Question about Microwave Ovens
How do I take off the door of GE Profile Oven PT916SOM1SS?
  • 4088 Answers
SOURCE: ge profile microwave oven runs when door is open
Good way to cook yourself! It has to be a stuck door interlock switch--the case needs to be removed to get at the switch. It could be either the mechanism that operates the switch or the switch itself is bad. The switch normally makes a click when the button is pressed. Unplug the unit when the case is removed.
Posted on Jul 16, 2009
  • 18 Answers
SOURCE: GE profile spacemaker mircoware oven change interior light bulb
Check behind the grill on the front top of unit. you can remove it by takign out a few screws from the top. There may be an access door there, if not unit would have to be pulled down and the case taken apart.
Posted on Dec 02, 2009
MicrowaveSvc
  • 9098 Answers
SOURCE: I have a GE profile spacemaker microwae oven. The
Yes. You can find links to helpful exploded view diagrams and part ordering help here.
I'd recommend that your bookmark this link to your favorites.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, & testing.
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If yours is a counter top model, you have to remove the outer cover, and the mini-manual will probably be in an envelope inside the wrapper.
Posted on Jan 10, 2010
MicrowaveSvc
  • 9098 Answers
SOURCE: Have a GE Profile Microwave Oven Model JE1540. the
See these files:
http://031d26d.namesecurehost.com/mwd/safety.txt
http://031d26d.namesecurehost.com/mwd/disassembly.txt
http://031d26d.namesecurehost.com/mwd/doorsw.txt
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Jan 17, 2011
  • 4 Answers
SOURCE: G.E. Profile Oven...model PB 970
Press the off button and hold for 5 seconds if this does not work un plug and it should reset.
Posted on Feb 14, 2011
My GE Profile Jvm1870sk03 microwave built oven does not work. There is power, the clock, timer works. If I press the button to heat the clock shows it's going on but there is no heating process go
Most likely door switches. Companies these days use switches with small 3/16 terminals and they tend to get hot and make the switch go bad. When I replace them I put in a 20 amp rated switch with 1/4 inch terminals, and a short section of better wire to the switch. If you make better connections it stops the wires from getting hot and the switch will last a long time.
Aug 24, 2017 | GE Microwave Ovens
GE Profile Advantium 120 oven: Clock is on and stuck, unit will not work otherwise.
Unplug the microwave oven for 60 seconds to reset microprocessor, hopefully this will cure the problem.
Jul 05, 2012 | GE Profile Advantium 120 Wall Oven
Jvm1870sk04 GE profile microwave will not shut off unless the door is open. Unplugged , pushed off/cancel continues to run with door closed. Any solutions?
Hi, Main control board bad...
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
Sep 19, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My ge Profile microwave oven will not heat! It turns on but doesn't heat... Any idea?
I had the same problem. I fixed it by replacing the primary (upper) door switch. The switch is about $50 from repairclinic, but it beats scrapping the whole oven. Tips: - If you don't have a torxx screwdriver, you can use a regular small flat screwdriver that you wedge between the torxx pin and the side grooves. - When tested standalone with an ohmmeter, the switch seemed to be healthy, but when you press on the pin a bit more it fails. I guess cycling the door eventually damages the switch.
May 15, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE Profile microwave oven will not heat! It turns on but doesn't heat... Any idea?
Hello:
It could be bad door switch or loose door switch mount . There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
or it could be problem with the control panel .
good luck .
please rate !
Mar 28, 2010 | GE Spacemaker JVM1640SJ Microwave Oven
My GE 1660 profile microwave oven will not cook or rotate, but the timer reduces in time. I have tried to gently press up or down on the door in case it is a door latch issue with not change. Also it keeps...
Check the door safety interlock switches. If they are burned (because you frequently open the door while the oven is running) they tell the magnatron that the door is open (forget what you know about the door) and not to run that magnatron (which produces the microwaves that actually heat the contents of your oven).
Check the switches with a ohm meter. Remove the cover to find the switches near the door latches.
Thank you for your interest in FixYa.com
Dec 26, 2009 | GE JE1660 Microwave Oven
Dec 02, 2009 | Microwave Ovens
GE Profile Spacesaver XL Sensor Microwave
You have a bad door swicth or a bad wiring connector to one of the door switches... secondary swicth or the door sense switch.
Dec 16, 2008 | GE Advantium 120 Convection/Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Microwave Ovens Logo
23 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
