Question about Hannspree HANNS-G 19" Widescreen Monitor
Monitor says: no signal input check video cable Even though the computer is on and hooked up
  • 94 Answers
If it says so....it indicates that the display card is gone bad. check with the display card...
or try inserting New Graphic card or PCI VGA card... works for sure....
Posted on Jun 23, 2009
2 Suggested Answers
venexcsd
  • 1185 Answers
SOURCE: monitor says: no signal input check video cable .
Sounds a bit bland but either the monitor has failed or the video card
Only test is to plug your monitor into another system and see if it comes to life
If it does then your video card has expired.
If it is part of the motherboard then the easiest option is to buy a replacement which plugs into the AGP slot
They are dirt cheap unless you are into gaming when the sky's the limit
Posted on Jun 27, 2009
No input signal on monitor-not connected to tv-computer works fine except for the no input signal
no input or signal means that the monitor is not receiving any signal from the CPU and if the power light is amber then and the cpu works fine then there could be a problem with the cable connecting the CPU and the monitor ...check the cable.
Mar 03, 2014 | Dell Computers & Internet
Samsung syncmaster sa350 start computer up then in the top left corner it shows a graphic that says hdmi, then the computer screen goes blank and the power button just blinks red continueously with a blank...
Is your computer connected via the HDMI cable? If not pull up menu and change to another input type. If it is HDMI, check cable ends. You can test by plugging into a Blue ray player and see if video plays on monitor as a test method to verify video coming from computer incase your video card has died for some reason..
Your monitor is going into sleep mode since it can not see an HDMI signal coming across the input. Check your cable though.. sounds like the biggest culprit to me.
Jan 29, 2014 | Smart Modular SV3170A
My gateway t-6330u hdmi cannot connect. It shows the the external monitor is connected but my TV set shows no signal. and it worked perfect couple month ago
Here is something you may or may not have tried:
With the HDMI cable hooked up to your TV set, reboot your computer. in many cases (even though it may be shown as hooked up) the video card will not send a signal on a specific output unless there is something plugged into it on bootup. Once that has been done, verify that you are on the proper HDMI setting on your TV. Many TVs have multiple HDMI inputs, so it is possible that there is a signal and it's not switched to it.
Sometimes its about going to the basics.
Nov 03, 2009 | Computers & Internet
Monitor says: no signal input check video cable Even though the computer is on.
Jun 27, 2009 | Hannspree HANNS-G 19" Widescreen Monitor
Computer not booting up
Could be one of two things:
1. Signal cable from monitor isn't hooked up. (either monitor end or computer case end)
2. Video card in the computer is damaged and not putting out signal. This is unlikely though as usually this will trip the motherboard into beeping when you turn the computer is turned on.
3.
Jan 15, 2009 | E-Machines eMachines Desktop PC
Dell m992 crt monitor
If it's getting no signal, make sure the monitor is set for the correct input. This would be either analog (if your cord has blue ends) or digital (if the connectors are white). Depending on wt yhat your monitor is, a button on the monitor will help you set that. If it's set for the correct input signal, then switch out a different cable to see if perchance you have a bad cable out of the box. If there is another PC or laptop setting around, plug your monitor into that to make sure it's good and maybe even plug THAT monitor into yours to make sure there is nothing wrong with your video card. Let me know what transpires. If this takes care of things, please help me out by rating it accordingly.
Jan 13, 2009 | Dell M992 19" CRT Monitor
No RGB imput signal
You need to change the input signal, get into the menu on your monitor and change the signal from rgb to dvi, hdmi or vga dipending on what cable you using for connection.
There is NO rgb connector on that monitor
Good luck
Dec 05, 2008 | Balance CM2015 15" LCD Monitor
How to hook this monitor onto my computer
You would have got a CD with this moniter..
we ahve install that cd..
and its better to check the cables first which would be the
VGA CORD that is blue in colour which connects your moniter with the tower.
We can check the connections with the moniter for the Tower and then install the cd.
Feb 06, 2008 | Computers & Internet
Hannspree HANNS-G 19" Widescreen Monitor Logo
580 people viewed this question
Top Hannspree Computers & Internet Experts
 Chuck N
Chuck N
Are you a Hannspree Computer and Internet Expert? Answer questions, earn points and help others
