Question about GPS
Where is reset button on air ease airconditioner
Frigidaire airconditioner compressor keeps running after turning the unit off
Thanks for the post, friend!
I understand that the compressor continues to run after your Frigidaire air conditioner has turned off. From that information it sounds like there could be a possible issue within your control panel or relay. I would recommend a reset on the appliance, to perform a reset unplug the power cord you will see a test button, push that button and you will hear a click. You would then press the reset button you will hear a click again signifying that the appliance has been reset. Then plug your air conditioner back in. If you continue to have an issue with your compressor I would seek assistance from a professional. Hope this is helpful. -Matt
Aug 12, 2014 | Frigidaire 18,500 BTU Window-Mounted...
Tried using display button on steering wheel and airconditioner will not cool anymore
Seems like the air con settings have changed and the air con is only running on fan only?? See if there is any info in the Owners book as to resetting the controls.
Aug 23, 2013 | 2009 Toyota Highlander Limited
LG airconditioner with reset botton on power cord 220. After a lightning storm. Airconditioner wont come on.There is power to the outlet but no power in the cord past the reset unit. should I replace that...
Yes replace reset cord. also see an electrician about a surge suppressor for your home this one item will save you alot of money and appliances
Aug 24, 2012 | Heating & Cooling
My air cond is running but the air is not coming out of the vents, is there a reset button
Here is a tip about troubleshooting your air conditioner...
There are many things that can cause your air conditioner not to cool...
AirConditioner Trouble - Review the Possibilities
heatman101
Jul 06, 2011 | Amana Heating & Cooling
House is getting hot....Thermostat seems to be dead...is there a reset button
heatman101
Jul 01, 2011 | Refrigerators
I am looking for the reset button on my Amana heat pump the outside unit fan inside operates but the compressor does not run
There are no simple reset buttons for that...
Here is a tip about troubleshooting your airconditioner...
heatman101
Jun 11, 2011 | Amana Heating & Cooling
My LG airconditioner keeps on blinking even if it has been switched on for some time.
sounds like the filter needs to be removed and cleaned. it should be easily removable from the front. after you have done this reset it either by removing power for about ten minutes or there should be a reset button right on the control panel
Nov 03, 2010 | LG LSC091PMA Split System Air Conditioner
Mitisubishi Ducted Reverse Cycle AirConditioner
1.check blower fan motor.if blower fan motor donot work then compressure trip after 5 to 10 minitue.
2.make switch of airconditioner n reset again.
Feb 11, 2008 | Mitsubishi MS12TN Air Conditioner
GPS Logo
21 people viewed this question
Top GPS Experts
Will Halftowaite
Are you a GPS Expert? Answer questions, earn points and help others
