Admiral ATW4475XQ0 leaks
During gentle cycle
4 Suggested Answers
tbirdfan1
  • 3051 Answers
SOURCE: water leaks
Hello there and welcome to fixya here is a list of things to check now you need ot try to figure out if it is doing all the time or at what time ok os the information i am going to send you will be in 2 or 3 seperate posts so you can go thru each one
During fill only If the washer leaks only during the fill cycle, check these: Air-gap device -The air gap is a small device found on most washers that prevents the wash water from being siphoned into the household water supply. It's located either mid-way along or at the end of the black rubber hose that comes from the water-inlet valve. Often it's made of translucent plastic. If one of the air-gap components deforms or cracks, you may need to replace it. The tube -There's a rubber tube that runs between the water-inlet valve and either the air-gap or the inlet spout. If it cracks or breaks, it can cause a leak. Inlet spout -Most washers have a plastic spout near the top of the main clothes tub that directs the water into the tub. If the spout cracks or breaks free of its mounting, it can cause a leak. During drain and spin only A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Posted on Dec 23, 2011
richroth
  • 9472 Answers
SOURCE: Admiral washer leaking water from bottom
What is the model number of the unit?
Posted on Nov 24, 2012
  • 12 Answers
SOURCE: Admiral ATW4475XQ0 washer does not shut off water
check the solenoid valve if its okey!if okey check the water level switch theres a hose on it maybe block the hose or the level switch not working!
Posted on Oct 03, 2013
Admiral ATW4475XQ0 washer does not shut off water on high level, and overflowed
Oct 03, 2013 | Admiral Washing Machines
Admiral washer begins leaking water from the bottom during the spin cycle
It is so common that the drain leaks in many ways and is the most problematic fault in a washing machine. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that water has leaked then as the drain hose pump/valve and fittings are located on the underside of the machine it is important that you look for possible leaks here. In some cases the drain hose would be clogged at the drain end to outlet of the house and so there will be back flushing resulting in overflow to the outside. Also the drain pump/valve can be clogged or the drain hose clamps can be loose on the grip which can all cause the leak to occur. Removing and cleaning the drain pump/valve, tightening of the hose is also very important. Also water can leak if there are gaps on the front door gaskets and must be checked but this will happen only during the cycle and not on the drain cycle end.
Tips for leak: http://www.espares.co.uk/advice/washing-machines/a/7/1461/do-you-have-a-leaky-washing-machine.html
Check for tips on the link below to identify parts and removal:
Jan 23, 2013 | Admiral AW22 Top Load Washer
Nov 24, 2012 | Admiral Washing Machines
Water leaks
Dec 23, 2011 | Washing Machines
I don't have a model number right now, but the front door on my Admiral dishwasher is leaking at the bottom. I have changed the gasket inside the door panel at the bottom but it still leaks. This is a...
it may not be the door that is leaking if this is an older admiral or whirlpool dishwasher the lever that holds the soap door closed has a little rubber seal that after time will let water in during the wash cycle it the runs down the inside of the door and out the bottom if you rmove the in side of the door you will probably see the water trail from the wax motor down. this gasket is not expensive or hard to replace.
Mar 08, 2011 | Admiral Dishwashers
My washer leaks and it is very loud when it is in the spin cycle. can anyone please help me?
Hi
Thanks for using FixYa. A washer that leaks only during the spin cycle often has a leak in the main drain hose. Inspect the entire hose and correct any problem you find. Alternatively, the steel or plastic outer tubs can rust, split, or be punctured. This may be most visible during large loads and high water levels. If this happens, you may have to replace the entire outer tub--but that may not be an economical repair to make. Consult a qualified appliance repair technician for further details.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Dec 05, 2009 | Admiral AW22 Top Load Washer
Admiral makes rattling noise during spin
Hello, could be a possible bad pump. I would lean the washer back so you can see the belt. take the belt off and spin all of the pulleys. the pump pulley has a s leave that sometimes makes a grinding noise.
Jan 05, 2009 | Admiral AAV7000A
Washing Machines Logo
Top Washing Machines Experts
