan
If your windows is vista / win 7 then
click start > All programs > accessories > Run
on Run window > Type wiaacmgr.exe press enter key
Hope this would work
Please rate me if you are satisfied with my answer
Mar 20, 2011 | HP LaserJet M5035 MFP Printer
I have properly connected my HP Scanjet 2400 scanner with my system and the appropriate software was successfully installed, the light is blinking and when we try to scan, it tries to start, but it...
sometimes the power management causes the scanner to act up or fail altogether.
Try: Solution: Disable power management on the USB hubBy default, Window XP tries to disable USB port when the HP Scanjet scanner is not in use to save power. The scanner fails to wake up when called. To fix this problem use the steps below:
  1. Click Start , right-click My Computer , then click Properties . The System Properties window will open.
  2. Click the Hardware tab, then Device Manager . The Device Managerwindow will open.
  3. Double-click the Universal Serial Bus controller branch to expand it.
  4. Right-click USB Root Hub , then click Properties . The USB Root Hub Properties window will open.
  5. Click the Power Management tab.
  6. Remove the check from the Allow the computer to turn off this device to save powercheck box.
  7. Click OK , and close USB Root Hub Properties window.
  8. Close any other open windows.
Aug 28, 2010 | HP ScanJet 2400 Flatbed Scanner
Canoscan LiDE 100 on WinXP loaded drivers+software from disk
Have you tried going to the Devices Website for any CURRENT SOFTWARE UPDATES/DOWNLOADS?
Jul 05, 2010 | Dell Inspiron 1525 Laptop
My HP2575 all in one will not install in to my laptop which is windows vista basic
driver specific to vista and a critical update for unexpected uninstalls... Click Here
I also found this info that you may find helpful if having issues with the scanning after you do get it up and running...
the scanner cannot send image files to computer. So Please follow the below steps to adjust the printer driver.
1. Unplug all cables from the scanner and the scanner cable from the computer
2. Click "Start", type "APPWIZ.CPL" (without quotation marks) and press the "Enter" key.
3. Highlight any software or program related to the scanner and click "Change/Remove" to remove the driver.
4. Click "Start", type "DEVMGMT.MSC" (without quotation marks) and press the Enter key.
The operation requires administrative privileges, please click "Continue" when the User Account Control dialog-box appears.
5. Click "View" and select "Show hidden devices".
6. Click the "+" next to “Imaging Devices”. This will show all Imaging Devices previously and currently connected to the computer.
7. Right-click on the Scanner Band scanner name and left-click on “Uninstall”. If the scanner is listed more than one time, uninstall all occurrences of the scanner.
8. If you see “Other Devices” in the device manager list, click on the “+” to view the list of Other Devices.
9. Right-click on the other device and left-click on “Uninstall” from the list. The scanner may be listed as any of the following:
- USB Scanner
- USB Device
- Unknown Device
- 1200 DPI Scanner
- (Your Scanner Model)
10. Reboot the computer.
After that plug the scanner cable to the computer and turn it on.
May 27, 2008 | HP Office Equipment & Supplies
No drivers found
Go to Control Panel >> Device Manager, look for the scanner in 'Device Manager' under 'Imaging Devices'
If it is not installed properly and working there should be a yellow triangle with an exclamation mark inside it next to the scanner name.
Whatever it says, right click on it and select 'Uninstall' and allow it to be uninstalled.
Remove the USB lead from the scanner.
Re-boot the Computer.
Once windows appears and is ready to use, re-install the scanner driver do not plug in the scanner yet!.
Once it has finished installing, re-connect the scanner USB lead.
Windows should install the drivers and tell you the scanner is ready to use.
Apr 24, 2008 | Canon CanoScan 4400f MultiFunction Color...
Microtek Scanner installation issue
If running XP SP2, then try clicking Start > right click My Computer > properties > Hardware tab > Device Manager button > expand Imaging devices > right click on your Microtek ScanMaker > uninstall > Re boot > and let XP pick up the device and let the found hardware wizard configure it.
I have seen plenty of hardware that when following the devices manufacturer's instructions for install, such problems as you're having occur and XP SP2 usually will cure it, though you may still need the device manufacturer's CD (for the driver) in your optical drive.
This link: http://support.microtek.com/downloads/bymodelname.phtml?viewtype=2&srch_in=ScanMaker+5950&frmsearch.x=10&frmsearch.y=11&frmsearch=Search&frm_rqst=2&axn=1 will allow you to select between the 5950 and 5950 Pro then on the next page you will be able to download the latest XP driver for your Scanmaker among drivers for other Operating Systems also.
I hope this helps, and Good luck.
Mar 21, 2008 | Microtek ScanMaker 5950 Flatbed Scanner
Error code 2019
Step 1 - Verify the scanner's power and connection
  1. Verify that the scanner is turnned on
  2. If the Check or Ready light on the scanner is flashing, click VIS1023 - Check Light Blinking on ADF Scanner for more information
  3. Check that the USB cable is connected to both the scanner and the computer
    • It is recommended that the scanner be connected directly to the back of your computer with a 6 foot or shorter USB cable
Step 2 - Redetect the scanner in device manager
  1. Turn the scanner off
  2. Click Here and select "Run" or "Open"
  3. The Windows Device Manager will open
  4. Go to "View" and choose "Show Hidden Devices"
  5. Click the "+" next to "Imaging Devices". This will show all Imaging Devices previously and currently connected to the computer.
  6. If listed, right-click on the DocuMate 510 then left click on "Uninstall"
  7. If asked to confirm the uninstall, click "OK"
  8. If the scanner is listed more than one time, uninstall ALL occurrences of the scanner
  9. IF you see "?Other Devices" in the device manager list, click on the "+" to view the list of Other Devices
  10. Right click on any instince of the scanner in this list then left click on "Uninstall"
    • USB Scanner
    • USB Device
    • Unknown Device
    • DocuMate 510
  11. Once the scanner has been completely removed from Device Manager, turn the scanner back on
If there is no Found New Hardware message when the scanner is turned back on and the scanner is not listed in Device Manager under Imaging Devices or Other Devices, this typically means the scanner is not communicating correctly with the computer. Try plugging the scanner into a different USB port or using a different USB cable.
Jan 08, 2008 | Xerox DOCUMATE 510 Flatbed Scanner
Acer ScanPremio 1220ST Flatbed Scanner Logo
85 people viewed this question
Top Acer Office Equipment & Supplies Experts
jasbo
jasbo
Electro Med Services...
color wheel light...
Are you an Acer Office Equipment and Supply Expert? Answer questions, earn points and help others
