Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
What causes PC to shut down during idle? - Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
    Problem Solver:
  • 60 Answers
This might be down to the power settings, by default the hard drive is set to shut down after 15 mins of inactivity, to check open control panel and select Power Options, this will show you the current plan settings, click the Change plan settings and then Change Advanced power settings, expand the Hard disk option and then Turn off hard disk after, this will show the time this can be set to 0 which will stop it shutting down.
You can also adjust display settings etc. in this area at the same time.
Posted on Oct 08, 2014
What Could Cause My Computer To Shut Down For No Reason?
What brand of pc is this? Download a diagnostic program to test internal functions. Sounds like maybe a motherboard or power supply issue.
Jul 28, 2014 | Dell Inspiron 530s Desktop Computer
Shuts off during Idle
Hi JESSE,HERE'S WHAT IT SAYS ABOUT THE IDLE CONTROL VALVE,AND HERE'S A LINK TO THE PART.
  • Regulates the amount of air entering the engine during idle
  • When not replaced, vehicle could experience high or low idle, engine dies at idle and/or severe high idle possibly causing internal engine damage and safety issues.Here's a link to the idle control motor.
Nov 05, 2013 | Chrysler Concorde Cars & Trucks
2500 HD chevrolet low idle problem
Engine stalling and rough run issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner (do not use carburetor spray cleaner!) from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
Sep 03, 2012 | Chevrolet Silverado 2500HD Cars & Trucks
Stalling during deceleration
Usually a sign of a faulty idle air control valve or a dirty throttle body.
Jul 13, 2012 | 1993 Ford Bronco
Toyota 92 model no idle upon initial start up but idle when engine is warm
Engine stalling issue at low speeds
This problem is commonly caused by a dirty automatic idle speed control valve and throttle valve. Buy a can of throttle valve cleaner from NAPA or Carquest (made by CRC chemicals) and spray it into the air intake while the engine is running, use up about 1/2 the can, engine will try to stall hold the speed up, shut it down and let it soak for 30 minutes, restart and blow out the remaining fluid, shut it down and disconnect the negative battery cable for 5 Min's to reset the base idle control
May 30, 2012 | 1992 Toyota Corolla
I use a Belkin Surge Protector UPS 600VA, and run Win 7 64 bits. In "System Configuration", "Services" tab, Belkin APmonitor is stopped, and Belkin APMRMI is running. Nothing shows on...
2 scenarios will either play out at the end of the day:
1. During power outage, your UPS will continue to supply backup power for the number of minutes.it is built/designed to do for your PC after which it shuts down and your PC due to lack of power shuts down too.
2. if you've programmed your PC to shut down after say a short period it idles, your PC will shut down even though your UPS is still fully operational.
A third approach is to sync the situation/scenario you envisage by powering off your UPS power supply at the mains/wall receptacle.
Watch what happens next by leaving your PC idle but still connected to the UPS still powered on (but without the mains power supply to it)
Oct 06, 2017 | Computers & Internet
I am unable to access the internet from sleep mode Can only get on internet from shut down mode
Three possible causes of sleep mode. first, an extensive screensaver with password lock prevents display. A condition that is observable as a blankscreen also known as sleep mode. Second, a computer power saver settings that shutsdown during idleness. Third, An improper shut down of the computer would have caused a sleep mode to save the system data files.
Restoring the computer to regular functionalioty
First solving predictable sleep mode settings
1. A movement of mouse pointer across the screen should reestablish unprotected password modes
a. password protected sleep mode would display an promp message requiring key code soon after the mouse pointer has changed direction
sloving unpredictable sleep mode settings
1.A computer power saver, screen saver, or splash screen displays prevnting programs acess would require manually powering off the computer system.
a. A manual power back on of the system should restore to program functionality mode
important notes
1. contact expert technical assistance
Dec 20, 2010 | HP KQ495AA Pavilion A6500F Desktop PC
My car threatens to die during idling...the rpm drops down low and then goes back to normal. It started doing this during driving too. I just had the fuel filter and a few other fuel related things...
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Mar 29, 2009 | 2001 Oldsmobile Alero
It only idles ruff during park or idle
Here is the most common cause of surges and stalls and low idle rough idle, it is the idle speed control air-bypass valve and throttle valve (IAC for short), they get full of gunk over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
Feb 06, 2009 | 2001 Mercury Sable
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
57 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
