Question about Singer Electronic Steam Press
My euro pro electronic press iron, bot 2000 is constantly beeping in appropriately, should I dump or try to fix switch??
Was at repair for not heating, fixed loose wire, now beeps uncontrollable, occas light comes on, gets sli warm, back to beeping, should I dump it or try to fix switch?
3 Suggested Answers
SOURCE: breville ir23 steam iron
My electronic steam press has been performing perfectly until yesterday. I can not longer get it to turn on? Any suggestions? carolb745
Posted on Oct 30, 2008
SOURCE: my singer magic press 4 iron comes on but the plate will not heat
Not sure how tech savvy you are, but the service manual can be downloaded at http://www.parts.singerco.com/CPpartCharts/Presses/MP4.pdf
UNPLUG THE IRON. Figure 7 shows the wiring. Note that the lamp inside the switch is shown incorrectly. It should be on the other side of the switch. Also the 2 wires running down to the fuse are the red wires. The red wires are interchangeable. Use a continuity tester between wire 2 and wire 3 to test the thermostat. Should be open when dial is turned to the left. Closed when dial turned to the right. Also check continuity on the heaters. If everything looks good but it still doesn't work, replace the circuit board.
Posted on Nov 05, 2009
Euro Pro Irons: Less than a year old stop heating up.
hello,
some time no part of our property go bad but what will need is to service them from there dysfunction
the problem of your iron could be from the element and the wire ,the element is the heat provider while the wire is the power supply from the electric
But the fact is that ,the problem of your iron is disconnection of element from the wire what you need to do fix it to unscrew your iron and trace the wire down to the element and see the disconnection am toking about and fix it back
thank you and thanks for using fixya.
May 31, 2010 | Euro-Pro Shark GI490 Iron
Constant steam and water coming out of the bottom of the iron
Try using different water...
Here is a tip that will help you with that problem...
My Steam Iron is Leaking Water
http://www.fixya.com/support/r5301301-steam_iron_leaking_water
heatman101
Oct 23, 2009 | Euro-Pro G1490 Continuous Iron
It shuts itself off
The SHARK ELECTRONIC Iron is equipped with an electronic auto-off. The electronic auto-off switches the iron off if it has been left standing unmoved in any position (sideways, flat or upright) for approximately 7-9 minutes. A red light on the LED display panel will flash when the iron switches itself off. (Fig. 7) To switch the iron back on, just shake the iron side-to-side several times.
Jul 31, 2009 | Euro-Pro Shark GI490 Iron
Burned out and Leaks
Without the reciept and the fact that it now dosent work, I think you dump it and never buy another of thier products. You could write to them first, but you are really on your own.
Good luck
Feb 12, 2009 | Euro-Pro Shark GI490 Iron
Euro-pro ep8001 steam iron
I found the fix myself.
I found a switch without the light and it works
Sep 08, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro pro craft n sew 959 iron
heatman101
May 16, 2008 | Euro-Pro Craft N Sew 959 Iron
No steam
It appears that your rocker switch is broken, I am attempting to find a source for the switch and the screw driver that removes the screws holding the unit together
Jan 03, 2008 | Euro-Pro Steam Generator EP8001 Iron
Euro pro steam iron model G6118H
the preasure tank inside the iron could have a hole or the holes at the bottom of the iron are clogged up and needs to be cleaned.good luck
Jan 16, 2007 | Euro-Pro G6118 Iron
Singer Electronic Steam Press Logo
35 people viewed this question
Top Singer Irons Experts
Chance Miller
Are you a Singer Iron Expert? Answer questions, earn points and help others
