Question about General Electric GE Security Digia II DVR
Can't run active x download on windows 7 64 bit
I have sony vaio laptop window 7,64 bit with 500 gb harddrive having only one partition = c i want to make 4 partitions how can i make it without losing my recovery data default from manufacturer
Type Computer Management into the search box above the start icon. Select Disc Management, select the drive name you wish to adjust and right click on it. Select Shrink Size and select whatever size you require. When complete format the new partition.
Dec 24, 2014 | Sony VAIO Computers & Internet
Tip
Want to Backup and check your Windows Activation use WinKeyFinder
The latest version of this program is v1.73 released March 2010 I use this to encrypt my Windows Activation keys the v1.72 is great for backing up and restoring your wpa.dbl activation file
  • Supports Windows 98, 2000, XP, Vista, 7 and more - 32 bit
  • Supports Windows XP, Vista, 7 64 bit versions
  • Supports MS Office 2000, XP, 2003, 2007, and 2010 - 32 bit and 64 bit
  • Many Enhanced features
  • Removed the title RC from it.
This New version has the following Features Removed that were in version 1.72RC:
  • Removed Password Generator
  • Removed Activation Backup/ Restore
  • Many Internal features
I liked it so much I created a U3 installer file for v1.72 to backup my activation files for future installs download the installer HERE from my Sky Drive make sure that you also save a copy of your Volume Serial for the Primary Drive Partition this will change each time you install another copy of the DOS or add a Hard Drive
on Mar 31, 2010 | Microsoft Windows XP Professional
How do I know if I am running MS Office 2013 32 bit or 64 bit?
open Microsoft word 2013
click on file
select account
then click on about word
24853651-3wpqtp00zodw0jp5gb00c3yk-2-3.jpg 24853651-3wpqtp00zodw0jp5gb00c3yk-2-6.jpg
Jul 21, 2014 | Microsoft Computers & Internet
Logithec attack3 devices not detected
Disconnect the divice uninstall the driver restart the laptop and then reinstall the driver again restart the laptop then connect the device it works.
Apr 03, 2014 | Video Game Consoles & Games
Install spyware files
connect the phone using the usb lead to the bluetooth connection on the phone once connected a found new harware should activate on the screen
if it does not activate you might have to install it manually
click start all programs accessories windows explorer
you should see all of your drives C: hard drive D: your cd/dvd drive
your phone might be listed as a mass storage device
click start control panel administration tools computer management device manager look for any yellow question /exclamation marks ? ! or ared X
this means the driver will need to be installed
right click on it select update /install driver
if your computer came with a mother board disk the drivers could be on it
if you still cant find your mass storage device you might need to download a bluetooth driver
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetoothview/3000-2648_4-10800572.html
Runs in the background, and monitors the activity of Bluetooth devices around you. The BluetoothView application was designed to be a small tools that runs in the background, and monitors the activity of Bluetooth devices around you.
http://download.cnet.com/%7Bvalue=http://www.download.com/bluetooth-driver-ver-5/3000-2110_4-149801.html
to suit multiple usb devices
· Operating system: Windows 95/98/2000/XP/2003/NT/XP 32-bit/AMD 64-bit/2003 32-bit/AMD 64-bit
then download your spyware files to your cell phone
hope this helps
Aug 07, 2012 | Computers & Internet
Windows 8 compatible
Windows 8 Release Preview works great on the same hardware that powers Windows 7:
  • Processor: 1 gigahertz (GHz) or faster
  • RAM: 1 gigabyte (GB) (32-bit) or 2 GB (64-bit)
  • Hard disk space: 16 GB (32-bit) or 20 GB (64-bit)
  • Graphics card: Microsoft DirectX 9 graphics device or higher
Additional requirements to use certain features:
  • To use touch, you need a tablet or a monitor that supports multitouch.
  • To access the Windows Store and to download and run apps, you need an active Internet connection and a screen resolution of at least 1024 x 768.
  • To snap apps, you need a screen resolution of at least 1366 x 768.
    be careful not to copy it over the current operating system you might use another hard drive or create a partition
    if you download the review
    http://windows.microsoft.com/en-US/windows-8/download
    hope this helps
Jun 20, 2012 | Computers & Internet
Usb port on presario F500 quit working, they are seen by device manager but will not reconize a flashdrive when incerted, a mouse or any thing else. Using win 7,64 bit t3500 cpu.
This should be pretty easy to fix. I have seen this many times before. Here's what to do:
Go into device manager and expand 'universal serial bus controllers'.
Start at the very bottom, and start deleting the usb root hubs one by one. You will lose your touchpad control at some point, as the touchpad is actually a usb device. One of thwo things will happen.
1. The usb hubs will automatically be re-detected and re-installed.
2. You will just lose touchpad control after deleting one of the root hubs. If this happens, then shut down using the power button, and restart. Th usb hubs will be reinstalled once you log back into windows. Please let me know if this doesn't fix it.
Joe
Apr 07, 2012 | Compaq Computers & Internet
No bluetooth device appears in my computer
which bluetooth device mobile ph Ipad iphone navigator.??????.......
first connect the blutooth device then you must turn on the make this active or and search for any bluetooth devices in both the bluetooth device and your computer the blutooth device should automatically search for any devices or you might have to do it manually click start click on my computer you will see your c:drive cd/dvd drives and any usb drives and you might see your bluetooth device
http://majorgeeks.com/Bluetooth_Driver_Installer_d6752.html
This small freeware utility will try to install generic Microsoft driver for your bluetooth adapter. The program is based on a widely known method of patching %WinDir%\inf\bth.inf file.
hope this helps
Jun 24, 2011 | Sony VAIO SURE MODELS VPCF13WFXB CI7173...
How Am I going to Activate My Windows Vista
Hi, If you have original product key.You enter thr product key when prompted.If you don't have original operating system, then follow the below steps. 1)go to www.bittorrent.com 2)download the bit torrent software (<3mb size) and install it. 3)Go to the below link. http://thepiratebay.org/torrent/3631799/Vista.All.x86.OneClick.Activator.4st.March-CLoNY 4)Click "download this torrent " link which will be in green colour. 5)open the downloaded torrent file and it will prompt to download the"clonysoft windows vista one click activator".Give ok 6)extract the downloaded file and run the software.Your windows will be activated. 7)if your download link is slow try searching in google as "clonysoft windows vista one click activator"
Nov 25, 2010 | Computers & Internet
General Electric GE Security Digia II DVR Logo
Top General Electric Home Security Experts
Lawrence Oravetz
Are you a General Electric Home Security Expert? Answer questions, earn points and help others
