Question about Pool & Spa
Why is my pool cloudy - Pool & Spa
Ph level is at 'ideal' chlorine level is at 3.0 but the pool water is still cloudy. Please help?
The cloudiness could be suspended particles or algae. Use an algae k i l l er as recommended, then a flocculant (water clarifier) as recommended, then vacuum the pool bottom and run the filter overnight.
After that check the ph, alkali level, chlorine level, and adjust as needed. That should do it.
Feb 05, 2017 | Pool & Spa
Cloudy foamy water
the filter is probably too small so you need to clean every day if not 2x a day super shock pool until clear
Jul 01, 2014 | Intex 18x10x42" Oval Frame Pool w/ 1000...
Pool cloudy with yellow powder salt system
yellow is mustard algea super shock then brush pool then clean filters and repeat if needed keep PH about 7.2 alkalinity about 100 you should be ok
Jun 12, 2014 | Pool & Spa
Water comeing out cloudy and makeing suds in pool
There could be a few things causing these problems. How old is the sand in the filter? Filter sand looses its filtering ability after 3-5 years and needs to be replaced. If the sand needs to be replaced, make sure you get actual pool filter sand. A lot of big box and home improvement stores sell play sand as filter sand. That will cause your pool to stay cloudy and never clear up. If the sand is less that 3-5 years old, you may need to clean it with a liquid filter cleaner that is poured through the skimmer. This works quite well!
Another issue causing the cloudiness and bubbles could be the type of chemicals you are using. I know that shock from big box and home improvement stores cause the water to be cloudy. Algaecides from these stores also cause foaming.
Jun 15, 2011 | Hayward SAND FILTER, PRO SERIES
High chlorine/cloudy/salt water pool
Purchase a PoolRx unit for your pool. PoolRx.com....No more algae!! Clearer water
Aug 26, 2009 | Pool & Spa
Cloudy brown dirt getting in my pool from sand pump
The dirt you are getting is most likely from the air, dirt and dust present in rainwater and the small amounts present on human bodies. It is settling out and going to the bottom. I recomend a vacuum attachment that connects to your pump/filter to keep this cleaned out. Basically it "plugs In" to the outlet on the pool and will get all that out for you.
Aug 11, 2009 | Hayward SAND FILTER, PRO SERIES
We switched to the saltwater system and the water is cloudy after 2 days
DID YOU USE POOL SALT, MINE STAYED CLOUDY FOR 2 WEEKS AND FINALLY CLEARED UP , I USED THE WRONG SALT , 25LB BAGS OF TABLE SALT FROM SAMS CLUB
Jul 18, 2009 | Intex Automatic Salt Water System for ...
Pool & Spa Logo
238 people viewed this question
Top Pool & Spa Experts
Jay Finke
Jay Finke
john h
David Spradling
David Spradling
Are you a Pool and Spa Expert? Answer questions, earn points and help others
