Question about Jensen VM9510 Car DVD Player
Uv7i will not take cd
Will not take cd whats wrong?
My Phase Linear UV7il accept only some CD's
the head unit is not reading due to incompatibility with thebrand or type of disck
Dec 29, 2009 | Car Audio & Video
How to assemble the phase UV7i dvd/cd player
can u give me some info about how to identify the power supply wire to a car cd player
Jun 27, 2009 | Phase Linear UDV9010 Car DVD Player
Jensen UV7i Need internal amplifier
I own a shop either get me the PN off the IC. I will either have it in stock or, can order for you. Audiovox will not sell parts for this unit. But, they will service this unit for you. Call us @ 727-530-5221, Radioactive Car Audio #1 in Tampa Bay area since 1987.
Dec 10, 2008 | Car Audio & Video
Wiring uv7i
you can use the deck without a remote, the only thing is you cant go into the system without the codes. there is a sequence code you must enter to disable it. there are a couple of videos on youtube but none for the uv7i. trust me, i 've been there on and off since the summertime. i am not sure if the sequence works due to me not hooking it up to external monitors but you can disable the blue screen with a on/off switch...only problem is, you'll have to do it everytime you turn your car on. here's what you do....
buy a on/off switch(radio shack $3)
hook the pink wire to one part of the switch-the other to the negative ground
put a dvd in(from what i hear, it must be store brought), wait unntil the blue screen comes up
turn the switch off...wait two seconds/turn on...wait two seconds/turn off...wait two seconds and turn back on. the blue screen is gone and video is on. ifyou still need the diagram, i'll scan mine for you.
Nov 09, 2008 | Phase Linear UDV9010 Car DVD Player
Jensen uv7i
did you try resetting the unit?
May 29, 2008 | Jensen VM9510 Car DVD Player
Phase linear uv7i
RUN A TOGGLE SWITCH FROM THE PINK WIRE AND THE OTHER END GROUND IT PUT DVD IN FLIP SWITCH 2OR3 TIMES YOU SHOULD BE ALL GOOD
Dec 28, 2007 | Alpine CDA 7893 CD Player
Jensen VM9510 Car DVD Player Logo
35 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
