Question about Home Security
II have a 8 channel sunluxy h264 network dvr.i have installed the hard drive and connected 6 cameras.i also connected video out to my tv.i have turned on the dvr and i can clearly see the six pictures
How do i login to my sunluxy h264 network dvr????to manual says i have to login when i boot it up but i do not see anywhere to login only the pictures from the 6 cameras connected come up on my tv that i have connected from the video out.The manual does not tell me how to login only that i need to.please help...thank you very mutch
ford_67
  • 34 Answers
SOURCE: camera picture has lines no monitor no clear
May be bad connection or need larger gauge wire.
Posted on Aug 24, 2008
ashcreekllc
  • 794 Answers
SOURCE: I am attempting to repair a Digimerge VCE 308301
The problem did not have anything to do with the DVR (Digimerge VCE 308301). It did however, have everything to do with the cameras' power supply system.
First, I contacted the company's (Digimerge) tech department; and they were of no help since the DVR system is obsolete. There are no replacement/spare parts available; e.g. mainboard and daughter boards...and of course, they don't have schematic diagrams for the DVR either. And due to its obsolesence- there is no tech support. (It makes me wonder why, though, how security and electronic vendors can in good conscious sell this obsolete model DVR for $1,400 and upwards of $2,200.00 to the unsuspecting consumer/end-user.)
Since I was able to boot up the DVR system and access the BIOS menu; and considering that the screen was showing that it was in record mode- and the system BIOS was keeping the proper date and time, I believed that there was something else going on with the security system.
I contacted the customer and went out to their home- as I was about to hook up the cameras to each input behind the DVR- by happenstance, I checked the power supply panel to make sure that the power supply had been turned off (which the home owner failed to do). Having turned off the cameras' power supply, I then made all my camera hook-ups to the DVR. When I turned the power supply to the camera system on, I was able to get a video signal, hence a nice clear picture. I did check the voltage draw on each power terminal at about 12.5 vdc and a visual check on the infra- red led's on each of the security cameras were lit.
Problem solved, right!?...WRONG!
Several hours later, I received a call from the homeowner that his security system was not working again. The first thing I noticed as I pulled into the customer's driveway was that all the cameras' infra-red led's were out. I immediately placed my volt meter on the output side of the transformer at each of the cameras' power terminal- and waddya' know- I was barely reading over 1 vdc. Apparently- over time, the transformer starts to overheat and the voltage drops out. After it cools down though, the voltage resumes to 12.5vdc to power up the cameras.
This is my first experience working on a secuirty camera system so I hope this has been as much of a learning experience for you novices as it has been for me!
Posted on Oct 02, 2009
SOURCE: Hi I have a new Swann DVR 4 - 1000 secrurty camera
Having the same problem, anyone found a fix yet?
Posted on Jul 12, 2011
levy354
  • 6 Answers
SOURCE: Certain cameras are showing the same video.
First you need to isolate the problem. Step one - make sure the video from the cameras is correct - use a monitor and check each input separate. If the video is correct, use one camera and start from input one on the DVR and check all inputs - in other words plug your camera in input 1, check for video to make sure is correct and shows up in the right place, than go to input 2. This way you check your DVR cards. If the video shows up, but in the wrong place - check the settings on the DVR - you might be able to change the physical input in the viewer.Or you might have a bad DVR.......do a search for DVR Doctors in Google - in case you need repair.
Posted on Feb 20, 2012
  • 58 Answers
SOURCE: how do i login to my sunluxy h264 network dvr
Please watch the above video for setup details or visit the product support team at http://www.sunluxy.com/?p=97
Posted on May 14, 2014
Hi i have lost my remote control for my CCTV system a Sunluxy H264 DVR 4 camera system i cant get to turn the machine on now so my system is useless. Any ideas please
If it's connected to you network you can down load a number of android apps that can connect to the live feeds assuming you know the logon and password. meye is a good generic app.
Mar 30, 2017 | The Home Security
My swann 8-camera system, each night goes into the "no video Mode" each night and comes back on in the daylight.
It's going into ir sound like you are not supplying enough power to the cameras or you might have a timer on you system
Oct 11, 2016 | SWANN H264 8 Channel Dvr W500 Gb Hard...
My Night Owl camera system is on,but there is ni signal on tv.
Has to be a connection on video cable or channel on tv your trying to view the camera on
Sep 02, 2015 | Night Owl Optics 8 CHANNEL H264 DVR WITH 4...
H264 password reset how do i reset
After forgetting my password, I tried everything. Literally. And this is the Only way I could reset it, and regain control. First you must kill the power to the DVR by unplugging it, or turning off it's surge protected power strip, wait 5 seconds, then reconnect power. This basic reset prepares the DVR to accept this admin password reset. Upon startup, the username should automatically be admin, if not then type the word admin in as username. then all you have to do is type in 1 2 3 4 5 6 for your password, then click enter, then log on. And Hallelujah!!! your back in!
Jul 21, 2014 | Digital Peripheral Solutions QSee QSC26416...
How do i find the defult sender password to set up my H.264 DVR
Open up the password browser and enter...519070 that's the Default. I have years of experience with the night-owl system.
INSKIP
Jun 07, 2014 | Night Owl Optics Night Owl Scorpion 168500...
May 14, 2014 | Video Accessory Corporation Home Security
H264 dvr password
I forget the password of my sentient cctv h.264 please help me
Jan 12, 2014 | Night Owl Optics Night Owl Scorpion 168500...
Home Security Logo
46 people viewed this question
Top Home Security Experts
Lawrence Oravetz
Are you a Home Security Expert? Answer questions, earn points and help others
