Question about Sirius Hoods Sportster SP-B1 Boombox
Antenea not detected - Sirius Hoods Sportster SP-B1 Boombox
Why doesn't the am radio work but the fm does
Somehow it sounds like your antenea cable has been unplugged
Aug 15, 2014 | Audio Players & Recorders
Home update
Is the signal Strength when your outdoor is high??...If not then there can be a problem with your antenea...Thank you..
Please post back for further assistance..
Kind Regards!!...
Jul 31, 2008 | Tomtom One Europe v2 GPS Receiver
My garmin iq 3600 has died I left the gps antenea put and it will n0t take a charge.garman has stopped repairs on this model
I suspect that your Lithium polymer battery is going bad. If the battery is more than two (2) years old, then the ability to hold a charge has depleted and it will be gone after about three years total. You probably need to replace it. see: http://www.newpower99.com/ProductDetails.asp?ProductCode=GARMIN+NUVI+360&Show=ExtInfo&gclid=CPy2jceQ26UCFdk65QodMmeTyQ
for a possible replacement, or go on line and search for your particular battery model
Dec 07, 2010 | GPS
Hello, My radio in my 2006 Xterra only works sometime and the other times the radio does not seem to have any reception and will not pick up ant stations
sounds like the radio antenea is loose in the back of the unit.
I suggest removing the radio and checking connections.
On the other hand... it could be set to LOCAL (only pulls local channels) instead of DISTANT ( pulls less strong signals).
Sep 28, 2010 | 2006 Nissan Xterra
Antenea cable in back of tv is loose. When watching tv the picture will get small
The antenna jack may be loose, but that's not your issue. The screen image shrinking is an indicator that the tube is going bad. If this is a plasma or LCD then you have a circuit board issue. Time for a new tv, I'm afraid.
Jun 09, 2009 | Philips Televison & Video
Magnavox DTV converter shows no signal
do you have your converter box hooked up to an antenea? If so, if you move the antenea, then you may have to reprogram the channels through the converter box. This happened to us. So, we played around with the antenea until we found the most channels came through and marked the area around the antenea (you can use tape, or if you do not care a permanet marker like us. Note our antenea sits on top of our tv.) We have not had any trouble since. We marked the place for the antenea, in case someone moves it or so we can try to get more channels when the final switch happens. We gain a lot of stations, but lost only one.
Hope this helps,
The Gordons :)
Jan 06, 2009 | Insignia Digital-to-Analog Converter for...
On off problem
removed any magneting material near your tv or any electronic material near you tv specially speakers,, turn it on for 1 min. then turn it off for 5 mins. 4 times..
Jan 01, 2008 | Televison & Video
White lines in tv whats the problem??????????????
Check the cable that you are using. If it's a "single" shielded cable, it maybe letting in "air" frequencies, like you have an antenea hooked to your TV. Especially if you live in a city that has several Tv stations near you. The cable could be to old and has breaks in it, or not grounded properly.
Dec 22, 2007 | Apex Digital AT2702 27" TV
No signal from either antenea A or B
enter the setup menu and select auto programed function,
Nov 15, 2007 | RCA F38310 38" TV
Sirius Hoods Sportster SP-B1 Boombox Logo
Top Sirius Audio Players & Recorders Experts
John
John
Scott Thompson
Are you a Sirius Audio Player and Recorder Expert? Answer questions, earn points and help others
